Msd ignition set up
Msd ignition set up
Right now i have a b20 with a procap dizzy and blaster2 and such, with the ignition module (couldnt tell you exactly which one). I can check that out in alittle bit. But when looking for a new dizzy from them (I am putting a b16 head on it). It lists different modules for different things, their website makes it quite confusing actually. Can i use this new dizzy on my old module or do i have to get different one?
Re: Msd ignition set up (jfruauff)
the cap will wok on any b series it's just one mounting screw is different. my ls cap fits a b16 except for one screw. so that's what i'm guessing from
Re: Msd ignition set up (r1ch1e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e »</TD></TR><TR><TD CLASS="quote">the cap will wok on any b series it's just one mounting screw is different. my ls cap fits a b16 except for one screw. so that's what i'm guessing from</TD></TR></TABLE>
So your saying i can use the one off of my b20? If so thats great.. i wont buy a new one.
NASIOC.com
Re: Msd ignition set up (Boostedb20EH2)
Ok, so your asking if you remove the coil from the inside of the b16 dizzy will it still work with your blaster two coil?
If your talking about taking the whole dizzy off the b20 yes you will have to cut a leg off the dizzy and only 1 bolt will go in. This works and there really wont be any problems i have done it a few times. Just take the msd cap off the b20 dizzy and put it on the b16 dizzy
