> Forced Induction
Old 10-15-2003, 10:53 AM   #1
revhigh96
revhigh96's Avatar
Send a message via AIM to revhigh96
Default The correct way to make your own Profec B switch
For people that dont know what I am talking about I will explain it first.
On the back of the Profec B there is a small jack for the wireless boost switch. Some people came up with the idea to make their own wired switch instead of spending the $100 for the greddy one. In all the tutorials for this I have seen the people just took a mono headphone plug and when you touch the two wires together it switches. The big problem with this is you need a small piece of vacume line (1-2mm works best) to shorten the lenght of the plug or else something shorts out inside the profec B. I tried this and it worked pretty good for a while but every once in a while I would have to mess with the plug to get the connections correct because the insulation was keeping the plug from "clipping in" to where it was supposed to sit.
Today I decided I had enough with the ghetto rigged switch and it was time to figure out how to do it right.
I took the Profec B appart and to my amasement the plug in the back is a stereo headphone plug and NOT a mono one! The plug inside the Profec B had three contact points. The mono plug everybody was putting in there only had two and was shorting the plug out between two of the contact points which was making the Profec B smoke!
I took a spare STEREO headphone plug I had laying around and plugged it in with no modifications what so ever. It work great. No smoke and it clicked in like it was supposed to so there is no more messing around with the connections.
Now for the wiring part.
Now there are three wires not two like everyone is used to.
(refer to picture below)
1. The tip of the headphone plug is the signal wire to the Profec B.
2. The center of the plug is the power wire that goes to the wireless part (We wont use this)
3. The last part is the ground.
Now all you have to do is put a momentary switch between the #1 and #3 wire and there you have it!
I was able to use my old cruise control buttons on my steering wheel for my switch and that works great.
Any questions?
-96 Civic EX - b18c5 turbo
revhigh96 is offline   Reply With Quote
Old 10-15-2003, 11:06 AM   #2
ScottEK
ScottEK's Avatar
Send a message via AIM to ScottEK
Default Re: The correct way to make your own Profec B switch (revhigh96)
I read mostly all the Profec B switch posts, I remember people's were shorting out and I'm pretty sure they finally figured out that the switch was supposed to be switching a ground on and not +12v like everyone was doing. Anyone remember something like this?
Scotty Doesn't Know!
90' Chameleon CRX - TopMount SC61 w/ 4" Downpipe Can Be Done...
94' Integra - Project Dadfab
96' Civic EK H22 Hatch
02' RSX Type-S Daily Driver
<FONT COLOR="blue">Download My Turbo CRX Videos</FONT>
ScottEK is offline   Reply With Quote
Old 10-15-2003, 11:10 AM   #3
revhigh96
revhigh96's Avatar
Default Re: The correct way to make your own Profec B switch (beta13)
Yeah I do remember that and the way I did it takes care of both the mono plug problem (which is definatly one of the problems) and mine does go to ground. Even with going to ground you will still have problems if you try to use a mono plug without some type of spacer or washer.
Old 10-15-2003, 08:04 PM   #4
SOUNDEFFECTS
SOUNDEFFECTS's Avatar
Send a message via AIM to SOUNDEFFECTS
pimp *** craftsmanship!
Old School Boost Junkie
SOUNDEFFECTS is offline   Reply With Quote
Old 10-15-2003, 08:14 PM   #5
FredoSP
FredoSP's Avatar
so u just use your curise control button to turn on the Profec B or to adjust boost levels?
I have a Profec A I wonder if I have this?
- Fred
400+ Whp Club
Arturbo, Earl, Stan, Len, Boostfed.com http://images.honda-tech.com/set1/smile/emthup.gif
"I rather be tried by 12 then carried by 6" P.O. Diaz, NYPD
FredoSP is offline   Reply With Quote
Old 10-15-2003, 08:30 PM   #6
White Smoke
i my honda
Global Mod
White Smoke's Avatar
What about an hks evc IV. Think this will work? I will have to take it appart and check it out.
White Smoke is offline   Reply With Quote
Old 10-15-2003, 08:36 PM   #7
GSRrR
GSRrR's Avatar
Default Re: The correct way to make your own Profec B switch (FredoSP)
- Fred
to switch between hi and low boost settings
GSRrR is offline   Reply With Quote
Old 10-15-2003, 09:16 PM   #8
torr
Default Re: The correct way to make your own Profec B switch (GSRrR)
Yeah post up about he profec A? Would be nice to know if that works
I wish I can install an aem on my girlfriend so I can tune her mouth shut.
torr is offline   Reply With Quote
Old 10-15-2003, 11:14 PM   #9
PHiZ
PHiZ's Avatar
Send a message via AIM to PHiZ
Default Re: The correct way to make your own Profec B switch (torr)
I don't have a profec, but I'd like to say thanks for a GREAT post.
-PHiZ
More go fast, less look fast.
Wideband tuning, ECUs, Conversion Harnesses, and ECU chipping available!!
PHiZ is offline   Reply With Quote
Old 10-16-2003, 07:34 PM   #10
revhigh96
revhigh96's Avatar
Thanks for the positive feedback! If somebody wants to donate a profec A to me I'll figure it out!
