1996 civic dx overheating
Old Feb 1, 2014 | 05:54 PM
raider1qaz's Avatar
Default 1996 civic dx overheating
Hello i have a 1996 Honda Civic dx, its been overheating today it went as high as 227 degrees, ive changed the rad a few months ago, just changed the thermostat,waterpump is a few months old,new antifreeze in,fan is hard wired so it turns on when car starts(old owner did it),heater is warm
Old Feb 1, 2014 | 05:57 PM
Former User's Avatar
Default Re: 1996 civic dx overheating
Try bleeding the cooling system:
https://honda-tech.com/forums/showth...1#post39830585
Old Feb 1, 2014 | 06:05 PM
raider1qaz's Avatar
i actually just did today
Old Feb 1, 2014 | 06:06 PM
Did you bleed as described at the link? You want to ensure that there's no air in the cooling system before considering other possibilities.
Old Feb 1, 2014 | 06:10 PM
raider1qaz's Avatar
ya ive seen that link before when i changed the waterpump, did it just like it says, im thinking maybe heater core clogged alil? idk
Losing coolant? White smoke in exhaust? Bubbles in the coolant?
Old Feb 1, 2014 | 06:17 PM
raider1qaz's Avatar
losing coolant,no leaks tho...white smoke -havnt checked...bubbles in coolant-when i had water in it a few days ago it did have bubbles
Old Feb 1, 2014 | 06:18 PM
Rent (free) a block tester kit at AutoZone to test for exhaust gas in the coolant.
Old Feb 1, 2014 | 06:23 PM
raider1qaz's Avatar
is that to check head gasket?ive changed mine like 8 months ago
Old Feb 1, 2014 | 06:24 PM
Yes
It appears that the head gasket may be blown or that the head/block mating surfaces are not flat.
Old Feb 1, 2014 | 06:26 PM
raider1qaz's Avatar
would you know when u went it if they give you the test fluid?
Old Feb 1, 2014 | 06:27 PM
I think you need to purchase the fluid.
Looks to be about $8.
http://www.autozone.com/autozone/acc...ntifier=391381
raider1qaz's Avatar
rent*
Old Feb 1, 2014 | 06:52 PM
raider1qaz's Avatar
just picked it up, thanks man ill check tomorrow to see
Old Feb 1, 2014 | 06:54 PM
Good luck.
Old Feb 2, 2014 | 12:18 PM
raider1qaz's Avatar
hey i did the check and ya seems its alil blown, the blue turned a kinda green so some yellow was in it, gonna order the headgasket and change it,thanks man you know your stuff
Old Feb 2, 2014 | 12:39 PM
Before you install a new gasket, check the head and block mating surfaces for warpage.
Old Feb 3, 2014 | 10:09 AM
raider1qaz's Avatar
is there a way i can check before i take it to get resurfaced?
Old Feb 3, 2014 | 10:11 AM
raider1qaz's Avatar
do i have to take the block out to get it resurfaced?
Old Feb 3, 2014 | 10:57 AM
Katlyn Hezinger
Dec 7, 2017 04:54 PM
WTB AUTO EK
May 20, 2016 07:03 AM
civistyleny
Dec 1, 2012 07:45 PM
bptmobb
Dec 7, 2011 09:24 PM
404notfound
Oct 3, 2010 10:37 AM
