oil pan torque specs???
Old 08-05-2004, 12:39 PM
hugh_jazz_sponer's Avatar
Default oil pan torque specs???
anyone know the ft./lbs I need to torque the oil pan bolts to on a D16A6? I searched and saw a couple of guesses but nothing definite. I am waiting for my helms to arrive but i would like to take care of this in the next day or two. i think it's between 9-15 lbs or so.
thanks
Old 08-05-2004, 12:48 PM
eda6's Avatar
Default Re: oil pan torque specs??? (hugh_jazz_sponer)
9 ft.lbs
Old 08-05-2004, 12:54 PM
MR5 EF9's Avatar
For a D16A6 apply liquid gasket (hondaBOND or like product) to the 4 points where the pans dips for the crank, apply between the gasket and oil pan
tighten bolts and nuts finger tight at six points starting in the center (number 1) above the drain plug, directly across, then both ends (left and right side)by the dips for the crank.
tighten all bolts and nuts starting from bolt 1 (number 1) clockwise in three steps
Torque 14N.m (1.4 kg-m, or 10 lb-ft)
Excessive tightening can casue distortion or the oil pan gasket and leakage
i use a 1/4 in rachet with a 6 inch extension and a deep 1/4 10 mm 6 point socket
does the trip every time, also i use a small amount of GASKASINCH on the gasket itself and oil pan ensures a seal
EK9JSPEC
04-20-2012 01:06 AM
Rhood
02-07-2007 05:30 PM
4gludy
05-23-2006 07:08 PM
baphomet
12-19-2005 01:41 PM
DjTrex
09-24-2005 01:40 PM
Quick Reply: oil pan torque specs???
