1.8 dohc vtec
Old Jul 1, 2003 | 12:01 PM
hot92honda's Avatar
Default 1.8 dohc vtec
can i drop in my b16a2 with mounts from a gsr?
Old Jul 1, 2003 | 12:06 PM
Nextelbuddy's Avatar
Default Re: 1.8 dohc vtec (hot92honda)
which car are u trying to drop this motor into?
Old Jul 1, 2003 | 12:15 PM
hot92honda's Avatar
Default Re: 1.8 dohc vtec (nextelbuddy)
i'm putting the b16a2 (obd1) into a 92 civic hatch. the mounts are from a 94 gsr.
Old Jul 1, 2003 | 12:24 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot92honda &raquo;</TD></TR><TR><TD CLASS="quote">i'm putting the b16a2 (obd1) into a 92 civic hatch. the mounts are from a 94 gsr.</TD></TR></TABLE>yes its fine.
Old Jul 1, 2003 | 12:29 PM
B18C5-EH2's Avatar
Former Moderator
Loved
What is an OBD1 B16A2?
Old Jul 1, 2003 | 12:31 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Sorry if this isn't 100% pertinent to your car, but here goes anyways:
Okay I have some more time to give a better answer to your question now.
First of all mounts:
For the timing cover side mount you will need to get the cast-iron bracket from any 1994-2001 Integra GS-R and also the aluminum mount as well. You can use the mount from a Del Sol VTEC as well, but not the 99-00 mount because it is totally different.
For the rear mount you will need to use a 1994-2001 Integra rear bracket. The actual rubber mount that bolts to the rear subframe can be the stock civic one. Check the 99-00 mount first and see if it will work too though before you go out and buy an Integra one. I used an Integra rear bracket on my fiancee's B16A2 swap in 1999, but the stock 99-00 one might work too.
The topside tranny mount can be the Civic VX one - it is the same thing.
The front mounting brackets need to be from an Integra 1004-2001, but if you want to keep A/C then get the A/C bracket for a Del Sol VTEC model. the actaul mounts that bolt to the underside of the framerails need to be the stock Civic ones.
I would also insert the energy Suspension mount inserts while you've got the mounts out.
For shift linkage the 99-00 Si linkage will bolt right up.
Axles can be either the 99-00 si axles or any 1994-2001 Integra axles. I'd try to get non-ABS ones as they are usually cheaper.
As I stated before I have a B16A2 swap in a 1992 Si hatchback as well as a B18C5 swap in a 1992 CX hatchback.
There are some differences in these swaps even though they are both "OBD2" swaps, and it all has to do with the factory engine harness that each engine comes with.
On the Integra the engine harness is exactly the same as any 1992-1995 Civic, but it just has a few extra sensor plugs, etc.
On the 99-00 Civic Si (B16A2) the engine harness is totally different from the Civic and Integra ones and CANNOT be used in the 1992-1995 Civic.
So what's the solution?
There are two ways that you can make the B16A2 swap very easy. One way makes it nearly plug and play, while the other requires a bit more work, but you could save some money in the process and it's still not hard at all.
Method number one:
Find any 1996-2001 Integra engine harness. Ideally it should be a GS-R or Type R unit, but if all you can find is an LS then it's only a few extra wires. I'd imagine they should not be too hard to come by and will cost probably no more than $100.00-$150.00 used and they are only $350.00 or so brand new from Honda if you need a reference point.
If you can locate the 96-01 engine harness then simply plug it into the engine and drop the engine in. Even though the harness is technically "OBD2" trust me it is a direct plug in for the 1992-1995 Civic on the underhood strut tower harnesses.
What ever you decide you should ditch the 99-00 Si ECU. It is OBD2 and horrible. What you'll need to run is a re-chipped P28 (1992-1995 SOHC VTEC ECU) from Kenji Plennert in Florida. His e-mail adress is kenji211@tampabay.rr.com - tell him Tom sent you from H-T. I run his ECU on my Type R swap and it is way better than any stock OBD2 crap ECU. even if you wanted to keep the 99-00 ECU you'd need to buy a jumper harness and wire up all of that extra OBD2 bullshit, which is not necessary.
