interchangeable coil for B16?
Old Jul 29, 2004 | 08:22 PM
goforbroke's Avatar
MEAT PATTY
Default interchangeable coil for B16?
I think my coil is bad, I tested it with a ohmeter and the readings were low. But what coil can I replace it with ls or d-series one. No solid answers were found in archives, so I figured someone had to know. This is for a b16 by the way. thanks.
Old Jul 29, 2004 | 08:36 PM
krazie1's Avatar
BANNED
Default Re: interchangeable coil for B16? (goforbroke)
yes I believe u can use the LS but not the d series
maybe a weaker spark since it maybe a smaller engine
but I maybe wrong u know
Old Jul 29, 2004 | 08:44 PM
eda6's Avatar
Default Re: interchangeable coil for B16? (krazie1)
A little off subject but when my ignitor went out i got on from a da teg.
You should be fine if you get a teg one.
Sorry man i know you want a solid answer.
can you compare the two side by side?
Old Jul 30, 2004 | 03:06 AM
goforbroke's Avatar
MEAT PATTY
Default Re: interchangeable coil for B16? (eda6 hb)
Nope, I didn't get to compare to the two side by side. Anyone else? I've replaced ignitors numerous times, but now the coil went. Its one of the very few crappy parts on a honda the distrubutor.
Old Jul 30, 2004 | 04:53 AM
90crxsib16's Avatar
For testing/diagnosing purposes, I swapped my igniter and coil from my D16A6 Dizzy to my B16 Dizzy. It ran, I didn't drive it around or rev it too high though. Worth a shot if you need to save some cash tho....
Old Jul 31, 2004 | 06:05 AM
goforbroke's Avatar
MEAT PATTY
Default Re: interchangeable coil for B16? (90crxsib16)
The ls one worked fellows. It had the same part # on it as the stock b16. Cost me $80 though.
Old Jul 31, 2004 | 07:43 AM
granturismonut's Avatar
sorry about the timing, too litle too late, but my coil on my b16 went out, used the one from the old d16z6, had same #'s stamped on them, works like a charm. maybe this will help someone in the future.....
Old Jul 31, 2004 | 08:18 AM
kid-honda's Avatar
I have used A6 coils numerous times with no problems.
Old Jul 31, 2004 | 08:30 AM
wtsexton's Avatar
D-series coil is the exact same one.
I have a d-series coil and ignitor in my b16a with no issues.
Old Jul 31, 2004 | 11:10 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (wtsexton)
does any one know if there is a after-markrt one like a MSD that will fit the stock ignition coil?
Old Jul 31, 2004 | 01:14 PM
DieMaster's Avatar
Default Re: (JC18)
bump
allnaturalb16
Dec 12, 2007 12:03 PM
Damills
May 6, 2007 06:59 PM
Boostedb20EH2
10
May 3, 2007 07:06 AM
BiTurboCiv
Nov 7, 2004 08:28 AM
