Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
the best spring rate for road race....
Old Dec 11, 2007 | 08:33 PM
JDM.DEEBO's Avatar
Default the best spring rate for road race....
hey guys im new at rr and i have a 95 4dr integra...i and was wondering what spring rate you guys recommand me getting.....
thanks
Old Dec 11, 2007 | 09:38 PM
Lo-Buck EF's Avatar
800f/1200r
Old Dec 11, 2007 | 10:54 PM
JDM.DEEBO's Avatar
Default Re: (Lo-Buck EF)
why tho????
Old Dec 11, 2007 | 11:19 PM
Stinkycheezmonky's Avatar
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">800f/1200r</TD></TR></TABLE>
LOL!
Search, guy. This has been covered 10 gillion times.
Old Dec 11, 2007 | 11:21 PM
JDM.DEEBO's Avatar
Default Re: (Stinkycheezmonky)
i tryed
Old Dec 11, 2007 | 11:31 PM
Suspetise...
Default Re: (JDM.DEEBO)
» Search Results
Your search for spring rate returned 84 results.
You didn't try hard enough. Select "archives" and RR/Autox as the specific forum.
Old Dec 12, 2007 | 06:42 AM
Baggy Spandex's Avatar
Definitely search.
"Best" is a relative term also.
Old Dec 12, 2007 | 07:15 AM
Lo-Buck EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.DEEBO &raquo;</TD></TR><TR><TD CLASS="quote">why tho????</TD></TR></TABLE>
because i said so.
Old Dec 12, 2007 | 07:20 AM
TPB's Avatar
TPB
I suggest you pick the shocks and springs together because most shocks off the shelf will not be able to handle the high spring rates used for RR. You'll either need to get the shocks revalved or invest in high end shocks that can handle most high spring rates (up to 2,000 lbs) if you're serious about RR.
Old Dec 12, 2007 | 08:46 AM
6spdKEG's Avatar
Default Re: (TPB)
for the newb
Some links I have saved under my name
A thread I started a while back to talk about the rear biased setup
https://honda-tech.com/zerothread?id=1915173
Some good talk about dampers, spring rates, tires.. .
https://honda-tech.com/zerothread?id=1746209
Don't forget brakes!
https://honda-tech.com/zerothread?id=1764407
OKAY! LET THIS THREAD DIE PLEASE!!!!!
Old Dec 12, 2007 | 09:23 AM
Crazydave's Avatar
Default Re: (6spdKEG)
I am having a lot of fun with my civic at the track on 450/600 with koni yellows.
I do want higher rates though for when I start racing.. or can afford some revalved shocks.
Old Dec 12, 2007 | 09:40 AM
thawley's Avatar
Default Re: (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">I am having a lot of fun with my civic at the track on 450/600 with koni yellows.</TD></TR></TABLE>
That's what I started with and it was bitchen. Just can't bring myself to sell those springs...
Old Dec 12, 2007 | 09:54 AM
solo-x's Avatar
The best spring rates are the softest spring rate that keeps chassis roll within a reasonable range, minimize chassis bottoming, don't coil bind, and distribute lateral load transfer properly between the front and rear axles. They also need to inspire confidence in the driver. The actual rate of the spring will be different for each driver, each car, each driving style, and each type of driving. Care to revise your question with one that is a little more specific? For example:
My XYZ car is going to be used for X type of racing on Y type of tire. It has Z amount of suspension travel, weighs M lbs. with Q weight distribution. The cg height is W and the shocks are brand K. Any suggestions for a good starting spring rate? I was thinking XXXlbs/in...
Old Dec 12, 2007 | 10:47 AM
kb58's Avatar
Banned
Default Re: (solo-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote">
My XYZ car is going to be used for X type of racing on Y type of tire. It has Z amount of suspension travel, weighs M lbs. with Q weight distribution. The cg height is W and the shocks are brand K. Any suggestions for a good starting spring rate? I was thinking XXXlbs/in...</TD></TR></TABLE>
Exactly, and to make it worse, then asking, "so, what's the answer for R?" The point is, the "best" value is what you like the most - it's subjective. Use the numbers in the above posts as a starting point and go from there. It's like worrying that you like brunettes while other people like blondes. As long as you're happy, don't worry about them.
