♪♫Fresh’86 big build up thread♫♪
Old Jan 12, 2009 | 08:22 PM
  #251
Fresh'86's Avatar
Default Re: ♪♫Fresh’86 big build up thread♫♪
Originally Posted by JVDE
so....... any updates?? :D
Yes, sorry I totally forgot about this page, I was focusing on the NWP4life build thread. I was under the impression HT was dead....
Originally Posted by DC5Chris209
Nice build man. I have always liked 4 doors
Thanks
Originally Posted by rhd-jon
to cold in canada ?
HELL YES! Tomorrow it's going to be -7*F here tomorrow :S
Old Jan 12, 2009 | 08:23 PM
  #252
Fresh'86's Avatar
Alright as for updates...I get a few new things...
First off, I bought my old shift linkage from the same douchebag who sold me the automatic shafts. Since I was buying an ITR shifter from a friend of mine, he threw in the linkages with it. Only bad thing about them is that they had a motor resting on one end, so it's bent up, I'll have to bang it out and bend it into shape. You can kind of tell from the pics. I included a side by side, as you can see the JDM ITR linkage is much beefier:
I was missing a few things for my head, so I borrowed them from another head that was just sitting around, and had to buy them back. Basically o-ring for the head, and a bolt. Also I was missing an alternator bolt, valve cover washer and acorn nut and a flywheel cover:
Picked up a 99-01 JDM ITR spark plug cover:
Also I was told that the new Honda tranny fluid is pretty good, still debating whether I should mix in a bottle of GM Synchromesh, or if I should just stick with Honda fluid only:
4 Gauge wire for the battery relocation:
Still waiting to get eyelets for the battery so I can hook it up.
Just a random fancy shmancy piece:
DEI heat wrap for my harness that will be running somewhat close to my exhaust for now, I'll be running it through my 02 sensor hole:
New bushings:
Originally I had a very beat up brass fitting for my vtec conversion oil line, so I grabbed some russels fittings...kinda shitty, I paid $45 for 3 fittings. I was told brass and aluminum can react with each other, and end up somehow fusing? So it's wise to run aluminum on all aluminum blocks:
(Before on the left, after on the right)
New Magnetic drain plug, it's pretty sweet. From what I can tell, it looks like a spoon replica piece:
Picked up an 'old school wide mirror' off streetwerks, I forgot to post up pics...so far here are the "teasers" I guess:
Still have to clean it and do something about the other side
I finally got my grill back from my friend, I'll most likely run the Domani grill (one on the very top) but I like to keep all 3 in case I want to change things up. Still need one more to have the complete set:
  #253
Fresh'86's Avatar
As for this weekend, here are the weekend updates -
How she sat Friday:
Started off with installing fittings to my new AN fuel lines:
A real bitch to do in the cold...trust me. It was around 5F on Saturday *cry*
This was bugging me, so I had to buy that tranny cover:
MUCH better:
Manifold was installed, and I didn't like the way the FPR was sitting, so I modified it, since it's adjustable:
And now, it's facing downwards:
So, installed the intake manifold, fuel rail, fuel lines, Fuel pressure gauge, FPR and TB:
Yes I know, I know, that header will be gone soon, it's just temporary...
New fuel setup:
I know people say don't have the fuel filter hang off the fuel rail, but I've seen it setup like that on plenty of cars, and I've never heard of issues before. Also, the line has some slack, so it pushes back on the filter. I'll keep checking it though, if anything starts to fail, I'll switch it up, I have spare fittings for it too and tons of line left.
The car...how it sits right now:
Old Jan 12, 2009 | 08:25 PM
  #254
Fresh'86's Avatar
Ok finally...update!!!
First off, thanks to Zach, aka rogueeg6 for making me these harness labels as per request. *hug*
I ended up finishing wrapping my harness in heat resistant wrap. As mentioned earlier, I didn't want to cut any holes in the firewall, so I'm going to run the harness under the subframe and under the car through the 02 sensor hole.
This new years break, the throttle cable was installed, along with the throttle cable bracket...which was slightly modified to fit, since it was from my B20 head, and the holes didn't exactly line up with the OBDI head, but no one can tell anymore
Also, a quick snap of my new clutch master resevoir I forgot to mention that I got:
(more on that later)
Also, the rad was installed:
Stock for now, will upgrade soon before the big power comes in.
Today I bought all the random hoses and clamps that I needed for coolant lines, etc:
And finally, I installed the header. I got a new heatsheld I will be repainting this week and have installed by next weekend. Should look brand new OEM once I'm done So check back next week for more updates. :bang:
Old Jan 12, 2009 | 08:30 PM
  #255
ek9 citrus's Avatar
Its looking great!
Old Jan 13, 2009 | 07:42 PM
  #256
suno's Avatar
I'm from Mississauga, hopefully I'll see you around! The car looks great, I love 1.6EL's.
Old Jan 14, 2009 | 03:57 PM
  #257
rhd-jon's Avatar
nice nice nice nice pimp
Old Jan 20, 2009 | 06:55 AM
  #258
Fresh'86's Avatar
Originally Posted by ek9 citrus
Its looking great!
Thanks citrus!
Sweet, I'm sure you will. Do you go to any of the local meets that the local car clubs host?
