Timing Belt Change?
I have an 01 GSR with 107K miles on it.
I do not know if the previous owner changed
the timing belt yet. I popped off the valve
cover and it loooks good. but is there another
way i can tell that i need to change it?
if you dont know then change it since its over 100k. another is have your valve cover off and turn your crank pulley counter clockwise. look for stretch marks, cracks, etc
You can't tell by looking at it. If you know where the previous owner had the car serviced, you could call them and ask them to check their records. Otherwise, I would just change it. Better safe than sorry.
if its the oringal oem belt you can tell it should have honda on it unless its been changed for a oem belt,what i say just change it if you feel like its not just give's you that peice of mind cause once it snaps ur in way more trouble later off the downrun.
I don't know where you get your "suggested" number from. The owner's manual and service manual for the '01 Integra say 105K miles or 7 years, whichever comes first, for the timing belt. In this case, both the mileage and the time have been exceeded.
There is no specific interval recommendation from Honda for replacing the water pump. However, most people (including me) recommend doing so because it's all the same work as the timing belt, so you may as well replace the water pump while you're doing the timing belt, so you don't have to re-do the same work later.
gl
timing belt, tensioner and water pump. the parts will cost you a whopping $120 maybe. compare that to what the dealer charges. I did the head gasket on mine while I was in there too ...
better safe than sorry.
Where are you getting those prices? Those parts together typically go for around $200 from an online parts dealer.
If that is really the price for timing belt + tensioner pulley + water pump, I would question if those are really brand new OEM parts.
From acuraautomotiveparts.org:
Timing belt 42.92
Tensioner pulley 56.12
Water pump 87.90 (includes gasket)
That's 186.94. I usually replace the tensioner spring also, at 3.32, so that's 190.26 + shipping.
If you got the same parts that you can find on http://oem.yoparts.com then I question if those are actually OEM. I highly suspect that they aren't.
Timing belt 42.92
$125 is substantially less than what the dealer pays Honda for the parts.
I used 2 of his kits, one on my B16 and one on my LS no problems, the spring actually comes in a honda bag, the belt is supposed to be an unmarked oem belt which I heard gates makes the honda belts not sure though, the tensioner and water pump were both made in japan, idk no if that means anything but I haven't had any issues with either kit. also you can get the honda branded stuff from him but Its a little more, also dealer mark up for honda is usaully like 110% which is twice what they pay and a little more. ... also its been like a year or so since I ordered anything from him so things may have changed
PS I am not affiliated with y0parts I have just had good experiences with Toms business
*edit* i didn't go thru the website I dealt directly with tom thru IM and phone b4 the really had much of a website
Timing belt 42.92
Timing belt 42.92
anyone got the parts numbers for all three of those items?
Check www.acuraautomotiveparts.org and order from them too if you're somewhat near their location in GA. I'm only 2 states away so I always order from there, takes 2 days w/ standard FedEx shipping.
The Delray Acura website shows part numbers as well as giving you good prices if you decide to order them there.
12341-PR3-000 (x1) Valve cover gasket - A good idea to replace this if it's seeping oil, hardened, or cracking.
12342-PT2-000 (x4) Spark plug tube O-ring - Again, a good idea to replace these while the valve cover is off.
12513-P72-003 (x1) Exhaust cam plug - Not really necessary unless it's leaking oil, but it is a common leak point.
14400-P72-014 (x1) Timing belt - OE is usually Unitta Sun or Gates; Contitech and Goodyear are good brands as well. The common aftermarket part number is TB247.
14510-P30-003 (x1) Timing belt tensioner - I recommend Koyo or NTN.
14516-PR4-A00 (x1) Tensioner spring
19200-P72-013 (x1) Water pump - OE is Yamada; I also recommend NPW. Do not use GMB.
31110-P72-004 (x1) Alternator belt - Bando and Mitsuboshi belts are best; this one is a 4PK-785.
31110-PV0-004 (x1) A/C compressor belt - Bando and Mitsuboshi belts are best; this one is a 4PK-840.
38942-P2K-T01 (x1) A/C belt idler pulley - Not necessary unless the bearing is rough or noisy. Honda only sells the complete pulley w/bearing, but the bearing itself is easily replaceable with a Timken 203FF.
56992-P72-004 (x1) Power steering pump belt - Bando and Mitsuboshi belts are best; this one is a 4PK-920.
90442-P30-000 (x8) Valve cover seal washer - Not really necessary unless they're seeping oil, hardened, or cracking.
91213-PR3-004 (x2) Camshaft seal - It's a good idea to replace these while you have the timing belt off.
You'll also need coolant (use the green stuff and mix 50/50, do not use Dexcool) and some Hondabond HT or Honda Ultra Flange Sealant.
You'll see in my notes that not all of these items may need replacement, but they are all easily accessible while you have everything apart for the job, so it's a good time to address them so that you don't have to tear it down again too soon. These are all items that I commonly see problems with when our shop does timing belt services.
^ thank you so much. ya i was already going to order a valve cover gasket and that so called cam seal/plug with the timing belt and water pump. thanks again for answering my question
Bling-blang shiny aluminum plug is not really needed.
