Spoon calipers...
Old 02-25-2004, 11:51 AM
scribnits's Avatar
Default Spoon calipers...
Im looking into a brake upgrade for my DC5. I want something where I dont have to switch to a 17" or larger wheel, as I dont wanna lose the use of my OEM wheels. So, Ive decided on Spoon calipers, with a good set of rotors and pads, and stainless lines around. Heres my question... are the Spoon calipers bolt-on with a certain bracket (ie S2k or otherwise), or is it more trouble than its worth? Thanks in advance.
Old 02-25-2004, 01:33 PM
tenzintsewang's Avatar
i have done calculation on going to spoon route vs big brake kit (brembo)
spoon comes out at the end close to the big brake kit
when you add:
Calipers
Rotors
Pads
SS Lines
Old 02-25-2004, 02:09 PM
scribnits's Avatar
Default Re: (tenzintsewang)
Do you mean more expensive? Not really, I can do the whole setup front and rear for less than a Brembo kit for just the front. Also, I wont have any 16" wheel problems, except *maybe* having to use a spacer, depending on which wheels I go with.
Old 02-26-2004, 12:21 PM
Default Re: (Driftntouge)
comes down to same price if you buy spoon rotors/ss lines/pads!
i got brembo with oz superleggra..and i need to use spacer
Old 02-27-2004, 10:33 AM
scribnits's Avatar
I dont see a reason to buy Spoons rotors or pads, as they are better pads out there for less money. Ive also heard of more than one instance where Spoon rotors have cracked, on numerous S2000s.
Old 02-29-2004, 04:23 PM
mikestypes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tenzintsewang &raquo;</TD></TR><TR><TD CLASS="quote">comes down to same price if you buy spoon rotors/ss lines/pads!
i got brembo with oz superleggra..and i need to use spacer </TD></TR></TABLE>
What size and offset Superleggera are you running?
Acurapwrd
11
03-28-2006 09:13 PM
crix868
12-03-2005 10:01 AM
Acurapwrd
03-26-2005 09:56 PM
AllMotorITR
01-22-2002 08:35 PM
Quick Reply: Spoon calipers...
