Slim Fan mandatory?
Old May 16, 2011 | 11:52 AM
DSMAddicted's Avatar
Default Slim Fan mandatory?
Guys,
I am planning on installing an RMF Narrow replica next week. This is on a '93 Hatch with ITR swap. Are slim fan or OEM fan grinding mandatory? If I need a slim fan, which brand/model would you recommend?
Thanks for clarifying!
-Walter
Old May 16, 2011 | 12:05 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Slim Fan mandatory?
I've seen people trim their OEM fan and it works just fine. Or you could order a slim fan and that would be "cleaner"
Old May 16, 2011 | 01:09 PM
Dekorum's Avatar
You need to either cut the OEM fan housing or get a slim fan. I got a Flex A Lite when I ran into this problem. Best deal around is on Amazon.
http://www.amazon.com/Flex-lite-125-...5580054&sr=8-1
Old May 17, 2011 | 06:36 AM
Thanks guys, I am trying to go the "cleaner" route.
Any thoughts regarding this setup?
http://www.slimfan.com/ProductDetail...Hondashroudfan
Are there better performing/better priced solutions out there?
Thanks for your input,
-Walter
Old May 17, 2011 | 08:15 AM
grumblemarc's Avatar
The Grumpiest
I picked up the slim fan I have linked to in my sig simply for the plug and play aspect of it. I haaaaate having to splice wires. There's nothing special about it past that and that it is low profile and cheaper that a FAL. It definitely does it's job though. If you get a shroud from them it makes mounting a little easier but due to the fact that I had to drill the mounting holes a little larger to get the bolts (the fitment is not precise and TBH I was not thrilled by the quality of the one I got-I might take a few pics and do a real review) to fit I'd get a FAL if I had the money.
Old May 17, 2011 | 10:25 AM
Thanks Marc.
Do you guys think the slimfan.com 1000cfm solution (fan + shroud) are adequate for my setup? I really want it to be as efficient as OEM or better, I don't want my car to run any warmer (even if it doesn't cause overheating).
My setup: stock B18C swap with RMF Narrow header, exhaust and intake. Car is driven in both Atlanta and Miami, about half and half traffic/highway.
Thanks for the help,
-Walter
Old May 18, 2011 | 09:13 AM
TTT.
-Walter
Old May 20, 2011 | 04:38 PM
The Grumpiest
Pics as promised.
This is the slimfan mounted to the Neukin shroud mounted to the Go Autoworks D-series aluminum radiator. This is going in tomorrow barring any incidents.
Pic #1. Mock-up of all 3 pieces.
Pic #2. Notice the way the shroud fit flush to the right of the rad?
Pic #3. Well it doesn't on the left side! WTF!
Pic #4. Don't know what the hell is going on here. Notice the patch welding job on what looks like a crack or cut in the shroud above the drain for the rad? Again WTF?
Pic #5. Mounting tab that doesn't line up even after widening the hole. WTF.
Pic #6. The the OEM style plug for the fan.
Pic #7. This is how the fan mounts to the shroud. Holes had to be made larger to fit the pegs on the shroud.
Pic #8. The other side of the rad.
Right now I cannot speak to the performance of this particular combo but I'll find out soon won't i?
Old May 20, 2011 | 05:07 PM
SeanK325's Avatar
I read somewhere on here that 1000cfm was low. i can't find the thread, though. Can anyone chime in? I have a dual-core that I've been meaning to install, but don't know which fan I should get. Nobody has a clear answer on how many CFM's are necessary.
Old May 20, 2011 | 05:17 PM
The Grumpiest
I have read that the shroud makes all the difference with these lower CFM slimfan applications. Probably why the lower CFM stock fad cools so well.
Old May 20, 2011 | 05:24 PM
SeanK325's Avatar
well, i'm interested in seeing how you feel about the fan you got. keep us posted.
were did you get the shroud from?
Old May 20, 2011 | 05:41 PM
The Grumpiest
Same place as the fan. Link in my sig.
Old May 21, 2011 | 03:41 PM
The Grumpiest
Rad, fan and shroud are in the car. Took almost twice as long for the fan to kick on as with the OEM combo while I was bleeding the air. Probably a testament to the cooling capacity of the new rad. When the fan did finally kick on it sounded like a mini-tornado and moved a lot more air than it did when it was mounted to the stock rad with no shroud.
I need to mention that the mounting legs of the rad were a little off as well. All in all not a precision fit for any of these components.
Old May 22, 2011 | 11:31 AM
Red_Army's Avatar
im running a mishimoto rad/fan combo. they line up nicely and fit well.
the fan as marc said sounds like a mini tornado in the front of the car. im aware they aren't the same brands. also it only puts out 933.5 cfm according to them.
you would have to splice wires though.
Old May 22, 2011 | 12:16 PM
SeanK325's Avatar
by mounting legs you mean where the rad fits on the radiator support, right? How much clearance are you getting with everything? No rubbing?
Old May 22, 2011 | 12:32 PM
The Grumpiest
I'll take some more pics.
Old Jan 14, 2012 | 03:53 PM
mr_munro's Avatar
i am in the exact same boat as i just ordered the RMF. What did you end up getting OP?
Old Jan 14, 2012 | 04:05 PM
1994turbocivic's Avatar
i have a lsr, with full length cx racing double core rad, gates racing low temp thermostat, 15" hayden slim fan no shroud... imo i dont know how well shrouds help, but ive never had cooling issues... PS i directly mounted fan with metal zipties to rad fins
Old Jan 14, 2012 | 04:09 PM
mr_munro's Avatar
Any idea how the fan + shroud combo you bought will work/fit on a full sized Integra Type R radiator? Or do you really need a hald size radiator for it
Old Jan 14, 2012 | 04:17 PM
H22AFerio's Avatar
I would go with the slim fan I could get the RMF header to clear but I went with a slip fan! it looks better it runs quieter and its waaaay more efficient.
this is what I was running before I switched to my boosted motor you can see there is plety of clearence but I dont know about your setup.
Old Jan 15, 2012 | 04:15 AM
The Grumpiest
It's obvious the setup is for a half rad. If you need a fan/shroud combo for a full sized one I've seen them available elsewhere.
KamalHonda
May 30, 2018 12:50 PM
slow sol
Mid-Atlantic (Sales)
Sep 18, 2009 04:58 AM
Topshot
Feb 21, 2009 08:44 PM
rusted_eyes
Nov 5, 2004 12:39 PM
