The difference in compression between B20B VS B20Z
Old 04-11-2003, 08:21 AM
  #26
irev210's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (SpeedVelocity.org)
OKAY speed velocity, You need to be reported to a mod or something for blatently trying to promote your website. Go home... and stop posting about your b20, that has nothing to do with b20b vs b20z
irev210 is offline
Old 04-11-2003, 09:06 AM
  #27
Jeff C's Avatar
Dont post that stuff here. This is a good tech thread, not an appearance thread.
Jeff C is offline
Old 04-11-2003, 09:22 AM
  #28
daver's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (irev210)
you can probably tell which cams it has then, by the size of the throttle body. Correct me if i'm wrong, but the giraffe intakes' have a 56mm tb?
bigger TB = higher revving cams
smaller = lower
d
daver is offline
Old 04-11-2003, 09:32 AM
  #29
irev210's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (Jeff C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff C &raquo;</TD></TR><TR><TD CLASS="quote">Dont post that stuff here. This is a good tech thread, not an appearance thread. </TD></TR></TABLE>
exactly....
He pm'd me saying that he was "trying to help us by showing us what a b20 looked like"
Well, if u were trying to promote your name, "speed volocity" I will never buy anything or support anything from your website.
Good job
irev210 is offline
Old 04-11-2003, 10:43 AM
  #30
Brrraaaap!
Blaze45's Avatar
honestly, lease space in the banner thats on all the pages.
Blaze
Blaze45 is offline
Old 04-12-2003, 04:02 PM
  #31
The Rob's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (Blaze45)
All the info on mine:
Engine: 98 JDM B20b.
Head: P8R-7
Block: B20B, 5007274
Tranny: Auto
Cams: P75 Cams
Intake Manifold: Tall Intake Manifold from USDM B20b
Head Gasket: 3 Layer
Knock Sensor: None
Pistons: Unknown
Hmotorsonline.com said it was a 9.6:1 compression motor and they compression tested it before sending it to me. I am currently trying to find out how to tell if they told me the truth without pulling the head. The engine is not in a car yet.
The Rob is offline
Old 04-13-2003, 03:01 AM
  #32
Tr0LL's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors ( Rob)
You SURE you have a 3 layer head gasket? Did you look carefully? If so, then my theory about the 2 layer head gasket creating the 9.2 compression is probably right......
96-98 b20b with 3 layer headgasket (p3f pistons) = 8.8 whether it's JDM or USDM (however, the 97-98 b20b most likely has a 3 layer headgasket and 8.8 for sure anyway).
96-98 b20b with 2 layer headgasket (p3f pistons also) = 9.2 like the japanese honda website says. Perhaps only the 96-98 jdm b20bs with the low rise manifolds came with a 2 layer? possibly?
99+ b20b and b20z have the higher compression phk pistions and 9.6:1 compression
Unless someone else would like to explain it. I am 100% sure my 96 jdm b20b has a 2 layer head gasket...
Tr0LL is offline
Old 04-13-2003, 03:45 AM
  #33
daver's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (Tr0LL)
can some one explain his P8R-7 head stamp? Is that what they called the ls head in '98?
d
daver is offline
Old 04-13-2003, 09:34 AM
  #34
The Rob's Avatar
So whats the deal with the P75 cams?
Has anyone found a single B20b that didn't have p75 cams in it?
The Rob is offline
Old 04-17-2003, 10:20 PM
  #35
irev210's Avatar
im intrested in the P8R head... who else had a p8r head?
irev210 is offline
Old 04-19-2003, 08:49 AM
  #36
Brrraaaap!
Blaze45's Avatar
I have the P-75-5 head but it says p3f on the block. How do I tell what layer the headgasket is? Mine is thinner so I think I have the lower compressoin engine. It does not have the knock sensor on it and I dont know what cams were in it cause I sold em.
Blaze
Blaze45 is offline
Old 04-19-2003, 04:32 PM
  #37
daver's Avatar
where does it say p3f on the block?
d
daver is offline
Old 04-19-2003, 06:52 PM
  #38
Brrraaaap!
