> Acura Integra Type-R
Old 12-31-2003, 05:25 PM   #1
Willard
Banned
Default Front wheel bearing replacement and wheel-stud install pictures/info (56K die)
"sorry charlie"
Modified by Willard at 11:21 AM 3/21/2007
Willard is offline Report Post   Reply With Quote
Old 12-31-2003, 05:34 PM   #2
Smitdog
Moderator
Smitdog's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (Willard)
Great Write up and Pics Willard! You are Impressive as always! This is the Tech Information that h-t use to be flooded with back in the day......
ITR #120
Dodge Cummins: Smarty Power - 426rwhp/789ftlbs
44' Pace Shadow GT
Smitdog is offline Report Post   Reply With Quote
Old 12-31-2003, 05:34 PM   #3
ITR764
ITR764's Avatar
nice write up d00de!!!
Keith
http://images.honda-tech.com/set1/smile/embeer.gif "I feel sorry for people who don't drink. They wake up in the morning and that's as good as they're going to feel for the rest of the day."
-Frank Sinatra. http://images.honda-tech.com/set1/smile/embeer.gif
ITR764 is offline Report Post   Reply With Quote
Old 12-31-2003, 05:46 PM   #4
Kicker773
Kicker773's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (ITR764)
wow.. now if i only knew how to do that..
Kicker773 is offline Report Post   Reply With Quote
Old 12-31-2003, 05:49 PM   #5
myhatchrips
you had to drill the hub? i have arps also and they just pressed in with no problems. make sure that those studs dont have any play. otherwise
myhatchrips is offline Report Post   Reply With Quote
Old 12-31-2003, 06:01 PM   #6
JjuuN R
Send a message via AIM to JjuuN R
awsome write up~
JjuuN R is offline Report Post   Reply With Quote
Old 12-31-2003, 06:02 PM   #7
Willard
Banned
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (myhatchrips)
the first try at pushing the stud in was quite hard... after the drill out they were hard but not as hard.
don't worry.. there is no play at all.
Old 12-31-2003, 06:46 PM   #8
D
Send a message via AIM to D
D is offline Report Post   Reply With Quote
Old 12-31-2003, 07:06 PM   #9
Dan GSR
Dan GSR's Avatar
Send a message via AIM to Dan GSR
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (D)
awesome write up
saved it to my hard drive
Frost White 95 LS... SOLD
2006 VW GTI
R-Speed
Dan GSR is offline Report Post   Reply With Quote
Old 12-31-2003, 07:27 PM   #10
743power
743power's Avatar
Send a message via AIM to 743power
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (Dan GSR)
Good stuff Willard. I believe ARP makes a honda specific knurl size stud now, I have some on order, I will confirm when they come in. Anyway, I will be doing this to my civic in the next month or so, good write up.
Do I really need all of those sockets you listed? I can only imagine that those 2"+ ones are quite expensive at sears. Also, would you only recommend OEM Honda bearing as a replacement, or would a pepboys/autozone one be acceptable?
"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
-Albert Einstein
743power is offline Report Post   Reply With Quote
Old 12-31-2003, 07:52 PM   #11
type r 01-1063
type r 01-1063's Avatar
Send a message via AIM to type r 01-1063
What kind of symptoms do you experience when you know the wheel bearings has to be replaced?
I'd rather go surfin' on HT.
type r 01-1063 is offline Report Post   Reply With Quote
Old 12-31-2003, 08:53 PM   #12
Bbasso
Bbasso's Avatar
Allthough everything worked fine, I'm still scared about that press
Good detail and good pics!
Bbasso is offline Report Post   Reply With Quote
Old 12-31-2003, 09:05 PM   #13
JjuuN R
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (type r 01-1063)
1: noise from the area
2: jack the car up without it in gear and spin the wheel with your hand, if it don't look like it's moving freely enough check your brakes, then the bearing.
3: they're usually good for 100,000 miles+ if you're in a dry city.
i live in vegas where there's not too much rain or snow
Old 12-31-2003, 11:10 PM   #14
Nuts
Nuts's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (JUN.R)
nice write up..... looks like there are a lot of tools I am missing if I have to do it myself though.
