Need a copy of the Fuse locations for 92-95 civic!! Brake lights are out...
Old 04-20-2003, 11:18 AM
UpstateCivic's Avatar
Default Need a copy of the Fuse locations for 92-95 civic!! Brake lights are out...
I lost my Haynes manual as well as the insert that's under the dash. My brake lights are out but I replaced all of the bulbs. Are the taillights on the same fuse as the brakes? I searched and found a diagram for a 99 EX, and it said they were. Is it the same for 92-95 then?
Old 04-20-2003, 11:24 AM
lsvinny's Avatar
what i came up with is fuse # 52 under hood
Old 04-20-2003, 11:32 AM
Default Re: (lsvinny)
Checked all the fuses under the hood, nothin....
Old 04-20-2003, 11:35 AM
lsvinny's Avatar
Default Re: (UpstateCivic)
if your not getting power to the lights when you press the peddle down and all your fues are ok then
check brake light switch on the brake peddle.
Old 04-20-2003, 04:34 PM
drunknbass's Avatar
heres a diagram. i needed one too and i could never find one online
Old 04-20-2003, 04:41 PM
CXHatchback's Avatar
Default Re: Need a copy of the Fuse locations for 92-95 civic!! Brake lights are out... (UpstateCivic)
On my 92 hatch the brake light fuse was under the hood and was the same fuse as the horn. It actually should stay stop/horn on it I believe.
Old 04-20-2003, 04:42 PM
shane01itr36's Avatar
Great info....Keep it up..
Old 04-20-2003, 06:32 PM
buddha429's Avatar
Default Re: Need a copy of the Fuse locations for 92-95 civic!! Brake lights are out... (shane01itr36)
anybody have the diagram for the fusebox under the hood? thanks
Old 04-20-2003, 07:38 PM
Default Re: Need a copy of the Fuse locations for 92-95 civic!! Brake lights are out... (buddha429)
Awesome, thanks a lot guys. I'll check everything tomorrow when it's light out!
NYVALL
15
04-09-2012 06:22 PM
dbailey
07-25-2010 10:24 AM
Hakuna33
11-30-2009 12:56 PM
keepitngga1
07-18-2008 10:26 PM
nguyen726
14
03-16-2007 08:22 PM
Quick Reply: Need a copy of the Fuse locations for 92-95 civic!! Brake lights are out...