If you run that re-chipped P28 and the 96-01 Integra harness then the swap is almost 100% plug and play. Hell in your Civic VX it will be 100% plug and play if you find a GS-R or Type R harness. Not one single wire will need to be ran this way. My 1992 CX (prewired for VTEC like your VX is, because all 1992 Civics were wired for VTEC regardless of trim) didn't require one single wire at all with my 1998 B18C5 swap because I used a re-chipped P28 and the Integra engine harness.
Actually I just recalled that you will have to only do one thing wiringwise. Simply extend the two wires foir the intake air temperature sensor. for some reason the B16A2 is the only B motor that I know od that locates its IAT sensor into the actual intake tubing rather than the intake manifold itself. for this reason you must simply extend the existing two wires for that sensor on the engine harness to stretch from the intake manifold (where it is on the Integra) to whatever intake arm you decide to run.
Method Number Two:
If you are just way too broke to buy a used 96-01 Integra engine harness, you can use your stock Civic harness. It will require more work, but if you don't mind that then you could save some money. I'll go ahead and tell you that if I were you I'd really try to find that Integra engine harness, but here goes anyways.
To use your stock Civic harness you will need to do some minor wiring changes and a few other things. It's not hard and if you just breathe deeply and read this I think you'll find it to be prety easy actually. I used this method back in 1999 when I put a B16A2 into my fiancee's car, and I did not know that the 96-01 Integra harness would make it near plug and play.
Change #1:
First of all there will be a minor difference in the plug style on the distributor. Some people will say :"get an OBD1 distributor" but they must think that OBD1 distributors are cheap or easy to find used. The B16A2 distributor will have one big plug on it, while your stock Civic and it's engine harness has two plugs. All you have to do is unpin the two lowest fat wires from the B16A2 distributor and repin them into the extra plug on the VX engine harness.
Here's a picture of the B16A2 distributor. The arrows are pointing to the wires you need to unpin. This is a picture of an unaltered B16A2 distributor:
So here's that extra plug on your VX harness with the two wires already ran into it. Notice the wires are the exact same color, making it "idiot proof" so to speak. i'm glad they decided to keep the same colors:
Okay that tales care of that.
Change #2:
The plug on the B16A2 alternator won't plug into your VX harness. There are two ways around this. You could either find an OBD1 B Series distributor, or you can swap the voltage regulator from your VX alternator into the B16A2 housing. The B16A2 will have a square plug while the VX harness will have a round plug. Simply pull both alternators apart and swap the voltage regulator. You'll know which part it is because the plug is part of it. A few 8mm and 10mm bolts are all that stand in your way.
Change #3:
Injectors.
The B16A2 uses OBD2 style injector plugs that will not plug into your VX harness. You can either buy new OBD1 injecotrs for a 1994-1995 Del Sol VTEC or just use your stock Civic VX injectors. I still run the 1992 Civic Si injectors in my fiancee's B16A2 and it dynoed the same or better as any other B16A2 with i/h/e in my area with 143whp with 102 ft-lbs. of torque.
Change #4:
Your VX comes with a 5-wire o2 sensor, which means that the harness will also support a 5-wire o2 sensor. The B16A2 will have 2 4 wire o2sensors, but if you use the re-chipped P28 it will only read for one.
You will need to covert your 5-wire harness to support the B16A2's primary o2 sensor with only 4 wires.
This is courtesy of poison:
- WHT/RED wire goes to D14 which is O2 Sensor Input
- ORG/BLK wire goes to A6, which is Heater Control
- GRN/WHT wire goes to D22 which is Sensor Ground
- YEL/BLK wire goes to A25 which is Sensor voltage
So after that you simply extend the IAT sensor wires just as you would even with the Integra 96-01 harness.
What do you think of that?
Old Jul 1, 2003 | 12:34 PM
92SiHatchie's Avatar
Default Re: 1.8 dohc vtec (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">What is an OBD1 B16A2?</TD></TR></TABLE>
does he mean the jdm b16 second gen?
Old Jul 1, 2003 | 12:39 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: 1.8 dohc vtec (92SiHatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SiHatchie &raquo;</TD></TR><TR><TD CLASS="quote">
does he mean the jdm b16 second gen?</TD></TR></TABLE>
If he does then he should say so.
There are too many B16A motors to be calling them wrong names, codes, and OBD generations.
There's:
Pre-OBD B16A1 (yes I've seen the suffix "1" before!)
