The end all DIY Side Marker Post
Old 03-27-2004, 05:31 PM
Jaysun's Avatar
Default The end all DIY Side Marker Post
Ok, yes this has been covered 100x but when searching I found no complete write up so i thought i would do one.
This thread is not for opinions on my car
This thread is not for opinions on my choice of lights
This thread is not a what should i do to my car thread
It is to help people who might do this...if you don't need it or like it. plz don't waste anyones time by adding a useless reply.
THANKS!
Ok Started by pullin into the garage...
Here's the side markers and the image i used for measurements (thanks to whoever first made it )
As you can see my markers go in to the fender with a round piece, so i adjusted my measurements so that the marker itself would still fit in the same position as stock ones would.
The bottom part of the marker should be 2 1/4" up from the side molding and the very left should be 15/16" of an inch from the door jam. I used a pencil to mark the cutpoint. (these measurements are for jdm or close to look you can really put them wherever you want, this is where i wanted mine)
After measuring I put the casing against the fender to see if it was where i wanted.
Then i unattached part of my wheel well molding
Then i made a slight dimple on the fender with a point and hammer...VERY SLIGHT, just enough so the drill would stay in place. The first hole was very small just enought to allow the bigger drill (made for cutting metal)
Big drill
Hole
File down so there are no rough edges...
Check to see fitment
Good, ok so now I needed to put a lead wire through the hole i wanted the wires to come into the engine bay to the wheel well, this took some try's but you'll get it, just stick your hand up and try to grab it.
Lead wire exit
Tape your sidemarkers wires to the end of the lead wire through your hole, and carefully pull the lead wire back through to the engine bay. Now this is the corner lamp bulb harness you need to get...just unhook the bulb from the other end.
Cut the harness off, but be sure to leave 1-2inches of wire still connected to the harness!!! I didn't and it was a pain later.
Next your going to connect butt connectors to the wires coming from the harness...as you can see i cut mine too short and it was a pita.
extend the wired from the butt connector...now i have 3 wires that have power coming from the car, i have the 2 wires from the sidemarker and i have the 3 wires to the corner bulb harness. Now you have 2 options.
wire the side marker to the red and green wires and the light will be on with the corners and blink when turning.
or wire them to the red and black, and it will only be on with the use your turn signals.
I chose option one, cause that's what i wanted. i don't care if it's jdm enough, thats how i wanted em
Use wire caps and screw the 2 sets of three wires together, and the 1 set of two wires together.
I didn't color code my wire extensions, so it may look off
And ding your done with one side!
re-attached your wheel wells and start on the other side...
If this helps 1 person it's worth the hour spent writing this and resizing the images and all that ****...
I like em!
Old 03-27-2004, 05:33 PM
Andres-eh2's Avatar
nice writeup, will help me soon
Old 03-27-2004, 05:38 PM
Mike_C's Avatar
Did you Dad drill the hole for you?
Old 03-27-2004, 05:39 PM
Jaysun's Avatar
Default Re: (MichaelJComputer)
Grandpa...he's a professional electrition(SP)
So i trusted him with his drill more then me
Old 03-27-2004, 05:47 PM
Kid1320's Avatar
sweet, got grandpa helping on the car
Old 03-27-2004, 05:48 PM
MissLady's Avatar
Default Re: (QuikJaysun)
great write up! may be eventually my bf will really hook his up
Jaysun's Avatar
Default Re: (Kid1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 &raquo;</TD></TR><TR><TD CLASS="quote">sweet, got grandpa helping on the car </TD></TR></TABLE>
yeah lol
Modified by QuikJaysun at 9:19 PM 4/23/2004
Old 03-27-2004, 05:49 PM
Jaysun's Avatar
Default Re: (MissLady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MissLady &raquo;</TD></TR><TR><TD CLASS="quote">great write up! may be eventually my bf will really hook his up </TD></TR></TABLE>
thx! there were a bunch of little write ups already but none that really covered the wiring with pics...
If anyone has questions regarding the project please ask
Old 03-27-2004, 05:53 PM
PatrickGSR94's Avatar
Well that works for those types of sidemarkers (single round hole w/ 2 screws) but not for OEM or OEM-style sidemarkers, so it's not end all.