Nuts is offline Report Post   Reply With Quote
Old 12-31-2003, 11:36 PM   #15
EK MONEY
EK MONEY's Avatar
good write up
EK MONEY is offline Report Post   Reply With Quote
Old 01-01-2004, 12:55 AM   #16
Kicker773
Kicker773's Avatar
hmm.. i live in the midwest area.. n well the car has been throug two snow seasons.. n i haven't checked on those.. but i did replace one of the axles.. hmm i wonder .. i'd have to check.. nice info on the symptoms
Old 01-01-2004, 05:26 AM   #17
Willard
Banned
They do... but the GM ones were in stock and ~$11.50 for a pack of 5.
You need those or the Honda specific pressing tools. The China brand sockets worked quite well and are much cheaper than the Honda press heads.
Dad got that socket set at a tractor show for his 3/4" drive socket set a while back... they have seen more use on the press than anything. Who have ever seen a 2-3/4" nut?
If you can find it cheaper somewhere else be my guest. I know the Honda one will work and will last about a year of HPDE driving for me... so Honda it will be. They are now considered a wear item on my car (like rotors/tires). At the first of the year... the car will get a new drivers side bearing and every other year the car will get a passengers side bearing.
Clicking when going over speed bumps while turning. Under normal use they should last well over 150,000 miles... but track use/heat shorten the life quite a bit.
The press is your friend.
Dad got it at a state auction a few years back for a $100 or so. It has paid for it's self many times over.
-re-bushed 3 Volvo's (full suspension)
-wheel bearing's
-Honda diff. bearing swap
Old 01-01-2004, 08:27 AM   #18
00MRSi
Will, great writeup!! Thanks for sharing.
00MRSi is offline Report Post   Reply With Quote
Old 01-01-2004, 09:12 AM   #19
rated_r
rated_r's Avatar
love the wheel studs
2000 ITR R.I.P
1995 BMW 325i 2009 Kawasaki Ninja 250r
2010 Triumph Daytona 675 Special Edition
rated_r is offline Report Post   Reply With Quote
Old 01-01-2004, 09:23 AM   #20
Philly_NBP_R
Philly_NBP_R's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (rated_r)
sweet write up Willard!
I wish I had a press like that...
2001 NBP ITR #386 - sold 02/18/05
2002 Subaru Impreza 2.5 RS - fun to drive, needs 100 more hp...
Check out some pics here
Philly_NBP_R is offline Report Post   Reply With Quote
Old 01-04-2004, 10:50 PM   #21
mstewar
mstewar's Avatar
Send a message via AIM to mstewar
nice write up, willard!
ITR #98-0158 - SOLD -- ITR #98-1040 - SOLD
ITR #00-0187 - SOLD -- ITR #00-0332 - SOLD -- ITR #01-1107 - SOLD
ITR #98-0106 - RIP -- ITR #98-0055/MWHC H2 #55 - SOLD
mstewar is offline Report Post   Reply With Quote
Old 01-05-2004, 06:31 AM   #22
Splat
Collector-o-Guns and Drinker
Splat's Avatar
FYI - Harbor Freight sells a 12-ton press for not a terrible amount of money. Willard can offer input on whether it would be hefty enough for this job, but I know it's more than enough for Volvo suspension bushings
Pat http://images.honda-tech.com/set1/smile/emdgust.gif
'99 S70 T5M (1 of 197), '02 S40 1.9T, '83 245DL Wagon, 244GL Sedan (busted), '76 IH Scout II
I believe she's going down,
I believe we're gonna die die die!
Splat is offline Report Post   Reply With Quote
Old 01-05-2004, 06:40 AM   #23
Willard
Banned
Default Re: (Splat)
12T < 28T
Old 01-05-2004, 07:07 AM   #24
Splat
Splat's Avatar
Default Re: (Willard)
Originally Posted by Willard
12T < 28T
Well duh
But few have 28T presses in their garage
Harbor Freigh = economical alternative. Use it twice and it has paid for itself
Old 01-05-2004, 07:44 AM   #25
Johnny Tran
Johnny Tran's Avatar
Send a message via AIM to Johnny Tran
Default Re: (Splat)
when are we bolting up the Weld Draglites and Sticky Mickey's ?
Black Label Society - NC chapter
Johnny Tran is offline Report Post   Reply With Quote
Bookmarks
2000, 2001, 63110, acura, bearing, cheap, civic, crv, front, honda, integra, louis, replacement, st, wheel