Pre-OBD B16A
OBD1 grey plug JDM B16A
OBD1 USDM B16A3
OBD2 B16A2 - USDM
and more I'm sure. There's B16A4, etc. if we want to list them all.
Old Jul 1, 2003 | 12:43 PM
Brewer's Avatar
Damn, that is a THOROUGH explaination
B18C5-EH2 =
Old Jul 1, 2003 | 01:06 PM
There's:
Pre-OBD B16A
OBD1 USDM B16A3
OBD2 B16A2 - USDM
i know what you mean but he prolly does mean that.btw your very informative.
Old Jul 1, 2003 | 01:27 PM
B18C5-EH2's Avatar
Former Moderator
Loved
By the way, pics courtesy of Katman:
And any OBD1 wiring:
Old Jul 1, 2003 | 02:01 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: 1.8 dohc vtec (BrewerHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch &raquo;</TD></TR><TR><TD CLASS="quote">Damn, that is a THOROUGH explaination
B18C5-EH2 = </TD></TR></TABLE>
Old Jul 1, 2003 | 02:09 PM
KRiS1's Avatar
?</TD></TR></TABLE>
Do the ES inserts add a lot of vibration?
Old Jul 1, 2003 | 02:11 PM
KRiS1's Avatar
Default Re: 1.8 dohc vtec (POS Hatchback)
Also will the exhaust manifold just bolt up to the civic cat?
Old Jul 1, 2003 | 02:41 PM
madman604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">
Do the ES inserts add a lot of vibration?</TD></TR></TABLE>
at first they do but they soften up a little. or at leest it seems like it.
Old Jul 1, 2003 | 02:50 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">Also will the exhaust manifold just bolt up to the civic cat?</TD></TR></TABLE>
Yes it will if you get the 99-00 Si exhaust manifold complete with the "A pipe" section that bolts to the cat.
Also any USDM Type R and LS/RS Integra manifolds will also bolt up, but the GS-R is riughly 2 to 3 inches too short and requires extending the exhaust to meet up with the cat.
You could also use the B series cat if you get it - might be lower mileage and in better condition too.
Old Jul 1, 2003 | 06:11 PM
KRiS1's Avatar
Thanks
Old Jan 23, 2004 | 10:54 AM
GTlvr82's Avatar
Default Re: 1.8 dohc vtec (KRiS1)
Best thread evar...might as well throw it up to the top....for all the noobs. This thread should be made into a sticky for the search challenged.
Old Jan 23, 2004 | 10:57 AM
dohcMONSTER's Avatar
Default Re: 1.8 dohc vtec (GTlvr82)
bravo (clap clap clap clap)
Old Jan 23, 2004 | 10:59 AM
GTlvr82's Avatar
Default Re: 1.8 dohc vtec (sohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">bravo (clap clap clap clap) </TD></TR></TABLE>
Thanks...but this should be a lesson in searching. I found this thread in the FAQ thread at the top of EG+ forum....let that be a lesson to you.
Old Jan 23, 2004 | 11:22 AM
turbo_ef9's Avatar
actually.. i dont think he can use the gsr driver side mount if the motor is a jdm one.. the mount bolts are different.. if i remember right, i was going to use my gsr mount but the bolts lined up straight as the b16 from the eg front clip lined up at an angle..
Old Jan 23, 2004 | 11:27 AM
ekb18cCivic's Avatar
Default Re: 1.8 dohc vtec (eli_vang)
ok im a litle lost... why is the thread title 1.8L dohc vtec when its about a b16a2 which is a 1.6L??? and correct me if im wrong the b16a2 is obd2 not obd1 .. which means you will need a conversion harness and injectors and a few other things.. i didnt read the whole thread im running out to work so i didnt have time sorry guys
Old Sep 20, 2005 | 08:31 AM
sparco562's Avatar
[QUOTE=B18C5-EH2]
Would this be vice versa which allow you to use the obd1 engine harness with obd2a chassis (underdash harness to the ecu) with an ecu jumping harness?
Old Feb 6, 2006 | 07:42 PM
PoWeRBaN_PaNdA's Avatar
couldn't you just use a d16z6 harness as well
Old Mar 20, 2006 | 07:46 AM
midnitesol's Avatar
dont forget the B18B
