spark plugs STUCK, how to remove?
Old 01-24-2004, 11:29 AM
  #26
RTW DC2R's Avatar
its safe to spray flammable liquid down there?? its not gonna blow up or anything when I try to fire it up right?
Old 01-24-2004, 12:21 PM
  #27
v-attack's Avatar
Location: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (RTW DC2)
on the PB blaster
Old 01-24-2004, 01:01 PM
  #28
Tweakmeister's Avatar
Default Re: (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">its safe to spray flammable liquid down there?? its not gonna blow up or anything when I try to fire it up right?</TD></TR></TABLE>
No problem as long as you clean everything. Besides...most of these will be evaporating anyway. If you're concerned about something flammable there then you have a bigger problem (leakage).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote"> on the PB blaster</TD></TR></TABLE>
Amen to that, accept no substitutes
Old 01-24-2004, 02:38 PM
  #29
RTW DC2R's Avatar
got 3 out...broke the 4th one :uber ******* mad:
guess Ill be pulling the head soon.
Old 01-24-2004, 03:14 PM
  #30
98ITR#0020's Avatar
That really sucks!!!! Did you try any of the suggestions?oil or PB or anything?
Old 01-24-2004, 03:39 PM
  #31
JjuuN R's Avatar
ok i've never had a spark plug snap in half on me, so i'm just curious of what the process is in getting the rest out?
is removing the whole head the only way out of it?
Old 01-24-2004, 03:41 PM
  #32
RTW DC2R's Avatar
both...let oil sit overnight then picked up some PB today, drowned it and let that sit for a couple hours...
It sucks even more because it was coming out slowly but surely, but it wouldnt let me turn it smoothly, it was just popping and jerking as I pulled. then the collar on the plug snapped.
Old 01-16-2005, 09:36 AM
  #33
rs
rs's Avatar
Just did a spark plug change on my beater (1987 chevy with original plugs). I soaked the plugs with PB for about 20 minutes and then tried to loosen them a little (just put some pressure so the PB would soak down a little more). Waited about 10 more minutes and then removed them carefully, gradually applying pressure, w/o any problems. No warming the engine or anything - worked liek a champ.
Old 01-16-2005, 10:49 AM
  #34
itr78's Avatar
Default Re: (rs)
that stinks your 4th snapped.
i didn't use anti-sieze last time. i should redo mine so same thing doesn't happen to me.
thanks for that info on PB.
Old 01-16-2005, 11:02 AM
  #35
RTW DC2R's Avatar
heres the results of this pain in the *** issue
https://honda-tech.com/zerothread?id=750340
BoydCivic2005
Honda Civic (2001 - 2005)
12-17-2013 08:50 AM
killercrx91
Honda Civic (2006 - 2015)
15
09-25-2008 12:51 PM
bringmyownend
05-04-2007 07:41 PM
Dartanian
05-13-2006 05:26 AM
Quick Reply: spark plugs STUCK, how to remove?