Blaze45's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (daver)
It says p75 on the IM but not on the cams. p3f is down where the tranny would bolt to block. Could I have to 9.2 compression engine?
Blaze
Blaze45 is offline
Old 04-19-2003, 07:03 PM
  #39
daver's Avatar
well, we do't know for sure if this 2 layer gasket p3f piston theory is true yet, but check where the head gasket sticks out and count the layers.
I'm still not clear on where it says p3f on your block. The front, the back, is it covered up by the tranny? I want to see if mine has it stamped on too, but its installed.
d
daver is offline
Old 04-19-2003, 07:21 PM
  #40
dmsticimport's Avatar
HELL YEA....
w00t
dmsticimport is offline
Old 04-19-2003, 07:38 PM
  #41
Brrraaaap!
Blaze45's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (dmsticimport)
hell yeah? what are you talkin about?
p3f is just below the IM and may be hard to see. Its right by the edge of the block about mid way from the bottom of the engine. How do I tell how thick my headgasket is?
Blaze
Blaze45 is offline
Old 04-19-2003, 08:13 PM
  #42
daver's Avatar
take a look at page 1 of this thread and troll has posted pictures of where you can see the head gasket sticking out. You should be able to just count the layers
d
daver is offline
Old 04-19-2003, 08:54 PM
  #43
Michael Delaney's Avatar
so JDM = USDM for the same years for the longblock...IM notwithstanding...why make the distinction then?
Michael Delaney is offline
Old 04-20-2003, 09:22 AM
  #44
The Rob's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (Michael Delaney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Delaney &raquo;</TD></TR><TR><TD CLASS="quote">why make the distinction then?</TD></TR></TABLE>
So they can lie, charge you more and tell you JDM=9.6:1.
Hmotorsonline.com will be changing their website info after the talk I had with Steve (The owner) a couple days ago. They thought all JDM motors were 9.6:1, so I had to straighten them out.
The Rob is offline
Old 04-20-2003, 09:59 AM
  #45
Brrraaaap!
Blaze45's Avatar
Yeah what did he say? I called him no answer, he charged me for the high comp engine and I didnt get it. What did he say? Id be intrested to find out what his excuse would be.
Blaze
Blaze45 is offline
Old 04-20-2003, 10:32 AM
  #46
irev210's Avatar
get password JDM to change their website aswell
u guys are starting a revolution! haha
irev210 is offline
Old 04-20-2003, 07:31 PM
  #47
Brrraaaap!
Blaze45's Avatar
Yeah well w/o you we would have never known....... a big thanks to you!
Blaze45 is offline
Old 04-20-2003, 07:54 PM
  #48
The Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah what did he say? I called him no answer, he charged me for the high comp engine and I didnt get it. What did he say? Id be intrested to find out what his excuse would be.
Blaze</TD></TR></TABLE>
He tried to play it off like it wasn't his fault. He did offer to exchange mine for a 9.6:1 comp motor if he could find one, but I suspect he will just turn around and go "Oh, I couldn't find one, your loss." I talk to him again tomarrow about it, and I'll let everyone here know what happens. I'd be happy with him sending me a set of PHK pistons and paying somebody to put them in for me.
I'm not about to swap the pistons on my own time for his mistake, and I won't keep an 8.8:1 comp motor.
-Rob-
The Rob is offline
Old 04-21-2003, 10:15 AM
  #49
Brrraaaap!
Blaze45's Avatar
Neither will I (put up with 8.8 compression). Im going to call him today and see if he will reimberse me cause @ the time he had a sale going on. It was 750 for the lower compression B20. I paid 800 for the higher one. Im pissed. I mean what can I do to make up the power?
Blaze
Blaze45 is offline
Old 04-21-2003, 12:55 PM
  #50
Brrraaaap!
Blaze45's Avatar
Default Re: B20B VS B20Z... The truth told, lets end the rumors (GSRslowandswap)
Why do they even waste thier time here? I can't figure some people out.
Blaze
Blaze45 is offline
Quick Reply: The difference in compression between B20B VS B20Z