And I think you should flip them over so the long end of the beveled surface faces forward
Old 03-27-2004, 05:57 PM
Jaysun's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Well that works for those types of sidemarkers (single round hole w/ 2 screws) but not for OEM or OEM-style sidemarkers, so it's not end all.
And I think you should flip them over so the long end of the beveled surface faces forward </TD></TR></TABLE>
It still covers the wiring with pics...
anyone can figure out how to fit the appropriate marker, it's the wiring most have problems with...and if i'm not mistaken, the oem 3 wire ones, will just all 3 wire up where i only used 2.
Old 03-27-2004, 06:01 PM
OEM sidemarkers are only 2 wire, they use the same 194 bulbs that your sidemarkers use.
Old 03-27-2004, 06:14 PM
slowhatch4now's Avatar
get ambers
ahh
peace
Old 03-27-2004, 06:15 PM
Jaysun's Avatar
Default Re: (slowhatch4now)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhatch4now &raquo;</TD></TR><TR><TD CLASS="quote">get ambers
ahh
peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun &raquo;</TD></TR><TR><TD CLASS="quote">This thread is not for opinions on my choice of lights
If you haven't figured it out, i couldn't give a **** less that you think i need ambers
Modified by QuikJaysun at 3:36 AM 3/28/2004
Old 03-27-2004, 06:35 PM
igo4bmx's Avatar
good write up man!!
remember this is honda-TECH
not honda-opinion
Old 03-27-2004, 06:49 PM
stockegsix's Avatar
Default Re: The end all DIY Side Marker Post (QuikJaysun)
if you use the oem eg6 sidemarkers, you installl it differently, dremel is your freind
Old 03-27-2004, 07:11 PM
Street Ghost's Avatar
Default Re: The end all DIY Side Marker Post (stockegsix)
I recognize that image/template you used. _randeee is his H-T username.
Good job on the DIY.
Old 03-27-2004, 07:14 PM
5STAR3's Avatar
hey those look familiar
glad you like them
Old 03-27-2004, 07:26 PM
Ass_Clown's Avatar
Default Re: The end all DIY Side Marker Post (envision2teg)
Good write up Jason. Look like EF style sidemarkers. Goood idea to go with clear ones. Go well with your headlights and corners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">And I think you should flip them over so the long end of the beveled surface faces forward </TD></TR></TABLE>
Old 03-27-2004, 07:33 PM
undertheradar's Avatar
Default Re: The end all DIY Side Marker Post (Hatchcrap Ownz J0o)
Looks good. I had those same markers before I put in my EK9's. Good thing is, if you ever decide to change em, most of the hole is already cut out and the outside of those markers are just about tye size of the JDM's. Nice How-To...you're right, most people can't figure out the wiring.
Old 03-28-2004, 07:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockegsix &raquo;</TD></TR><TR><TD CLASS="quote">if you use the oem eg6 sidemarkers, you installl it differently, dremel is your freind</TD></TR></TABLE>
Hell no, the dremel is evil when cutting holes for OEM sidemarkers. A metal nibbler is your friend, either hand-operated from Radio Shack or air-powered, a metal nibbler is actually faster, easier, safer, more precise, less messy, and WAY less noisy than a Dremel and those evil cutting wheels.
Old 03-28-2004, 08:10 AM
tominos's Avatar
Default Re: The end all DIY Side Marker Post (PatrickGSR94)
can we get a pic of this metal nibbler? i've never seen one.
and jaysun, i think you need to put something on the exposed metal so it doesn't rust, ie nail polish works good.
Old 03-28-2004, 08:23 AM
EK MONEY's Avatar
good writeup man
Old 03-28-2004, 08:36 AM
elwood's Avatar
Not making fun of your write up, its nice to see
any kind of good write up.
But are those wire nutts permanint? I know thats
good for house wire, but automotive is a hole different deal,
and I think those will shake loose after a while.
Old 03-28-2004, 10:33 AM
Ricey McRicerton's Avatar
Default Re: (elwood)
I have wirenuts holding some of my WB02/stock 02 sensor stuff together. Been that way for close to a year with no problems whatsoever.
Old 03-28-2004, 10:35 AM
skip.two's Avatar
nice write-up
Quick Reply: The end all DIY Side Marker Post
