***Official All-Motor Stock Sleeve B20VTEC Thread***
Old Nov 26, 2010 | 10:59 AM
  #1451
dc4teg95's Avatar
Default re: ***Official All-Motor Stock Sleeve B20VTEC Thread***
Originally Posted by lunatics209
I spin my 85x89 all the way too 9500...
are you forged internals? my plan for my b20vtec is
HEAD:
2001 itr stock head
sk2 stage2 tuner cams
supertech valve springs
itr valves,keepers, and retainers
BLOCK:
b20z block
84mm itr spec rs machine pistons
arp head studs
stock rods shotpeened and balanced and arp rod bolts (9mm i think)
stock crank micropolished and balanced
MISC:
Spoolin performance toda replica header
2.5 magnaflow high flow cat
greddy evo2 cat back
Old Nov 26, 2010 | 12:50 PM
  #1452
spr2000's Avatar
Planned build:
B20/vtec 84.5mm bore
RS Machine 84.5mm pistons
Gold Eagle Block Guard
ARP Hardware top - bottom
shot-peened rods
ACL Race Bearings
Balanced rotating assembly
Gold Eagle LS/Vtec kit
99 Si B16 head
ITR valve springs
H22 Injectors
Skunk2 Pro Manifold
professional products 68mm TB
TB to Manifold port match
Custom 3" Intake Piping with Blox Velocity stack and filter
CTR Cams
Some kind of cam gear
3 angle valve job
slight porting on intake side
Hondata IM gasket
OEM Honda seals/gaskets
GSR/ITR Water & Oil pumps
Hytech Replica (Unless money starts pouring out my *** for this build)
2.5" test pipe
2.5" Mandrel Bent Exhaust - possibly by Burn's Stainless / Royal Muffler
Burns Stainless 12" canister
Resonator
Will be tuned by Church Automotive on s300
Hoping for 210whp and 150wtq
Old Dec 2, 2010 | 02:18 AM
  #1453
leed's Avatar
My first NA build.
B20 w/ RS pistons. W/ 2+ decks on the head, 12.5ish c/r.
Stock GSR head w/ the flashing cleaned up, ala factory R, S2P2 cams, skank2 springs/retainers. Stock valves.
Hytech replica to 3" through two magnaflow 5"x14" mufflers and one magnaflow oval.
Stock GSR IM w/ functioning IAB's. IAB's made 5-7tq from off idle to 5200.
74mm TB from Chis Maletsky. Very nice unit.
Mfactory geared tranny built by 20/20 motorsports in Bellingham, WA.
All this in a very unattractive $300 93 CX hatch = very fun and most likely not going to get stolen.
PS, after degreeing the cams to the recommended settings I ended up @ +9e,+3I. I'm at the end of adjustment on the exhaust gear. What a joke.
Although the cams did make for a very pretty TQ curve imho.
Dave
Old Dec 2, 2010 | 02:39 AM
  #1454
pasaunde's Avatar
Originally Posted by leed
My first NA build.
Dave
Nice Torque curve...
Which size header are you using small or big tube?
Old Dec 2, 2010 | 06:48 AM
  #1455
Do-Work's Avatar
My first NA build.
Dave
are you useing the M-Factory Final drive too?
Old Dec 2, 2010 | 11:31 AM
  #1456
krazy one's Avatar
very nice numbers and torque curve. its amazing that you made those numbers on a stock gsr IM also.
Old Dec 2, 2010 | 11:38 AM
  #1457
DDTECH's Avatar
WOW.. lol if i went above +6 on the exhaust the car would start pinging like no other. Taking too much away from the power stroke.
What gears were you using dave?
Old Dec 2, 2010 | 06:50 PM
  #1458
hey man's Avatar
i got a thrwead if anyone can just leave some input thanks
Old Dec 3, 2010 | 02:07 AM
  #1459
Natural Aspirations's Avatar
Come again?
