B16A1 Parts
B16A1 Parts
If I put a B16A1 in my 1990 Civic hatch, what car parts do I buy for the engine? like, Del Sol parts? Integra parts? etc. etc. Thanks.
Re: B16A1 Parts (Home Skillet)
LIST NUMBER #1
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol"
List NUMBER #2
Maintenance Items:
Gaskets Head gasket = US '94+ DelSol VTEC
Valve cover gasket = US '94+ DelSol VTEC
Spark plug O-ring gaskets = US '94+ DelSol VTEC
Intake manifold gasket = US '94+ DelSol VTEC
Exhaust manifold gasket = US '90-7 Integra or US '94+ DelSol VTEC
Spark Plugs = Any US B series motor
Cap and Rotor = US '90 Integra
Spark Plug Wires = Any US B series
Thermostat = US '90-1 Integra, US '94+ DelSol VTEC, '99+ Civic Si
Timing Belt = US '94+ DelSol VTEC
Water Pump = US '94+ DelSol VTEC
Lower Radiator Hose = '91 Integra
Upper Radiator Hose = Universal, may need trimming
Alternator = '90 Integra
or 94 GSR alternator, which puts out 90 amps
Oil Pan = Any US B series
Oil Pump = 94 DelSol VTEC
Crank Pulley = Any US B series
Clutch = US '92 Integra GSR
Pressure Plate = US '92 Integra GSR
Pilot Bearing = Any US Civic/Integra
Throw-out Bearing = US '91-2 Integra, P/N 22810-ps1-015 $47.05
Flywheel = Any US B series
Axles = http://www.raxles.com, can use others, but best solution.
Intermediate Shaft = US '94+ DelSol VTEC
Mounts = http://www.hasport.com
Shift Linkages = http://www.hasport.com
Headers = best to use JDM B16
ANOTHER LIST:
Water Pump 19200-P30-003 94 - del sol $86.28
Head Gasket 12251-P30-014 94 - del sol $57.56
Oil Control Orfice O ring 15142-PH3-003 94 - del sol $1.36
Intake Manifold Gasket 17105-P30-004 94 - del sol $8.26
Exhaust Manifold Gasket 18115-P30-013 94 - del sol $11.30
throttle Body Gasket 16176-PR3-010 90-91 integra $4.71
Pcv valve 17130-PM6-G01 94 - del sol $11.98
Timing Belt 14400-PR3-004 94 - del sol $48.72
Alternator Belt 31110-PR3-003 94 - del sol $7.56
Tensioner 14510-P30-003 94 - del sol $50.94
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) $11.69
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) $2.76
Cap & Rotor Assembly 06303-PR4-000 90-91 integra $24.54
Rotor (If needed seperately) 30103-PR3-016 90-91 integra $6.87
Clutch Cable 22910-SK7-A02 90-91 integra $45.54
Throttle Cable 17910-SK7-A03 90-91 integra $17.18
Cam Seals (2) 91213-PR3-004 94 - del sol $8.52
Oil pan seal 11251-P30-004 94 - del sol $18.64
Oil Filter 15400-POH-305 94 - del sol $4.93
Shift linkage bushing 54303-SB2-010 90-91 integra $4.66
crank seal 91212-PR3-003 94 - del sol $5.78
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) $12.00
Valve cover grommets (8) 90442-P30-000 94 - del sol $20.80
Spark Plug O rings (4) 12342-P66-000 94 - del sol $7.16
Rubber plug for exhaust cam tranny side 94 - del sol $4.00
Spark Plugs (4) BKR6E-N11 NGK $8.00
Upper Radiator Hose 19501-PR3-000 92 - integra gsr $14.71
Lower Radiator Hose 19502-PR4-A00 90-91 integra FREE BY MISTAKE
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol $5.62
Washer for coolant drain on block 90401-PR4-000 94 - del sol $3.00
Re: B16A1 Parts (WindyIce)
ok, thanks a lot. But now what type of I,H,E do I buy and other performance modifications like pistons, cams, etc. for this car? Also, any links to where I can buy any of the parts mentioned would be of great help.
luckybull
12-26-2003 03:16 PM
bluecrxsi
22
02-25-2003 04:47 PM
Monty
09-07-2002 05:41 AM
19501pr3a00, 91212pr3003, 94, b16a1, del, installing, integra, oil, oring, parts, pump, series, sol, sparkplug, thermostat, vtec
