[FAQ] How To: Wiring VTEC into an EG non-Si Civic (that's not a 92) OBD1 w/p28
Old 01-05-2004, 01:52 PM
ARIZONA's Avatar
Default How To: Wiring VTEC into an EG non-Si Civic (that's not a 92) OBD1 w/p28
So you've just swapped a SOHC VTEC motor into your EG (CX,VX,DX, whatever).
Now, just wire up the VTEC spool solenoid and Pressure switch to clear those CEL's. (assuming you are good to go as far as O2 sensors)
The PIC below is the upper connector on your passenger side shock tower under your hood. Now, assuming the VTEC motor you just swapped in came with the engine harness intact, the 2 spots I am pointing to should not be plugged.
It should now look like this:
So, the upper Green/yellow wire is the VTEC spool solenoid, and the lower Blue/black is the pressure switch
Now you need to run wires from your stock ECU harness to the back of that plug where they are still blank.
If your EG is a 92, the work has been done for you and you need nothing more. However if yours is 93 up and not an EX/Si you will need to salvage 2 pins from a junked harness and 2 from a junked plug.
Try to pull the pins from the harness and plug with atleast 2 to 3 inches of the wire still on those pins for ease of splicing. On the "parts" harness, undo the "keeper clip" that folds down securing the pin seats in place, use a needle or a pin puller to release the pins from positions A4 and D6.
Plug those into your harness in the perspective locations, splice enough wire to run to the shock harness.
Now, salvage two of the pins from the plug harness and those go to the blank spots on your car. Make sure that the one that has the Green/yellow wire on the engine side mates with the wire you ran from A4 on the firewall side, and the Blue/black with the D6 wire.
Simple enough right! Good luck and I hope this helps!!!
Old 02-16-2004, 10:29 AM
JurakS's Avatar
Default Re: How To: Wiring VTEC into an EG non-Si Civic (that's not a 92) OBD1 w/p28 (ARIZONA)
ok i need this..gonna save in my watched topics
Old 02-16-2004, 10:32 AM
Risky Business
BauleyCivic's Avatar
Good info
Old 02-16-2004, 10:33 AM
al3e's Avatar
Default Re: How To: Wiring VTEC into an EG non-Si Civic (Juraks)
yeah same hurr
Old 02-19-2004, 02:32 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: How To: Wiring VTEC into an EG non-Si Civic (al3e)
good write up. just what i needed.
Old 02-19-2004, 05:01 AM
XoUnKoWnXo's Avatar
I needed this badly. Printing it out right now. Thanks
Old 05-01-2004, 10:31 PM
hondaeg8's Avatar
Default Re: (XoUnKoWnXo)
what about the knock sensor?
Old 05-02-2004, 09:59 AM
J.P.'s Avatar
Default Re: (hondaeg8)
nice little write-up.
Old 05-02-2004, 03:02 PM
ARIZONA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">what about the knock sensor?</TD></TR></TABLE>
Well, using a P28, you cannot use it. Good Fortune I'd say. Now, say you NEED one for some reason, use a p30 or similar and hardwire from the ECU to the Sensor.
Old 05-02-2004, 03:12 PM
4DRPIMPIN's Avatar
Default Re: (ARIZONA)
Good stuff, probably need to add this to the FAQ swap thread.
Old 05-02-2004, 05:26 PM
gillyfesh's Avatar
okie, what if i am doin a swap on my EG 94 hatch cx model with 94 GSR engine and p72 ecu. do i need to modify the wiring??
Old 05-02-2004, 06:32 PM
trooper0641's Avatar
Default Re: How To: Wiring VTEC into an EG non-Si Civic (gillyfesh)
well i hope your right...and i hope that all "92s" are prewired for vtec. Because i just swapped in a d15b into my 1992 cx w/ a z6 harness p28 ecu. Hopefully vtec will work.
Old 05-02-2004, 07:00 PM
ARIZONA's Avatar
Default Re: How To: Wiring VTEC into an EG non-Si Civic (trooper0641)
I hope so too, for your sake.
Old 05-03-2004, 01:02 PM
cxjon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARIZONA &raquo;</TD></TR><TR><TD CLASS="quote">So you've just swapped a SOHC VTEC motor into your EG (CX,VX,DX, whatever).
my 92 civic plug has three rubber plugs in the harness plug....
i am a 1 wire o2 as well
Modified by cxjon at 5:18 PM 5/3/2004
Old 05-03-2004, 02:02 PM
labatia's Avatar
what about hooking it up to p08?
Old 05-11-2004, 04:33 PM
icucnme's Avatar
Thanks this helped alot.
Old 05-20-2004, 08:57 PM
SkRiBLaH's Avatar
sweet
Old 09-29-2004, 11:56 AM
drewbie*'s Avatar
good stuff
Old 02-13-2006, 08:17 PM
kos99ngel's Avatar
nice!!!!!!!!
Old 06-22-2006, 08:58 PM
_RedRiceR_'s Avatar
Default Re: How To: Wiring VTEC into an EG non-Si Civic (labatia)
yeah, what about p08?
Old 08-05-2006, 10:42 AM
17's Avatar
This helped a lot! Thanks Arizona.
What about using a PR3? I'm still throwing a cel #23. The only thing is I'm using a 94 Del Sol Dohc Vtec Engine Wire Harness but still have the 93 Civic Cabin harness. The color of the knock wire is Yellow w/red stripe and the MAP sensor has that color as well. You can't really follow the color to the plug because one leads the plug on the passenger side and the other leads to the plug on the driver side.
My Vtec is good!
I'm trying to bring out the techies here, but I appreciate all input and suggestions!
Thanks!
Old 08-05-2006, 11:15 AM
17's Avatar
Default knock sensor help or suggestions
need quick help!
My Vtec is good!
Thanks!
Old 10-01-2006, 08:41 PM
jackhunt321's Avatar
Default Re: knock sensor help or suggestions (17)
AWESOME POST! I jsut did this and it cleared my check engine lights. I can't feel the vtec AT ALL, so this poses 2 questions.
1.)Why can't I feel the VTEC? How can I check this? (my buddy car is the same motor and i can feel it) NO CELS visible.
2.) My cx had a one wire 02 sensor, and now a 4 wire w/ the Z6. I didn't rewire anything and there is no CEL. Is this something I need to do or can affect performance?
Old 10-01-2006, 10:10 PM
Jonny G.'s Avatar
great info now can u do one that explains how to hook up a 4 wire O2 on a 1 wire O2 car?
Old 05-29-2007, 02:08 PM
BelgiumEG6's Avatar
nice
Quick Reply: [FAQ] How To: Wiring VTEC into an EG non-Si Civic (that's not a 92) OBD1 w/p28
