My B20 into EK parts list
Old 10-30-2007, 11:02 AM
  #26
* B A N N E D *
ASHi's Avatar
Default Re: My B20 into EK parts list (ebrakeracin4)
when doing this swap, what head did you use? i am planning on doing this swap sometime very soon and plan on using a b16 head. what if any modification will be required? also is this swap possible using the cable trans?
Old 10-30-2007, 01:44 PM
  #27
* B A N N E D *
ASHi's Avatar
Default Re: My B20 into EK parts list (ASHi)
bump
Old 10-31-2007, 09:40 PM
  #28
* B A N N E D *
ASHi's Avatar
bump it up.....also how well does the b series trans hold up
Old 11-01-2007, 11:02 AM
  #29
* B A N N E D *
ASHi's Avatar
can i get a reply here please
Old 11-04-2007, 07:02 AM
  #30
MeetyourconnecT's Avatar
Default Re: My B20 into EK parts list (DevinW)
Old 11-04-2007, 11:32 AM
  #31
* B A N N E D *
ASHi's Avatar
Default Re: My B20 into EK parts list (MeetyourconnecT)
anybody with some help for me???
Old 11-05-2007, 04:10 PM
  #32
* B A N N E D *
ASHi's Avatar
what a bunch of ******* ******** u guys are....no wonder people dont like u
Old 11-06-2007, 02:24 PM
  #33
* B A N N E D *
ASHi's Avatar
F!ck this forum just a bunch of ricer pussies in here
Old 11-07-2007, 04:18 PM
  #34
* B A N N E D *
ASHi's Avatar
so i come on here to try get some help to make more power in my car and the ricer site has no one who can provide any assitance.....its a good thing my im able to put 14s downs unlike u bastard in here all og u go fuckk yourselves
Old 11-07-2007, 04:24 PM
  #35
ekb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHi &raquo;</TD></TR><TR><TD CLASS="quote">so i come on here to try get some help to make more power in my car and the ricer site has no one who can provide any assitance.....its a good thing my im able to put 14s downs unlike u bastard in here all og u go fuckk yourselves </TD></TR></TABLE>
go make ur own thread moron...how do you expect to get help when your posting every minute
Old 11-28-2007, 07:50 PM
  #36
rwlangdale's Avatar
Default Re: My B20 into EK parts list (ekb16)
i still havent finished my swap yet, but im finally putting it all together. no what if i want to keep the powersteering and ac, which would i use?
Old 11-30-2007, 11:49 AM
  #37
thereturn
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">
go make ur own thread moron...how do you expect to get help when your posting every minute</TD></TR></TABLE>
why dont you u *** off, look at how far apart the posts are and look weeks later there is still no reply so once more *** u and all the ******s on this forum...******* fudge packers
Old 04-04-2008, 11:59 AM
  #38
sicboxr's Avatar
Thanks for this info! I'm using it for a b20b into my eg. I was also wondering if my power steering or a/c would be affected by the swap.
Old 04-08-2008, 05:03 AM
  #39
AGENT 99's Avatar
Default Re: (sicboxr)
You are God!! This thread is a life saver!!
I'm swapping a b20b/z (haven't decided yet) into my 98 civic dx. This writeup is immensely helpful.
Old 04-08-2008, 05:36 AM
  #40
AGENT 99's Avatar
Default Re: (AGENT 99)
I took the liberty of making a "NEED TO BUY" parts list for this b20&gt;96-00 civic swap
MISC:
wiring harness
crv alternator +2 mounting bolts
94-00 ls starter + 2 mounting bolts
96-00 LS intake manifold- loaded
96-00 LS throttle cable
96-00 LS intake manifold gasket
96-00 EVAP purge solenoid
96-00 IAT sensor
B series header (99-00 si, 94-00 teg)
96-00 LS exhaust manifold gasket
MOUNTS:
99-00 si rear mount bracket
94-00 LS/GSR/Type R front trans mount bracket
96-00 CRV driver’s side front lower engine mount bracket
99-00 si timing belt bracket (possibly, unsure)
ECU:
96-00 OBDII LS ecu p75
Transmission:
LS Hydraulic
LS trans mounting bolts
clutch fork
clutch fork pivot bolt
clutch fork release spring
Clutch:
99-00 si or LS/GSR/Type R
Any b series flywheel
94-00 Integra NON ABS axles/intermediate shaft
94-00 LS/GSR/Type R shift linkage + bolts/washers/bushings
Old 04-11-2008, 01:53 PM
  #41
AGENT 99's Avatar
Whats the deal with the crank angle sensor and oil pump?
