ECU AND ABS CODES HERE!
Old 10-20-2011, 01:16 PM
  #76
jrsc_integra's Avatar
Default Re: ECU AND ABS CODES HERE!
i have codes 14, 16, 32, and 42 for ABS codes for 98 integra. Does anyone know how to fix these? thanks
Old 06-21-2012, 10:28 PM
  #77
plokijuhyg's Avatar
Anyone know how to fix the P1298 code? (ELD)
Old 09-23-2012, 10:47 PM
  #78
Mikey747's Avatar
Thanks Rory,
I've beeen looking for these for a while on the net with mixed varying results so I decided to become a member here. Great information.
I had a P0847 code on my Odyssey 2005 4cyl model. Which would cause the D on the dash to flash 2x second or so evenly. When engine turned off then restarted it resets but may flash again later in the day when driving.
The code points to a faulty 3rd Pressure Switch in the trans, however how does it know there is not a problem with the actual pressure instead inside the trans ?
Cheers Mike
Old 09-26-2012, 07:57 PM
  #79
Mikey747's Avatar
When one gets a Catalytic Converter Efficiency code.
Can someone explain the Catalytic Convert efficiency theory.
Does the Cat conv use two sensors in and out and what gases do they sense.
Cheers
Old 09-29-2012, 02:18 AM
  #80
Mikey747's Avatar
Default BEST SOFTWARE to read ECU via OBDII ?
Hi all,
I'm using a registered version of PCSCAN to read the OBDII and although it reads and clears the fault codes it reads little else inc the dashboard which seems eratic at best and also the Bluetooth connection keeps disconnecting and reconnecting despite being only a seat away in the car.
The software needs to be able to read the Bluetooth com port 41 on my Toshiba Qosmio X770 Win 7 64bit laptop.
Some programs are for serial port PC's only and only go up to port 8 or less.
Maybe someone can post the software HONDA use for OBDII Bluetooth version here.
Cheers Mike
Old 09-29-2012, 02:28 AM
  #81
mathewbyrne's Avatar
very nice write up, and specific. A+ to you sir.
Old 10-27-2012, 12:47 PM
  #82
DeCePtEgRa's Avatar
Why do so many members ask questions that are covered in this thread lol
Old 10-29-2012, 12:47 AM
  #83
Scratchoz's Avatar
This was really convenient, thanks.
Old 10-29-2012, 01:21 PM
  #84
Mikey747's Avatar
Can any one suggest a good program that works with a bluetooth OBDII reliably for all data.
The Demo program is crap and the others that came with it are for serial port OBDII's. No good as my Bluetooth port is port 41 on my laptop. I got a blue tooth one as modern laptops dont have a serial port.
Cheers Mike
Old 02-23-2013, 03:23 PM
  #85
Mully31's Avatar
getting a cel 17 vss but speedo works any help?
Old 02-25-2013, 08:14 AM
  #86
dwayne cool's Avatar
Hey guys I have a 98 integra and my only error code. Is 13 and I dnt knw what to do to fix this error, it says(open/short to body ground/short to power),can anyone help me
Old 07-08-2013, 04:19 AM
  #87
Bonestock98GS's Avatar
I have a turbo gsr with b16 head it's been sitting for few months and when I first started it to check for leaks it ran perfect. I went to crank it last weekend it had CEL and it ran like a wrx. I have error 12 which is egr lift valve malfunction. CAN SOMEONE HELP ME WITH THIS PROBLEM PLEASE ITS KILLING ME
Old 08-07-2013, 07:27 PM
  #88
oopsyclone's Avatar
hi, useful info!
could you be so kind to post the coding principle about the autoparts of exhaust system?
eg. 18308-TBO-H010-220
what does it mean by each code number?
so much appreciated with your kind help~
Old 09-23-2013, 08:35 AM
  #89
JoHudson's Avatar
Default Re: Codes for 2000 Honda Pilot - T1295
We recently acquired a 2000 Honda Pilot. It brought up a low power alert yesterday, with reduced power and throttle to the floor went no where. Had a friends code reader that shows a 1295 code. Is this the throttle sensor? Where can I find info about this code and the sensor(s)? Any help you could give would be greatly appreciated!
Old 09-23-2013, 12:47 PM
  #90
B_Swapped93's Avatar
Wrong section post this in the ridgeline/oddessy/MDX/pilot section. but it's known as the TPS and can be found on the side of the throttle body 45$ part.
Old 09-25-2013, 09:41 PM
  #91
xLokei360's Avatar
Mine only flashes once, and thats when I turn the ignition all the way to the right one. And when i turn it back left it flashes once. Any idea?
Old 10-17-2013, 08:57 PM
  #92
5honda's Avatar
thanks for posting. years have gone by, but its still a top one!
Old 10-22-2013, 04:32 AM
  #93
JU57FL1P's Avatar
Hi,
Does anyone know where is the fail safe relay (code 54) for EK3 civic, sedan 99' ? I have been searching, but can't find it :/
Old 06-15-2014, 07:33 PM
  #94
Teggy_Newb428's Avatar
Icon6 Re: ECU AND ABS CODES HERE!
I have a 1996 Acura Integra LS Coupe bone stock.
the only 2 Codes that pop up and I tried on 3 different ODBII Code readers, and they are; P0700 & P1791, Anyone know how to get them fixed? Please Help a Fellow teggy user out.
Thanks.
Old 08-16-2014, 05:33 PM
  #95
Munkeyjdm86's Avatar
Very helpful but 1 quick question I got a 94 gsr turbo and im getting cel 11 I dont see that one on the list any info greatly appreciated
Old 08-20-2014, 06:26 PM
  #96
mcgalliardt20's Avatar
Im in serious need of help. I bought a new ignition switch for my 96 acura integra. An it still want start. My starter is still good i checked it. I have no clue what to look for
Old 08-23-2014, 08:53 AM
  #97
fyah2k5's Avatar
Thanks for these. I'll definitely be refering back to this thread, every now and then. I'm also getting an SRS light. Any idea what I should do with that?
I get an intermittent ABS light in my '96 JDM SIR-G. When it comes on, just turn the car off, restart and most times it doesnt come back. Previous owner said the ABS modulalor ran out of brake fluid once, he started seeing the CEL after that.
Old 09-28-2014, 05:17 AM
  #98
Will Agus's Avatar
hai,everybody.
i got problem with my car honda odyssey 2010 and my abs code come out 61-01( battery voltage low),62-01(battery voltage high), 83-01(ecm relation failure). pls anybody can help resolve my problem?
Old 04-12-2015, 02:41 AM
  #99
samaka2002's Avatar
Dear All I have Honda HRV 2002 i have error code 55 any one know it ?
Old 08-14-2015, 12:24 PM
  #100
Spudd_Civic's Avatar
So I have a 91 honda hatchback with ECU code 13 and I was just wondering if there is a way to test the Baro (atmospheric pressure sensor).
Quick Reply: ECU AND ABS CODES HERE!