It works really good cause I dont have cruise control in my car anymore and just a quick push of the button on the steering wheel and I'm at high boost! This function can also work as a ghetto traction control on launch. I wired the button in after the steering column so that I didnt have to worry about the wires wrapping around the steering wheel. I let honda fix that problem for me.
I'm not on my home computer but I will post the wire colors that I used next time I'm on.
Old 10-16-2003, 07:45 PM   #11
revhigh96
revhigh96's Avatar
I was just looking on greddy's site and it says that wireless button they make will work on any of their profec boost controllers. This means that the wired one I posted should work on the A. Somebody check it out and post back. Remember the entire mod costs all of like $3!
Old 10-16-2003, 08:11 PM   #12
rjardy
Send a message via AIM to rjardy
Default Re: (revhigh96)
The back of the A is the same, if you look around, the greddy switch will work on both A and B controllers, so there is no reason this trick wont work.
Rob
Back to civilian life, and adapting well http://images.honda-tech.com/set1/smile/emsmile.gif
rjardy is offline   Reply With Quote
Old 10-16-2003, 08:31 PM   #13
torr
Default Re: (rjardy)
so do you have to hold the button? or is it one press to turn no high boost, then press again to turn off? Also do i have to setup my profec to run this, as i see nothing about it in the book? thanks for the great post
Old 10-16-2003, 10:16 PM   #14
I Like Boost
I Like Boost's Avatar
Send a message via AIM to I Like Boost
Default Re: (torr)
So i plug the stero jack into my proflec b, then how would i hook it up to my cruise control button?
Turbo GS-R 350whp
Turbo MKIII Supra 400whp
Turbo SRT-4 ???whp
I Like Boost is offline   Reply With Quote
Old 10-17-2003, 06:54 AM   #15
ScottEK
ScottEK's Avatar
Default Re: (IMPULSE B18C-T)
It acts just like pressing the button on the face of the Profec B to switch between lo and hi boost modes.
Old 10-17-2003, 07:46 AM   #16
VaporTrail
VaporTrail's Avatar
Send a message via AIM to VaporTrail
it should also work with the Profec E-01
[B]<U>1995 240sx SR20DET</U>[/B] - GT25R, widebody, 400whp too much to list
VaporTrail is offline   Reply With Quote
Old 10-17-2003, 11:00 AM   #17
revhigh96
revhigh96's Avatar
Like Beta13 said above it is just like pressing the button on the front of the profec. To hook it into the cruise control buttons just look up the color of the wires that go to the button and use the button as a normal momentary switch. I'll try to get a wiring diagram or atleast colors or something by tonight.
Old 10-17-2003, 06:19 PM   #18
Pengo
Pengo's Avatar
Send a message via AIM to Pengo
nice job man
remember when i did the hacked up insulation mono plug solution? it did work fine, but i would always check the connection in the back to make sure it didnt come loose. still, i'm sure the stereo plug would work a lot better since it'd be in all the way and there's no risk of losing connection. that's some nice work there. too bad i'm gettin outta the honda game. but i'm sure it'll be useful if i go boosted agn in the future. props to finally figuring out the clean solution
[url="http://www.honda-tech.com/zerothread?id=1275439"]94 Captiva Blue Del Sol (FS in NY area)[/url]
-MY98 Scooby Impreza - Stock, Bone Stock
Pengo is offline   Reply With Quote
Old 10-18-2003, 01:41 AM   #19
toxicshit
nice post !!!
toxicshit is offline   Reply With Quote
Old 10-18-2003, 07:58 AM   #20
revhigh96
revhigh96's Avatar
Thanks again for the comps. Lets keep this post on top so everybody can check it out!
Old 10-18-2003, 11:06 AM   #21
NyQuiL
NyQuiL's Avatar
Send a message via AIM to NyQuiL
i just got my profec b spec II a week ago. I was also plannin on purchasing the greddy switch, but im really gona try to rock this instead. Pics or wiring diagram would rock.
again badass post
Previous: Z32TT/DC4/GST/S14/MS3
Current: 06 Civic Lx Coupe - mpg monster
NyQuiL is offline   Reply With Quote
Old 10-19-2003, 08:21 AM   #22
revhigh96
revhigh96's Avatar
Default Re: (NyQuiL)
Here is a quick wiring diagram.
Today I am going to go to radio shack and construct another one so I will have part numbers and step by step pictures of where to solder. I have allready been contacted to see if I will make them. If you want one made just tell me what type of switch you want and how long you want the wire to be and I will shoot you back what it will cost. I promise I will be really fair with the price.
Old 10-19-2003, 08:37 AM   #23
FredoSP
FredoSP's Avatar
can't wait!
400+ Whp Club
Old 10-19-2003, 10:51 AM   #24
Pengo
Pengo's Avatar
Default Re: (FredoSP)
for those who have a momo wheel and dont use their horn, u can use the horn button as ur momentary switch. this is what i used to do on my boosted sol. it worked great, and i think would prob be more reliable if i converted over to stereo plug like revhigh96. honestly i think the greddy IR switch stands out too much anyway and looks like some infants toy.
Old 10-19-2003, 02:27 PM   #25
b16booster
b16booster's Avatar
Default Re: (Pengo)
Hey pengo, how did you feed the wire through the hub so it won't twist when you're making turns?
b16booster is offline   Reply With Quote
button, greddy, horn, lo, make, momo, place, plug, profec, spec, supra, switch, tutorial, twist, wire