Old Dec 12, 2007 | 10:48 AM
6spdKEG's Avatar
650/800+ with a rear ITR bar and go from there.. .
From experience I feel that anything less than 650s on a 2400lb race weight setup on 225 r comps is not going to be enough rate.. .
search search search and experiment!
Old Dec 12, 2007 | 11:33 AM
Crazydave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote">The best spring rates are the softest spring rate that keeps chassis roll within a reasonable range, minimize chassis bottoming, don't coil bind, and distribute lateral load transfer properly between the front and rear axles. They also need to inspire confidence in the driver. The actual rate of the spring will be different for each driver, each car, each driving style, and each type of driving. Care to revise your question with one that is a little more specific? For example:
Jeez Solo-x.... is there a letter of the alphabet that you didn't use as a variable....
not every driver is an automotive engineer.
This guy is probablly looking for somewhere to start.
So lets look again at his question...
thanks </TD></TR></TABLE>
If you are new... try learning how to drive your car on stock springs.
You can throw all the money and parts you want at a car... doesn't mean you are going to be any faster.
that being said....
I found that upgrading my hatch from stock springs to 450/600 was very favorable for the handling of my EG.
Body roll and understeer has significantly reduced but not to a point where I feel out of control.
I also have quite a bit of track and auto-x experience before I did this.
Is 450/600 the best for me and that car... no.. I would like to try 600/800 but I would like to get some more seat time, and some revalved shocks before I do that.
Old Dec 12, 2007 | 12:32 PM
granracing's Avatar
I started off with 400 / 600 with my Prelude and did just fine with it, but now use 750 / 600.
When you say that you're new at rr, have you done any HPDEs yet? Is the set-up you're looking for going to be used at HPDEs or are you starting competitive wheel-to-wheel racing? If it's for HPDEs, as said earlier stick with stock.
Old Dec 12, 2007 | 01:15 PM
EdoMoto's Avatar
Default Re: (granracing)
I started with 450/600 with Tokico Illuminas and Now 700/1000 with Koni 2812's.
I love the way the car feels now.
Edo
Old Dec 12, 2007 | 02:57 PM
TunerN00b's Avatar
that being said....
I agree with starting stock.
I started with my GSR stock, on rt-615 Azenis. And while it was an understeering pig, it was a fun and educational experience. It was also forgiving.
My 2nd HPDE, I had a Comptech rear swaybar, and went faster as I got more comfortable.
My 3rd HPDE, I had Konis and 400/400 rates as well, and dumped the car off the inside of the track sideways at 90mph, because I failed to floor the throttle after entering a turn a little hot.
Granted, I was also running STS class auto-x as well in this car, and probably did 4 events between each of these HPDEs, so I had a little more experience than just the track. But be careful about making the car looser than the driver is ready for.
Old Dec 12, 2007 | 08:42 PM
Lo-Buck EF's Avatar
you guys suck. i wanted to see how long whatever shocks he has would last with 1200in/lb rear springs. and how many times he'd loop it in one session.
Old Dec 13, 2007 | 02:13 AM
Eyal 951's Avatar
lol I hate these threads cause they make me want to upgrade my 400/500 to 450/600.
Who wants to trade?
OP, it also depends on the weight of the car. 400/500 has been very good to me in a CX hatch. (2100 with no weight reduction)
Old Dec 13, 2007 | 11:02 AM
JDM.DEEBO's Avatar
THANKS
Old Dec 13, 2007 | 11:03 AM
JDM.DEEBO's Avatar
Default Re: (kb58)
THANKS
Old Dec 14, 2007 | 07:02 AM
turboteener's Avatar
Banned
Beleive it or not on a smooth track you can run underdamped and not be as slow as you would expect. The Spec Miata guys do it all the time. I have run 700 and 800lb springs with OS Koni Yellows. It is not hard to drive and yes, I am sure I could go faster with the right shocks. I am getting some shortly.
LBBP R
Honda S2000
Jul 31, 2005 10:22 PM
EFin' Kyle
Jan 30, 2005 03:29 PM
slowls
May 18, 2004 01:28 PM
Carlito Brigante
11
Apr 17, 2004 07:10 PM
combustion
Oct 23, 2003 01:14 PM
