what is this light? (pic inside)
what does this light mean? ive never seen it before.
iam getting that light after i put on my new exhaust.
Modified by db8sirg at 11:08 AM 12/16/2003
Re: what is this light? (canuck-mx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">His manual would not cover the JDM cluster </TD></TR></TABLE>
He could try to find a JDM manual and someone to read it
Re: what is this light? (DigitalPunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DigitalPunk »</TD></TR><TR><TD CLASS="quote">I dunno why they have em, but I know thats what it is.</TD></TR></TABLE>
A catalytic converter can overheat to the point where it is so hot it is igniting the bottom undercoat of a car. If you happen to have a slight oil leak, you could be doing even more harm.
Re: what is this light? (hondahans)
i have seen that on most of the jdm clusters i have seen. FOr overheating cat convertor. Y? who knows... maybe because they have higher octane, their exhaust temps are higher and need to be monitored? No clue why, but thats what its for
Re: what is this light? (B16B)
IT IS ON JDM CLUSTERS ONLY. IT IS SUPPOSED TO TELL YOU WHEN THE CAT IS COMPLETELY WARM.
We here in the US do not have that plug for the bung so it does not come into play. I would suggest unplugging that bulb so it is not as annoying.
Sorry for the bold but I just had to inform everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahans »</TD></TR><TR><TD CLASS="quote">It's a light indicating the warming up of the 2nd o2 sensor (to read properly). JDM obd2</TD></TR></TABLE>
JDM ecu's do not check for a 2nd o2. If you run a jdm ecu, you can run a test pipe without the worries of a CEL.
Re: what is this light? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote"> IT IS ON JDM CLUSTERS ONLY. IT IS SUPPOSED TO TELL YOU WHEN THE CAT IS COMPLETELY WARM.
Sorry for the bold but I just had to inform everyone. </TD></TR></TABLE>
so it on to tell me the cat is not completely warm?
Re: what is this light? (Jesse H)
It is a CAT over heat light, all JDM cars have a temperature probe at the end of the cat which lights up if the CAT gets too hot. It also lights up like that if the sensor gets disconnected. When people remove the CAT from their car they usually just take the bulb out of the cluster.
Re: what is this light? (Silver-Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver-Teg »</TD></TR><TR><TD CLASS="quote">It is a CAT over heat light, all JDM cars have a temperature probe at the end of the cat which lights up if the CAT gets too hot. It also lights up like that if the sensor gets disconnected. When people remove the CAT from their car they usually just take the bulb out of the cluster.</TD></TR></TABLE>
There you go. The answer to all your questions.
Re: what is this light? (non_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non_VTEC »</TD></TR><TR><TD CLASS="quote">It means ur ramen is ready! </TD></TR></TABLE>
damn you damn you damn you.....i was JUST about to type that
Haha good one bro
Haha good one bro
