Car jerks in first gear and sometimes in what ever gear while driving
Old 08-04-2003, 06:51 PM
hybridEj6's Avatar
Default Car jerks in first gear and sometimes in what ever gear while driving
My car will jerk violently in first gear if i dont let the car idle for a little, also in other gears sometimes.
Old 08-04-2003, 07:09 PM
altoid's Avatar
Default Re: Car jerks in first gear and sometimes in what ever gear while driving (ekhybrd)
what car what motor
Old 08-04-2003, 07:33 PM
hybridEj6's Avatar
Default Re: Car jerks in first gear and sometimes in what ever gear while driving (altoid)
99 civic b18c
Old 08-04-2003, 08:19 PM
NonovUrbizniz's Avatar
you sure it's not just the dropping/raising of idle during normal high idle clutch engagement.
My car bucks like a F*ck when it's warming up if I don't over gas the crap of it and feather the clutch...
If this is your problem you may want to consider tightening your motor mounts...
Is the warm-up idle rough?
Old 08-05-2003, 04:28 PM
hybridEj6's Avatar
Default Re: Car jerks in first gear and sometimes in what ever gear while driving (NonovUrbizniz)
it only happened if i dont let the car idle for a little. Then sometimes after i get on it, it will jerk a little in higher gears like third fourth and fifth. not as dramatic though
Old 08-05-2003, 06:19 PM
AngryTR0LL's Avatar
Is it a misfire? Does it misfire under a load? Do you know what it feels like when an engine is misfiring because a faulty ignition component? Check your spark plugs, plug wires and rotor/cap.
Old 08-05-2003, 06:20 PM
it's because the idle is higher than normal so when you put in the clutch it's reving at a higher rpm then you're used to so if you shift you are gassing it the same as if it were at normal idle speed... so it bucks a little... you can give it more gas and let the clutch out a little more slowly and it won't do it... that or let the car come up to temperature...
It happens more with cars in need of a tune up... so if you're behind on any of the normal maintanance items you may want to go ahead and catch up.
Old 08-06-2003, 06:39 PM
hybridEj6's Avatar
do you think the the distutor sub assembly could have something to do with it? my car is throwing a code 8 right now( well only when i get on it sometimes) so its stored in the ecu
Old 08-06-2003, 07:16 PM
It could be but generally it's just a general out of tune symptom..
that code is your tdc sensor which you don't really want to go... I'd replace the dist.
Old 08-06-2003, 10:05 PM
hybridEj6's Avatar
i was told i just need to replace the sub assembly, i just put a brand new 250 dollar ignitor in there and its still acting GAY!!!!!!!!! Today during the middle of the day that **** was acting weird like 3/4 power, you think heat has something to do with it at all?
Old 08-07-2003, 09:18 AM
the ignitor won't fix the tdc sensor or the dist... sounds to me like you need a new distributer...
heat could have something to do with it but not the most likely thing... a brand new ignitor shouldn't malfunction do to heat... although it's certainly not operating at peak...
the code you're throughing indicates you need a new dist.
Old 08-09-2003, 09:07 PM
hybridEj6's Avatar
you cant just buy the sub assembly? i have a msd 6al ignition could i use the the distributor cap on the new sub assembly or distributor?
cstone
01-17-2011 07:42 PM
MLevinson
06-22-2008 06:35 PM
napalm588
11-05-2007 06:46 AM
lunarone
09-20-2007 05:28 PM
Quick Reply: Car jerks in first gear and sometimes in what ever gear while driving
