B20 /Vtec WHAT water pump to use??
Old 07-08-2003, 09:33 PM
Dan GSR's Avatar
Default B20 /Vtec WHAT water pump to use??
I have a B20B long block
I also have a B16 long block
B20 water pump is 19 tooth
B16 water pump is 22 tooth
What is the GSR tooth?
Can I use the B16 water pump on my B20/vtec and use a GSR timing belt?
Any advantages/disadvantages to using a non-vtec or vtec water pump?
Old 07-09-2003, 06:09 AM
irev210's Avatar
Default Re: B20 /Vtec WHAT water pump to use?? (Dan GSR)
you cant use a b16 water pump
here are the ideas behind a gsr pump
the water doesnt move as fast, hence better for high rpm.
The longer the coolant stays in the radiator, the better it cools down
w/ a LS pump it is designed for lower RPM operation, so high RPM action means that the coolant doesnt recover in the radiator for long enough time.
blah lbah blah
i dont think there is much difference
if your replacing, you might as well go with the gsr pump/belt
Old 07-09-2003, 06:53 AM
Integra-T's Avatar
Yes you can use the B16 water pump. I am using one. All B series DOHC VTEC water pumps have 22 teeth. You can only use the GSR timing belt if going with a VTEC water pump.
Old 07-09-2003, 12:07 PM
AzG35's Avatar
Yes, you can use a b16 water pump with GSR belt. If you use the B20 pump, you have to use a B20 belt. B16 pumps are the same as ITR/GSR. Oil pumps used to be different, but Honda only produces 1 now for all B series VTEC motors, and B20s too.
Old 07-11-2003, 04:02 AM
irev210's Avatar
Default Re: B20 /Vtec WHAT water pump to use?? (Integra-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra-T &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can use the B16 water pump. I am using one. All B series DOHC VTEC water pumps have 22 teeth. You can only use the GSR timing belt if going with a VTEC water pump.</TD></TR></TABLE>
hrm go figure
Old 07-11-2003, 07:05 AM
Dan GSR's Avatar
Default Re: B20 /Vtec WHAT water pump to use?? (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">
hrm go figure
irev210 what do you mean? do you agree?
Old 07-11-2003, 07:54 AM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can use a b16 water pump with GSR belt. If you use the B20 pump, you have to use a B20 belt. B16 pumps are the same as ITR/GSR. Oil pumps used to be different, but Honda only produces 1 now for all B series VTEC motors, and B20s too.</TD></TR></TABLE>
i concur.
hrm go figure</TD></TR></TABLE>
i think it means he gets it now..or now, he knows.......(?)
Old 07-11-2003, 08:00 AM
BROOD's Avatar
You have two choices (reguardless of what ITR, GSR, B16, etc.)
19 tooth water pump is a non-Vtec pump
22 tooth water pump is a Vtec pump
Vtec engines operate at higher rpms than non-Vtec engines, to sustain proper heat transfer capacities of the cooling system the water pump pully diameter is increased, slowing down the pump.
Vtec water pump on B16A block - use Vtec B16A timing belt
Vtec water pump on B16B, B18B, B18C,etc blocks - use Vtec B18 timing belt
nonVtec water pump on B16A, B18B, B18C,etc blocks - use nonVtec B18, B20 timing belts
The water pump pully dameter and cylinder block height determine what timing belt you must use.
Old 07-11-2003, 10:45 AM
Kataku2K3's Avatar
Default Re: B20 /Vtec WHAT water pump to use?? (SLPR)
VTEC pump... B18C timing belt... It's that simple... Latez
Corksil
22
01-25-2011 07:57 PM
untitled
07-25-2003 11:51 AM
built562
05-04-2003 07:27 PM
getgot2
12-22-2002 12:54 PM
Quick Reply: B20 /Vtec WHAT water pump to use??
