190/60/15 tires on integra
Old Sep 13, 2009 | 04:49 PM
pinkspider's Avatar
Default 190/60/15 tires on integra
Hello all, I recently traded rims with my friend who is running 190/60/15. It is noticeably fatter than the stock. My car is lowered and it makes scraping sounds when I turn right or hit any hard bumps. Is it safe to run, relatively speaking? My only concern is that something will slash the tire while I hit a bump. Otherwise I can find some cheapo tire shop who will probably trade tires with me.
Old Sep 13, 2009 | 04:52 PM
mrdeadman's Avatar
They let me pick
Default Re: 190/60/15 tires on integra
Stock size is 205 50 15r or 195 55 15r. So your tires are skinnier and taller than what comes standard. Are the scraping sounds actually rubbing sounds from your tires or is it something else?
Old Sep 13, 2009 | 05:36 PM
95DC2GS-R's Avatar
Those tires are smaller in in width and taller than stock 195/55/15's. You probably need to take the fener liners out, or even roll the fenders.
Old Sep 13, 2009 | 05:43 PM
hushypushy's Avatar
Raise your car and/or get new tires. Rubbing tires isn't the end of the world but it's still bad.
Old Sep 15, 2009 | 04:49 PM
nsxtasy's Avatar
H-T Order of Merit
No and no.
The stock size on all US-market Integras is 195/55-15 for models that came with 15" wheels, and 195/60-14 for models that came with 14" wheels.
195/60-15 is the same 195 treadwidth as both those sizes, NOT skinnier, but has a larger outer diameter. That's why they rub.
I recommend replacing them with tires in a size whose outer diameter is approximately equal to the stock size, so it won't rub. For 15" wheels, that means either 195/55-15 or 205/50-15, and NOT 195/60-15. 205/50-15 is slightly wider than 195/55-15, but the outer diameter is slightly smaller (by 1.6 percent), so the clearance is usually about the same.
Old Sep 15, 2009 | 06:36 PM
mrdeadman's Avatar
They let me pick
Originally Posted by nsxtasy
No and no.
He said he was running 190/60/15. Please tell me what I said was wrong?
Old Sep 15, 2009 | 07:16 PM
hushypushy's Avatar
Stock Integras did not come with 205/50/15. They came with 195/55/15 or 195/60/14. Says that right here in my owners manual
Old Sep 15, 2009 | 07:40 PM
mrdeadman's Avatar
They let me pick
Bastard.
Johnoolo
Dec 1, 2013 09:13 AM
VR4ownzU
Dec 22, 2008 01:50 PM
gsr sol
10
Jun 9, 2004 01:30 PM
thatpreludeguy
Jan 3, 2003 05:51 PM
zk11
Oct 8, 2001 01:42 PM
