[FAQ] ECU Codes for everyone
Old 11-27-2003, 10:44 PM
  #26
JDMlyfestyle's Avatar
common mods this needs to be a sticky
Old 11-27-2003, 11:39 PM
  #27
oddball327's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">common mods this needs to be a sticky</TD></TR></TABLE>
Old 11-28-2003, 12:58 AM
  #28
i need all the support i can get for this cause i dont think they want it as a sticky. but it will solve alot of flaming, and alot of nonsense posts
Old 11-28-2003, 01:33 AM
  #29
civic_tuned's Avatar
damn it i cannot find the the green box on mine. Is it visible or is covered with black tape over the ecu. ive checked above the kicker panel and nothing. CAn somebody help a brother out.
i have some car seats in the back and all i hear is daddy go faster!
Old 11-28-2003, 12:50 PM
  #30
my bad bro. its a grey plug. there should be a red w black strip wire and a black w a white strip going to it. sorry lights out in the garage. lemme know if that was right
Old 11-28-2003, 07:02 PM
  #31
misfitmagoofey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">if you go to passanger side kick panel and raise up the carpet u sould see your ecu. and above your ECU there will be a lil plug. i believe its green. I take a spare piece of thin speaker wire and cut off both ends so that the actual copper of the wire is showion on both ends. i twist up both ends so that they are in a nice point. stick one end of the wire into the fist socket on the plug. The other end of the wire into the other socket. Turn your key to the ON position.. dont start your car. just to the ON position. Watch your check engine light on your cluster. it will flash.. 1 long flash is 10. the quick flashes are one. so if ur CEL goes !.....!!! that is a code 13. !....!....!!!!! code 25. then take the code #'s and hop on this thread and see what it is. i hope i could help you all.</TD></TR></TABLE>
thanx man i know exactly where your talkin bought and that helps me alot better than what ive ben told in the past
thanx again magoo
Old 11-28-2003, 08:48 PM
  #32
Hey no prob bro thats what HT is for helpin each other out. and ive been pretty bored lately so i decided to do it.
Old 11-29-2003, 11:23 AM
  #33
Common mods :thumpup:
Old 11-29-2003, 12:41 PM
  #34
scratchy's Avatar
Default Re: ECU Codes for everyone (JDMlifestyle)
this is the **** i'm talkin about thats what this forum is about very very nice
Old 11-29-2003, 10:32 PM
  #35
TTT for everyone doing late night work on there BEAST
Old 11-30-2003, 09:25 PM
  #36
TTT for the motor heads
Old 12-03-2003, 12:05 AM
  #37
TTT. had to use it tonight cleaned out IACV
Old 12-03-2003, 03:04 AM
  #38
photec2's Avatar
he is another place http://tech.hybridgarage.com/tech/codes.html
Old 12-03-2003, 03:34 AM
  #39
Mr Boston's Avatar
Default Re: (misfitmagoofey)
Thanks for the list
Old 12-03-2003, 04:24 AM
  #40
VRD^don's Avatar
nice post..
Old 12-03-2003, 05:55 AM
  #41
ViRS2304's Avatar
Do these codes apply for the '98 Civic
Old 12-03-2003, 09:47 AM
  #42
yes they are obd 1 & 2
Old 12-03-2003, 07:44 PM
  #43
Up to the top for the hell of it.
Old 12-03-2003, 08:45 PM
  #44
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">TTT. had to use it tonight cleaned out IACV</TD></TR></TABLE>
does anybody know where the iacv is located. Is in back of the intake manifold and how would u clean it.
fs
apexi vafc~new
92-95 civic tanabe springs
Old 12-03-2003, 09:47 PM
  #45
if u look on the back of your TB there is a sensor right there that is ur tps. 2 inches to your right is like a long black ****. thats ur IACV. take off the 2 12 mm. and i used carb cleaner and it runs fine now.
Old 12-05-2003, 01:09 PM
  #46
ViRS2304's Avatar
I found the soft green plastic enclosure and a 2pin plug with a red wire with black strip and a black wire with white strip... but where do i look to see the codes?...
Oh yea...and What`s the CEL??
Old 12-05-2003, 02:01 PM
  #47
GoT HaTcH's Avatar
Default Re: (ViRS2304)
good info! thanks
Old 12-05-2003, 03:29 PM
  #48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">if u look on the back of your TB there is a sensor right there that is ur tps. 2 inches to your right is like a long black ****. thats ur IACV. take off the 2 12 mm. and i used carb cleaner and it runs fine now.</TD></TR></TABLE>
thanks. good info!
Old 12-08-2003, 06:28 PM
  #49
TTT since everyone is asking about this tonight
Old 12-16-2003, 02:09 PM
  #50
egturbo's Avatar
kewl thread..
Quick Reply: [FAQ] ECU Codes for everyone
