what is done at 80k mile service check?
Re: what is done at 80k mile service check? (Seminole83)
80,000 service
Timing belt
Water Pump
all drive belts
all hoses
valve adjastment
plug wires
plugs
rotor/distributor cap
radiator flush
brake flush
clutch fluid flush
powersteering flush
new break pads all around
new airfilter
pcv valve
and that should do it
Timing belt
Water Pump
all drive belts
all hoses
valve adjastment
plug wires
plugs
radiator flush
brake flush
clutch fluid flush
powersteering flush
new airfilter
pcv valve