I'm now hearing that I'll have to replace the oil pump?? WTF?
Old 04-11-2008, 02:08 PM
  #42
Turbogixxer's Avatar
You again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 &raquo;</TD></TR><TR><TD CLASS="quote">MISC:
wiring harness
96-00 EVAP purge solenoid NO!!! Emission only
96-00 IAT sensor REUSE your stock one
96-00 LS exhaust manifold gasket REuse the b20. All b-series exhaust are the same</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 &raquo;</TD></TR><TR><TD CLASS="quote">ITransmission:
LS Hydraulic Any b-series
LS trans mounting boltsB and D series are the same
clutch fork
Clutch:
94-00 Integra NON ABS axles/intermediate shaftIt does not matter ABS or not
94-00 LS/GSR/Type R shift linkage + bolts/washers/bushings</TD></TR></TABLE>
Old 04-11-2008, 02:09 PM
  #43
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 &raquo;</TD></TR><TR><TD CLASS="quote">Whats the deal with the crank angle sensor and oil pump?
I'm now hearing that I'll have to replace the oil pump?? WTF? </TD></TR></TABLE>
No
Old 04-11-2008, 02:28 PM
  #44
AGENT 99's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">You again
Seriously, thank God you're hear!
I'm so [freak]ing confused. Didnt help that I just read all kinds of questions from a guy called b20guy in the archives who swapped a b20z into a 96 dx. My car is a 98 dx. He had to re-wire the dist and everything.
:headache:
Old 04-11-2008, 07:46 PM
  #45
AGENT 99's Avatar
No</TD></TR></TABLE>
So tell me whats going on here, for example:
http://cgi.ebay.com/ebaymotors...ZWDVW
Read the description where it talks about 99 and up oil pump. I are confuse!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by AGENT 99 »
MISC:
wiring harness
ITransmission:
clutch fork
Clutch:
Whats with "emissions only" on the evap? If I keep it obd2, I thought I had to have that.
Man, after this is over, I'm paypal'ing you for the help!
Modified by AGENT 99 at 12:05 AM 4/12/2008
Old 04-11-2008, 08:13 PM
  #46
You are making me work for this, eh
First things first. Honda added the sensor to the crank to be able to ID cylinder miss-fires that OBD2 standards needed (SAE). The fact of the matter is, you do not need it to run the car. If you run a OBD2 ECU, it will throw a code for it if you do not have it wired up. You catch what I am saying now?
You do not need evap. It will throw a code if you run OBD2, but like I have told you before, I would run OBD1 to get a map that will wokr with the B20 better
Old 04-11-2008, 08:26 PM
  #47
AGENT 99's Avatar
Sounds like I'm better off converting down to obd1 for simplicity.
Old 04-11-2008, 08:29 PM
  #48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like I'm better off converting down to obd1 for simplicity.</TD></TR></TABLE>
There you go
plus, you can get cool things like this for OBD1: http://www.hrtuning.com/pages/...w-lcd
Old 04-11-2008, 09:18 PM
  #49
AGENT 99's Avatar
There you go
plus, you can get cool things like this for OBD1: http://www.hrtuning.com/pages/...w-lcd</TD></TR></TABLE>
Nice to see we're on the same page!
Isnt that item alot like a safc?
Old 04-12-2008, 03:23 AM
  #50
No, it gives you data, but hacking your map signal
Quick Reply: My B20 into EK parts list
