how do you tell if a water pump is bad
Old 06-10-2003, 10:26 AM
af97civic's Avatar
Default how do you tell if a water pump is bad
i know when the seal goes it leaks out the weep hole,but is there another way you can tell if the shaft is broken or if im missing and impellor blade?any help will be appreciated.peace
Old 06-10-2003, 10:41 AM
JimBlake's Avatar
Default Re: how do you tell if a water pump is bad (af97civic)
Sometimes the bearings just start making noise even if they don't leak or wobble.
I had one where the bearings got loose. It made rattling noises as the impeller hit the housing. When I took off the belt it was so loose I could wobble the pulley back & forth.
I think a broken shaft wouldn't hold the pulley in place & you'd throw your timing belt. Also, it wouldn't move any coolant & you'd overheat. Loose pieces of the impeller might jam it up, then you'd throw your timing belt. If I had any possible reason to suspect this, I'd take off the timing belt & inspect the pump really good. Throwing a timing belt is never a good thing.
Old 06-10-2003, 10:49 AM
af97civic's Avatar
ok,cause i have been overheating pretty badly,and ive replaced coolant,thermostats,and a blown head gasket.but this is the last straw if it ain't this i am going to get another motor.
Old 06-10-2003, 12:26 PM
Crazydave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by af97civic &raquo;</TD></TR><TR><TD CLASS="quote">ok,cause i have been overheating pretty badly,and ive replaced coolant,thermostats,and a blown head gasket.but this is the last straw if it ain't this i am going to get another motor.
Bad Radiator...
leaking hoses...
bad cap...
bad fan / or fan switch, sensor
Old 06-10-2003, 12:27 PM
Crazydave's Avatar
Default Re: how do you tell if a water pump is bad (Crazydave)
if you blew a head gasket..
maybe it's a bad head..
Old 06-10-2003, 01:31 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">if you blew a head gasket..
maybe it's a bad head.. </TD></TR></TABLE>
Yeah, 'cause if it was any of the other stuff like hoses, he'd probably have figured it out by now.
06-17-2009 05:19 PM
B18C1NMotion
11-20-2007 11:27 AM
NotMYHonda
11-27-2005 06:09 PM
zracer240
08-01-2005 10:07 AM
turrismaldon
10-29-2002 07:33 AM
Quick Reply: how do you tell if a water pump is bad
