ECU AND ABS CODES HERE!
Old 05-14-2006, 06:36 PM
  #26
DC2 Mang's Avatar
Default Re: ECU AND ABS CODES HERE! (Rory Breaker)
very nice info
Old 07-12-2006, 03:56 PM
  #27
escape2me's Avatar
Default Re: ECU AND ABS CODES HERE! (DC2 Mang)
Just thought id add this link to further assist with actual pics for people doin this for the first time to see what it looks like....http://www.team-integra.net/se...ID=34
Old 09-27-2006, 05:00 PM
  #28
bigrballerz's Avatar
Thats funny cuz I couldn't find it ....so someone must have cut it off !
Old 10-17-2006, 08:02 AM
  #29
Speed94's Avatar
Default Re: (bigrballerz)
subscribed
Old 10-17-2006, 08:19 AM
  #30
huevosrancheros's Avatar
NExt level son, love it!!!
Old 12-19-2006, 08:31 AM
  #31
Bfreeman's Avatar
Default Re: ECU AND ABS CODES HERE! (iH8RICERZ)
lots of useful info
Old 02-07-2007, 07:53 AM
  #32
puregroove's Avatar
Thanks for these.
Old 03-21-2007, 01:41 PM
  #33
nWilk666's Avatar
Default Re: ECU AND ABS CODES HERE! (puregroove)
how do you read the abs codes?
Old 06-10-2007, 06:18 AM
  #34
Legal Bill's Avatar
Default Re: ECU AND ABS CODES HERE! (nWilk666)
I think it describes how to read the ABS codes about mid way down the list from what I just read.
My question: Once you make a repair, will the light go out by itself if you have fixed the problem, or do you need to reset the light some how, and then see if it comes back on to find out that you did not fix the problem?
Old 06-10-2007, 07:43 AM
  #35
Daisy... Daisy...
Dogginator's Avatar
Default Re: ECU AND ABS CODES HERE! (Legal Bill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legal Bill &raquo;</TD></TR><TR><TD CLASS="quote">I think it describes how to read the ABS codes about mid way down the list from what I just read.
My question: Once you make a repair, will the light go out by itself if you have fixed the problem, or do you need to reset the light some how, and then see if it comes back on to find out that you did not fix the problem? </TD></TR></TABLE>
The ABS light will not illuminate again unless another fault condition is detected. Pull the ABS fuses in the underhood fuse box by the ABS unit to clear the codes. The ABS computer stores the 3 most recent fault codes.
Old 06-11-2007, 07:03 AM
  #36
Legal Bill's Avatar
Default Re: ECU AND ABS CODES HERE! (Dogginator)
Thanks for the response.
Old 06-21-2007, 06:06 PM
  #37
K20A3T's Avatar
Modified by K20A3T at 12:25 AM 6/23/2007
Old 07-02-2007, 04:15 PM
  #38
BoltonGSR's Avatar
Default Re: ECU AND ABS CODES HERE! (Honduh Chicken)
Hey, one of the codes is wrong i think...
Code 91 should be code92
Old 07-03-2007, 09:38 PM
  #39
gsrmike7's Avatar
Default Re: ECU AND ABS CODES HERE! (BoltonGSR)
nice post
Old 11-01-2007, 03:49 PM
  #40
peAches yO's Avatar
Default Re: ECU AND ABS CODES HERE! (gsrmike7)
&lt;3 This just helped me so much
Old 11-30-2007, 02:41 PM
  #41
JDM90Sleeper's Avatar
Default Re: ECU AND ABS CODES HERE! (peAches yO)
Old 12-26-2007, 12:33 PM
  #42
terplaygroun_dc2's Avatar
how do i pull the blue connector out of the green thing? having trouble, please help
Old 01-23-2008, 09:02 AM
  #43
gen2integra2001's Avatar
nicce to keep this list..youll never know when you will need it
Old 02-01-2008, 01:36 PM
  #44
VNMCRX's Avatar
Ok i have an 89 crx exclusive, does anyone know the abs codes for this year? it started off as a fuse and then the cv joint sensors which have been both replaced (had to take it to honda themselfs but cost me more than my pay cheque to get it fixed ), and now the light goes off but after about a min and a half of driving down the road the light comes back on, my abs computer in the boot as an LED in a little glass hole, when i put the ignition to on, it flashes 3 times all about 1 second long with about a 2 second pause, and then it just stops and doesnt flash again, can anyone help?
Old 03-23-2008, 10:45 AM
  #45
Thorgs's Avatar
Default Re: (VNMCRX)
This is weird. My blue connector has 3 wires going into it. Brown, blue, & yellow wire. Anyone else have this?
edit: nevermind. It was tucked up under the dash more and not in the green casing. I have 2 plugs.
Modified by Thorgs at 12:02 PM 3/23/2008
Old 03-09-2009, 07:01 PM
  #46
Js-TM's Avatar
Originally Posted by dsav4shawn
Could someone provide me a picture of exactly where it is??? That is where to jump?
Thanks
Old 04-19-2009, 09:35 PM
  #47
VizionTeggy's Avatar
when jumped my CEL stays on is this a code 0?????
Old 04-29-2009, 03:26 PM
  #48
msb1510's Avatar
Hi, I need help please.
I just bought a 94 Integra LS "mid swap" B16A, OBDI, P30 ECU manual trans.
Here is the problem, it will not start. It turns over at the normal rate. I have fuel psi and pulse at the injectors, their is just no spark. I have tried a known working dist and still nothing. There is power to the dist but no signal from the ECU.
I tested for cel and got 20, I think that is for ELD, not sure if info is correct. In my Haynes manual, it shows pix but I cannot make out where the test point is??
I would be very grateful for any help. I have been messing with it for almost 2 weeks, on and off, when I can. Thank you
Old 05-23-2009, 01:15 PM
  #49
250r king's Avatar
was it a auto before the swap
Old 07-17-2009, 02:37 PM
  #50
rhd-jon's Avatar
i got a code 8 on my car need to know any info on wat it could be and how do i fix the problem i have a 95 eg6 sir p30 ecu obd1
Quick Reply: ECU AND ABS CODES HERE!
