HELP:Piece of spark plug wire stuck around spark plug
Old 03-11-2004, 12:38 PM
PSU
formerly DxHatchback
PSU's Avatar
Default HELP:Piece of spark plug wire stuck around spark plug
i bought cheap @SS accel plug wires before reviewing them and now a the black peice from the tip of the plug wire is stuck around the spark plug and its impossible to get out.
please help
Old 03-11-2004, 12:41 PM
Brewer's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (DxHatchback)
Can we just point and laugh? Hahaha
Old 03-11-2004, 12:42 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">i bought cheap @SS accel plug wires before reviewing them and now a the black peice from the tip of the plug wire is stuck around the spark plug and its impossible to get out.
please help </TD></TR></TABLE>
A piece from the wire is stuck on the plug? Have you tried using needle nose pliers? Can you snap some pics of it?
PSU
PSU's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (BrewerHatch)
thanks for the dumb, useless reply
Old 03-11-2004, 12:43 PM
PSU
PSU's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (EL Vap133)
the tip around the end of the plug wire came off and is stuck on the spark plug, needle nose pliers are too short <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
A piece from the wire is stuck on the plug? Have you tried using needle nose pliers? Can you snap some pics of it?</TD></TR></TABLE>
Old 03-11-2004, 12:44 PM
Filthy Focker!'s Avatar
With all honesty, throw the spark plug away. They cost a buck or 2 and you will end up buying new plug wires anyway... So it's not worth it..
fs
Old 03-11-2004, 12:46 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">the tip around the end of the plug wire came off and is stuck on the spark plug, needle nose pliers are too short </TD></TR></TABLE>
They sell some long *** needle nose pliers, or maybe you can borrow some. Can you still fit the socket over the plug to take the plug out?
Old 03-11-2004, 12:48 PM
Two_K Si's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (filthy_shovel)
a deep socket wont fit over it?
Old 03-11-2004, 01:01 PM
PSU
PSU's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (Two_K Si)
the black rubber from the plug wire is stuck on the spark plug so no deep socket will fit over it
Old 03-11-2004, 01:06 PM
TurboBumblBee's Avatar
use a wire coat hanger and pull it up.. happened to a friends car and i got it out in about 5 min
PSU
PSU's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (hybrid94Si)
tried that and a flat head screwdriver, no luck
that thing is really on there
Old 03-11-2004, 01:08 PM
Two_K Si's Avatar
I dont know man, maybe put some glue on the end of the wire and stick it down in there. Maybe when it dries, you can get it off the plug. There has to be an easier way.
Old 03-11-2004, 01:12 PM
PSU
PSU's Avatar
i thought about that, but it would prolly still pull right off with force <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">I dont know man, maybe put some glue on the end of the wire and stick it down in there. Maybe when it dries, you can get it off the plug. There has to be an easier way. </TD></TR></TABLE>
i hate my car
Old 03-11-2004, 01:19 PM
Sketch_hs's Avatar
long *** pliers or some kinda sharp hook?
good luck
Old 03-11-2004, 01:22 PM
Nextelbuddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch &raquo;</TD></TR><TR><TD CLASS="quote">Can we just point and laugh? Hahaha
lol just use long needle nose pliars. i hope you dont have to take the head off lol. i had a similar problem when my adaptor for my compression tester got stuck in the spark plug hole took me like 2 hours to figure it out.
Old 03-11-2004, 02:06 PM
kun3racer's Avatar
that happend to me a couple of times... i used two long flat heads like they were cop sticks and i got it out
Old 03-11-2004, 02:15 PM
PSU
PSU's Avatar
Default Re: HELP:Piece of spark plug wire stuck around spark plug (kun3racer)
thanks guys hopefully one of those ways will work
Old 03-11-2004, 02:19 PM
EL Vap133's Avatar
Is it only stuck to the tip of the spark plug? Cause maybe you can unscre the tip with some pliers?
Old 03-11-2004, 02:39 PM
PSU
PSU's Avatar
superglue worked, yeahh!
now, where can i buy oem plug wires?
Old 03-11-2004, 02:56 PM
EL Vap133's Avatar
http://www.hondaautomotiveparts.com
Or you can also try the classifieds section, people take off their OEM wires for aftermarket ones all the time.
Old 03-11-2004, 03:44 PM
PSU
PSU's Avatar
thanks
i know HAMP is good, have ordered from there before
but where on the site are plug wires?
Old 03-11-2004, 03:49 PM
PSU
PSU's Avatar
okay found them
they are $56 for 4
Old 03-12-2004, 05:30 AM
PSU
PSU's Avatar
Default Re: (Dimi)
oh im defiently getting them, just a matter of when i get them
Old 05-27-2012, 11:27 PM
b20bFourDoorCivicLX's Avatar
im having a similar situation, but you didnt post a picture so i can compare, take a look maybe someone on here can help me out,
heres my sparkplug, it looks nothing like the rest, i can see further down, so you said you put superglue? superglue on what>? the socket? and let it sit and try so u can just yank it out?
Old 05-28-2012, 03:32 AM
Technical Hero
HondaPartsHero's Avatar
Long thin flathead screwdriver and/or super long thin pair of needle nose pliers. I've done it like that plenty of times with multiple engines. Coat hanger will also work as well.
Quick Reply: HELP:Piece of spark plug wire stuck around spark plug
