Fluidyne Radiator for 90 CRX Si with B16a?
Old 05-21-2003, 09:55 PM
NiMhist's Avatar
Default Fluidyne Radiator for 90 CRX Si with B16a?
Will the half size Fluidyne for a 90 CRX Si be sufficient for a B16a equipped car?
Old 05-21-2003, 10:11 PM
matt j's Avatar
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (NiMhist)
yes it should be
Old 05-22-2003, 06:59 AM
Fred n J_v2.0's Avatar
they make a half size specific for the crx or are you going to use the one for a 92-95?
Old 05-22-2003, 07:02 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiMhist &raquo;</TD></TR><TR><TD CLASS="quote">Will the half size Fluidyne for a 90 CRX Si be sufficient for a B16a equipped car?</TD></TR></TABLE>
Yes it will be. So then you will be getting the half sized for the CRX from fluidyne correct? Caue it should be a thicker radiator as well.
Old 05-22-2003, 07:09 AM
REDBARON's Avatar
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (Vinceg99)
FYI
I have a CRX HF with a B16, and I didn't change the radiator. It's almost been a year, and I've never had any problems.
Old 05-22-2003, 08:50 AM
slowpokesi's Avatar
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (REDBARON)
me 2
and i live in texas and only run 1 fan
texas=where lucifer and all the other sinners live.
Old 05-22-2003, 09:51 AM
INTEGRAMIKE's Avatar
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (slowpokesi)
why not use the fluidyne crx rad rather than the 92-95 civic its only 25$ more
Old 05-22-2003, 09:55 AM
FourthGenHatch's Avatar
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (INTEGRAMIKE)
Probably not what your looking for but this site sells double thick replacement Radiators for pretty cheap, I've heard the product is good...
http://www.absoluteradiator.co...rod=9
Old 05-22-2003, 10:19 AM
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (FourthGenHatch)
I just priced those out $337.99 for the civic rad. and $363.99 for the crx.
Old 05-22-2003, 10:28 AM
wickedEFguy's Avatar
I've got the full size fluidyne radiator in my car and I had no fitment problems even still has the fan, I'm not sure about with the B16 though but from I've read it'll fit just fine and there about the same size
you planning on going with some crazy Turbo header or something?
Old 05-23-2003, 01:41 PM
NiMhist's Avatar
Default Re: Fluidyne Radiator for 90 CRX Si with B16a? (Ninja_Jc7)
Sorry I didn't reply sooner but I'm in the middle of moving. I don't have very much room in between the fan and header so I figured I would use a half size just in case I need room at a later date.
Thanks for the replies.
msinsky14
02-17-2007 02:10 PM
hatchinprogress
10
12-29-2005 07:37 AM
bman2033
08-11-2005 02:53 PM
b18-c-rx
16
01-17-2005 11:40 AM
jcivic
01-17-2003 03:50 PM
Quick Reply: Fluidyne Radiator for 90 CRX Si with B16a?