Old Dec 5, 2010 | 08:28 PM
  #1460
negroeg6's Avatar
95 GSR head Alaniz Competition Head Work, skunk2 dual valve springs crower retainers stock valves OG skunk2 manifold 68mm blox TB port matched to IM Rc 310 injectors Tri Y headers 2.5 collector Blox p1's degree'd Dyno max 2.5 muffler
b20z block 84.5 bore cp 11.5.1 comp pistons eagle rod z10 block girdle moroso oilpan ctr crank pulley acl race bearings arp'd up hondata s300 walboro 255 fp
put down 218hp 156tq tuned by lawrence at DSR in sanjose,ca
Old Dec 10, 2010 | 05:00 PM
  #1461
prjct92eh2's Avatar
Originally Posted by prjct92eh2
Just got this done and tuned at RLZ yesterday
Block:
B20 block
Bored to 84.5 mm
Stock crank
Eagle rods
11.5:1 Wiseco pistons
Golden Eagle block guard
P72 oil and water pump
Head:
Stock B16
Milled 0.020", 12:1 compression
Supertech springs and retainers
Blox Type-C cams
Skunk2 Pro IM
Omni 70 mm TB - port matched
AEM fuel pressure regulator
GE fuel rail
RC 440 cc injectors
Walbro 255 fuel pump
Tuned on Crome
93 octane pump gas
PW:JDM carbon whale *****
JUN header
3" exhaust
Tranny:
ITR 1-2 gears
Kaaz 3-5 gears
OBX LSD
fidanza 7.5 lb flywheel
ACT clutch/PP
Originally Posted by pasaunde
Howard's dyno reads low your probably in the 220s on a DynoJet.
Update: Numbers on a Dynojet. pasaunde was almost right!
Old Dec 10, 2010 | 09:47 PM
  #1462
egycasper16's Avatar
is that stock sleeves or resleved
Old Dec 20, 2010 | 10:10 AM
  #1463
rea1ist's Avatar
for you guys using the Supertech springs, which one are you guys are using SPR-H1002D or SPR-H1002DR??
Old Dec 20, 2010 | 12:09 PM
  #1464
civic00sir.'s Avatar
im running SPR-H1002D on my new setup being built, i believe they are almost the same just this ones are the newer and improved ones, like 2gen, when supertech came to the market i bought a set of valves, springs and retainers, and they had diferent part numbers but they were the same components as the ones on the market this days....
Old Dec 24, 2010 | 09:01 PM
  #1465
deucedeuceEK's Avatar
ive been looking but i have not found anything. What kind of numbers are you guys putting down with a bone stock gsr head and 84.5 rs machine pistons?
edit- my setup will be that with a 3 inch exhaust.
Old Dec 25, 2010 | 03:37 AM
  #1466
negusjuda's Avatar
depends on what other parts your running and who tunes it it can make anywhere from 160-190 no one really can tell you what it will make you have to dyno it
Old Dec 25, 2010 | 04:53 AM
  #1467
Well yes your right but just like everyone else's dyno sheets it could give me a general idea. Im not asking about what I would make, but what others have made.
Old Dec 25, 2010 | 05:03 AM
  #1468
blackeg's Avatar
is there a good aftermarket cam to run with my oem itr springs and crower steel retainers? just looking for something a little more than itr's.
rev limit will be in the 8500 range and the bottom end is a 84.5 b20 with rs itr pistons, oem b20 rods with arp bolts. i was thinking something like blox b or tuner 2's....
Old Dec 25, 2010 | 10:10 AM
  #1469
jdmcivic2fast's Avatar
ive seen tuner2 on itr valve train, holds up just fine.
Old Dec 25, 2010 | 01:01 PM
  #1470
lunatics209's Avatar
Originally Posted by The Ogre
what sorta setup do you have?
PM me I'll tell you my setup don't want to thread jack.
Old Dec 25, 2010 | 01:03 PM
  #1471
Sleeved CTR block. Thats why I didn't post my build in here.
Old Dec 26, 2010 | 12:25 PM
  #1472
DDTECH's Avatar
No. And if you have, it wasn't ran in vtec..
Old Dec 26, 2010 | 02:04 PM
  #1473
negusjuda's Avatar
im running tuner 2 with itr retainers and portflow springs
Old Dec 26, 2010 | 04:56 PM
  #1474
DDTECH's Avatar
Portflow springs.
Retainers dont really make or break running cams setups.. you need a spring to support the lift, the retainers support the pressure fine.. its springs you worry about.
i'm sure a valvetrain with itr retainers is what jdmfanboy ment..otherwise he's an idiot.
Old Dec 26, 2010 | 05:20 PM
  #1475
I've honestly seen stock GSR springs and Crower stage 3's spun to about 9k, and it actually lasted some how. I eventually talked him into buying a used set of quality springs.
