b16a head on b20a "the frankinstien"
Old 03-06-2004, 11:55 AM
miketurbohonda's Avatar
Default b16a head on b20a "the frankinstien"
hey i brought a b20a block and i was reading the honda building book and you can bolt a b16a head on the b20a block with ease on problems and make it vtec aswell just by hooking up oil line from oil pressure sensor on back of block.and a ecu
but does this work on the b20a gold top. or the b20a black top????
your help is much appreciated
thanks
mike
Old 03-06-2004, 12:38 PM
non-VTEC's Avatar
Default Re: b16a head on b20a "the frankinstien" (miketurbohonda)
you bought a B20A? you might as well use it as a boat anchor.....those B20A's found in the older 2.0 preludes are useless. you can rev them over 6500rpm without blowing them up.
the B20 you NEED is from the 98+ Honda CR-V. engine codes B20B or B20Z. if properly built they can take 8500rpm or maybe even more.
oh and i have no idea what your referring to about gold or black tops? what are those supposed to mean?
Old 03-06-2004, 07:08 PM
virginia_dude's Avatar
Default Re: b16a head on b20a "the frankinstien" (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">you bought a B20A? you might as well use it as a boat anchor.....those B20A's found in the older 2.0 preludes are useless. you can rev them over 6500rpm without blowing them up.
oh and i have no idea what your referring to about gold or black tops? what are those supposed to mean?</TD></TR></TABLE>
Second that. You have to use a B20B or a B20Z, the B20A is about as usefull for high performance as a HF engine is.
Old 03-06-2004, 07:24 PM
Kendall's Avatar
Default Re: b16a head on b20a "the frankinstien" (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">Second that.</TD></TR></TABLE>
And a third.
Old 03-06-2004, 09:07 PM
b20a the 2 litre dohc motor
whats wrong with that???
have you not seen the browny/gold top motor in the 86model preludes and the black top rocket cover in the later model preludes
i was going to rebuild b20a with forged pistons etc.. for when my turbocharged 1600 ZC dohc motor blows up.
Old 03-06-2004, 10:21 PM
JDMorgan's Avatar
a b20a is a shorter block. some1 figure out bore and stroke on it and deck height too while ur at it.
Old 03-06-2004, 11:25 PM
Rusty Shackleferd's Avatar
Default Re: (KraZEtEggIE)
Back in the day people would use those cranks in ls blocks
My friend had one (81x95 ls motor in a coupe). It had crazy mid range but nothing above 7grand.
Probly would have made for a pretty good tow vehicle though......lol
Old 03-07-2004, 02:11 AM
jeremy.'s Avatar
Default Re: (10secondbeast16)
i thought a frankinstein motor was a k20 head on a tsx block
Old 03-07-2004, 09:13 AM
dfoxengr's Avatar
Default Re: (ek_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">i thought a frankinstein motor was a k20 head on a tsx block</TD></TR></TABLE>
uzzled: i hope youre being sarcastic. although this is one variation with the k series motors
Old 03-07-2004, 10:00 AM
red91sit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10secondbeast16 &raquo;</TD></TR><TR><TD CLASS="quote">Back in the day people would use those cranks in ls blocks
Probly would have made for a pretty good tow vehicle though......lol</TD></TR></TABLE>
Did it bolt right up to the ls rods? I really want to do the exact opposite lol but i don't want to buy new rods.
BTW was that crank from a 88-91 prelude or a pre 87 or older.
Also all 3rd gen motors are black valve covers and the single cammers i think had gold tops but these motors are completely different from the black tops.
Old 03-07-2004, 10:51 AM
Default Re: (red91sit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red91sit &raquo;</TD></TR><TR><TD CLASS="quote">
Also all 3rd gen motors are black valve covers and the single cammers i think had gold tops but these motors are completely different from the black tops.</TD></TR></TABLE>
you use the ls block, b20a crank and b16a rods
Old 03-07-2004, 01:22 PM
red91sit's Avatar
These all bolt right together? no machine work needed?
Old 03-07-2004, 01:40 PM
dfoxengr's Avatar
thees some machine wor. searc lsvtec on google
JoLibs
09-20-2017 02:13 PM
JDM_EK_621
10-06-2007 10:22 PM
xtokex
10-05-2007 11:10 PM
mok
03-11-2007 12:25 PM
caminSi
12
09-07-2006 03:26 PM
Quick Reply: b16a head on b20a "the frankinstien"
