"HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (detailed instructions w/ pictures)
Old 03-06-2003, 05:29 PM
  #26
JeremyL's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (SlowRedTeg)
what is the benefit of doing this?
why couldnt one swap in the master cyl from a prelude, NSX, 4.2RL etc hell even an Odessy i would think should have some power coming out of the MC
JeremyL is offline
Old 03-06-2003, 05:49 PM
  #27
Armed Ferret's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (JeremyL)
in my car, swapping a full NSX MC is a clearance issue. later model cars may be different, and if so, then by all means take advantage of what you have available to you.
also, i've driven a 99 Si equipped with the ITR 5-lug conversion, stainless lines, EBC pads, brembo blanks; i also drove a '95 hatch with the fastbrakes 4-pot, and to be honest the 4-pot was, in MY opinion, too harsh for a daily driven vehicle. some may like stopping on a pinhead, but a dime is just fine with me. Also, if I have trouble with the caliper in the future, a rebuild will be a little easier to do as the parts will be more readily available. usually (not always, but a good chunk of the time) one has to contact wilwood directly for replacement parts. with the 5-lug it's as simple as going to the nearest dealership (of which there's 2 honda and 3 acura within a 35-minute drive of my house--all of whom stock nearly every small part, including bolts, seals, hoses, belts, and brake parts).
Armed Ferret is offline
Old 03-06-2003, 06:11 PM
  #28
JeremyL's Avatar
so other than clearance issues would any honda/acura mc work with a D integra? honestly i would love to have the touchiest brakes this side of the F1 track, disable or remove the ABS and give me soime calipers that could clamp the black hole shut
JeremyL is offline
Old 03-06-2003, 08:06 PM
  #29
maxxdout's Avatar
WOW, great info.
I have just one complaint. It concerns safety so i figured i would let it be heard. I noticed in the first post that the owner purchased 2 bottles of the Valvoline Synpower brake fluid. Here is my concern. This fluid is a fully synthetic DOT 5 fluid. The systems in our cars are designed to function on DOT3 only!! This is a concern because the DOT 5 fluid by nature when serviced and even under heavy use....such as racing or performance driving, is more suseptable to airiation: the forming of tiny air bubbles in the fluid that will gather to gether to cause air in the system. This will ultimatly lead to a low brake pedal when you arnt expecting it. Dont quote me on this. I will check tommorw to be sure but im almost positive.
Just a small note. However GREAT DIY!
maxxdout is offline
Old 03-06-2003, 10:30 PM
  #30
migs's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (maxxdout)
MAxxdot, no where on the bottle does it say it is certified as DOT5. Everywhere on the bottle it says DOT3 or DOT4.
migs is offline
Old 03-07-2003, 04:44 PM
  #31
JeremyL's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (Migs)
i just bought a bottle of the valvoline synpower and it was a DOT5 and the boiling point was a lot higher than all the other i could find at the parts store
JeremyL is offline
Old 03-07-2003, 04:56 PM
  #32
10K2HVN's Avatar
best i ever read!
10K2HVN is offline
Old 03-08-2003, 10:28 AM
  #33
sExy_TinKY's Avatar
props for the tech help!!
sExy_TinKY is offline
Old 03-13-2003, 09:37 AM
  #34
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (PatrickGSR94)
For $1018 you can get 11" front rotors w/ 4-pot calipers, plus 11" rear rotors that use the stock calipers, and all these fit under stock 15" wheels.
actually, i'm not doing this to be a *****, but the 11" front 4-pot kit that is now on the new fastbrakes site is for cars with 9.2" front stock rotors, which integras do not have. integras are 10.2" front rotors, and therefore must use the 11.75" front 4-pot kit which is nearly $1,300. This does not include the extra $300 for the rear kit. The 11" 4-pot kit is no longer available for integras/civics with 10" front rotors.