Correction: your the pimp, mr. RHD Are you going to be going to IA'09 this summer with Mitchell?
Old Jan 23, 2009 | 06:40 AM
  #259
be18see1's Avatar
I just read this from start to finish and I can say that I'm very impressed with your work! You pay great attention to detail, which is someone I will admit I sometimes skip over... Keep up the good work!
Old Jan 25, 2009 | 11:57 AM
  #260
oneoffaccord's Avatar
i thought you moved this to another site? looking good man...keep it up
Old Jan 25, 2009 | 12:56 PM
  #261
sde780's Avatar
Just read your whole thread, good work
Old Jan 26, 2009 | 09:53 AM
  #262
Fresh'86's Avatar
Default ♪♫Fresh’86 big build up thread♫♪
Thanks a lot, I guess I'm a little ****, and if I skip something over, I end up thinking about it, and it bugs me until it's perfect. Sometimes I'd want to, but I can't help it.
Yeah I have the build up on NWP4LIFE.COM as well, but I'll still post the updates here. I just don't like using HT as much anymore.
Thanks!
Old Jan 31, 2009 | 06:24 PM
  #263
scrooge's Avatar
Nooooooooooooooo!!!! *insert two birds pic one dead other saying no* your pics are down! I cant see anything .
Old Feb 1, 2009 | 05:12 PM
  #264
rhd-jon's Avatar
Pix down pix down
Old Feb 11, 2009 | 12:33 PM
  #265
Santys EK's Avatar
dude your car is ****ing unreal, cant wait to see it this year, even tho i dont known a honda anymore
Old Feb 11, 2009 | 01:51 PM
  #266
Fresh'86's Avatar
lol, there are nicer cars than this one on JDMR...I'm just trying something different I guess.
I can't believe you sold the hatch! What are you driving now?
Old Feb 11, 2009 | 01:57 PM
  #267
Fresh'86's Avatar
I got around to installing the rebar and headlight support beam, everything looks fresh with the new honda bolts:
Installed the new clip for the hood support rod:
Repainted my header heat shield to flat black, to cover up the temporary ugly headers:
The motor as it sits right now: (as you can see, the harness is being installed)
And finally, I got a new shift ****. I bought it off a friend who had it on his car for a long time, as you can tell it's a bit worn out. Special 10th anniversary edition, I'll have it restored and installed shortly.
  #268
Fresh'86's Avatar
This weekend a got a couple of things done...car is almost ready to start!!!
Firstly, here was my old brake line setup:
And now:
Full out EARLs brake line conversion from the master cylinder all the way to the calipers I have hardline running everywhere inside the cabin, and in the engine bay, and the hardline in the fenderwell to the stainless flexline. I can't wait to see what my brakes will feel like after this.
Then I finished the setup on the S2000 clutch master cylinder. Bore is 3/8th on S2000 and on my car, the only difference is that the resevoir is connected to the cylinder itself. I will need to adjust the pedal on the inside, but once that's done it will feel exactly the same.
*note: ran a 90* fitting here, but will be changing it up with a 120* fitting that's sitting right next to my car that I forgot about
As the car sits now. All that is left is the upper rad hose needs to be cut, and installed, the harness needs to be plugged up and I need to get that alternator on there. Once that is done, the engine will be running and I still have to finish off a few brake lines inside the cabin, as well as complete the harness for the headlights, fan, and horn.
Also, I found a distributor, I just need to figure out what car it's from, grab the cap and rotor for it and it's good to go for installation :bang:
Old Feb 11, 2009 | 03:29 PM
  #269
pingar's Avatar
looking good how far are you from being done?
Old Feb 11, 2009 | 04:57 PM
  #270
Fresh'86's Avatar
Not far at all, a few things left on my list of to-do's:
-Finish brake lines in the cabin
-assemble distributor; and install
-finish connecting wiring harness
-install stainless lines on 3 more corners
-install new boots to tie rods (current ones are ripped)
-assemble interior and front end
-polish intake and install (almost done)
-install tow hooks
-extended exhaust to bolt up to headers
-street tune
I'll also be repainting the front end, hood and trunk once all this is done. I got some new goodies going on the front end that I will reveal later on...
Old Feb 11, 2009 | 06:39 PM
  #271
phatboycrxhf's Avatar
sheesh,how the frick am i suppose to beat this ? lol ...awesome job bro.but please don't be mad when i smash into u with my beater in the summer ...why you might ask ,well cause than i can say my civic's nicer
hatechu lil bit now
Old Feb 12, 2009 | 04:05 PM
  #272
siblues's Avatar
this build is amazing man I love checking in to see the progress.I hope to see this thing in person at IA09
Old Feb 21, 2009 | 06:02 PM
  #273
Santys EK's Avatar
there isnt that many nice cars on jdmr, lots of half assers.
i can't believe i sold the hatch, but its good im actually saving alot of money now, i went an bought a 02 blazer zr2, so i can do some offroading
send me this site where you have the complete build of this thing
Old Feb 21, 2009 | 06:36 PM
  #274
t57b18's Avatar
looks good man , i just found this thread again .
Old Feb 21, 2009 | 06:46 PM
  #275
rhd-jon's Avatar
hope to see this thing this year