For this same price ($1,600) you can obtain a full JDM ITR 5-lug swap from passwordjdm.com and that comes with wheels and tires.
Old 10-05-2003, 05:23 AM
  #35
trutuner's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (G2 Pilot)
bump for a great tread!...-Roger
trutuner is offline
Old 10-12-2003, 09:41 PM
  #36
EK MONEY's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (Kryptonite)
EK MONEY is offline
Old 10-19-2003, 06:16 PM
  #37
jdmcivicek's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (Peagreenhatch)
nice DIY
jdmcivicek is offline
Old 01-09-2004, 10:39 PM
  #38
253EK's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (jdmcivicek)
TTT
thanks
253EK is offline
Old 03-10-2006, 06:08 AM
  #39
Help we my pennies
BLUE EH3's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (Armed Ferret)
please post a pic of a hub and a knuklce
BLUE EH3 is offline
Old 03-10-2006, 07:23 AM
  #40
Guess whos bizzack
It's*BOLO!!'s Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (BLUE EH3)
ow man NICE WRITE-UP, thanks for taking the time to do this to help people out!!!
It's*BOLO!! is offline
Old 07-11-2006, 10:32 PM
  #41
GranadaTeg's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (BOLO-FTW.)
Everything is straight forward, but what about the rear.
My question is, there is no way to get away with re using the GSR rear trailing arms and spindles?
Have any of you guys tried it? or are clearances impossible?
GranadaTeg is offline
Old 07-12-2006, 05:51 AM
  #42
ST4TUS's Avatar
very nice tut.
ST4TUS is offline
Old 07-12-2006, 06:34 AM
  #43
Li-tunner's Avatar
Great D.I.Y.
Li-tunner is offline
Old 07-12-2006, 07:51 AM
  #44
That's what she said!
Dforce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armed Ferret &raquo;</TD></TR><TR><TD CLASS="quote">here's the link to the instructions for this mod on the DA chassis.
http://www.jarofbees.com/tech/da_5lug/</TD></TR></TABLE>
link is not working.
Dforce is offline
Old 07-12-2006, 10:56 AM
  #45
GranadaTeg's Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (Slo Cord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Cord &raquo;</TD></TR><TR><TD CLASS="quote">Everything is straight forward, but what about the rear.
Old 07-12-2006, 01:35 PM
  #46
Comp97GSR's Avatar
The way I understand it, the GSR and ITR rear trailing arms are the same. However, you can not just swap the hubs. It is unsafe because the spindle nut won't thread all the way on. If you can source rear hubs/spindles you can swap them on to the arms. You can not purchase them from Acura without buying the complete trailing arm assembly.
Comp97GSR is offline
Old 07-15-2006, 09:08 AM
  #47
GranadaTeg's Avatar
I will be using the EK Civic Type R setup with 32mm axles.
When i need to replace them, can i use USDM Integra Type R axles?
Thanks.
Old 07-15-2006, 05:17 PM
  #48
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Cord &raquo;</TD></TR><TR><TD CLASS="quote">I will be using the EK Civic Type R setup with 32mm axles.
Thanks.</TD></TR></TABLE>
yeper
Old 08-10-2006, 09:05 AM
  #49
tofu__'s Avatar
Default Re: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (Comp97GSR)
**instead of making a new thread i figured I could get help here.
I recently picked up jdm itr 5lug conversion for my 99gsr w/abs.
i've searched plenty of threads and taking out the whole abs system is clearly a no for me now since it's a PITA.
What should I do? find parts for the optional jdm 5lug w/abs? if so What parts?
Or is there any way of installing the 5lug without removing abs?
tofu__ is offline
Old 08-10-2006, 10:42 AM
  #50
DeeSee4K20's Avatar
Great job on the write up very detailed.... i mlookin to do the 5lug setup also sooon on my dc4
for a goood DIY write up.
DeeSee4K20 is offline
Quick Reply: "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (detailed instructions w/ pictures)
