OT: Fact or Fiction: Gas lines can freeze?
Old 01-23-2003, 07:57 AM
RTW DC2R's Avatar
Default OT: Fact or Fiction: Gas lines can freeze?
is it true that your cars gas lines can freeze on a bitter cold morning, causing startup difficulties? or is this just a myth?
Sorry for the dumb question
Old 01-23-2003, 07:58 AM
SoCal ITR's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (RTW DC2)
I think it's true, but as long as you keep at least a half a tank in your car, then it would have to be REALLY cold before you had any problems.
Old 01-23-2003, 08:00 AM
Big Phat R's Avatar
It has to be very cold like minus 30-40 Celcius. Most cars have moisture in the tank and fuel line system that can start the freezing process. Methyl hydrate in the tank (line antifreeze) can prevent this by binding to the H20 so it won't freeze.
BPR - who used to live in Winnipeg brrrrrr
Old 01-23-2003, 08:02 AM
RTW DC2R's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (Big Phat R)
minus 30-40 C is how cold in F?
Old 01-23-2003, 08:03 AM
Chris N's Avatar
I would not leave the gas tank less than half full.
Old 01-23-2003, 08:06 AM
RTW DC2R's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (py1091)
why would it matter how much gas is in the gas tank? If I had 1/4 tank or a half tank, how is that gonna make a difference in it freezing or not?
BTW, my HONDA isnt the one that wouldnt start this morning...it was a WRX
Old 01-23-2003, 08:07 AM
Chris N's Avatar
Because I've had a gas line freeze with 1/4 - 1/8 a tank, never when mostly full.
farenheight = 32 + ( 9 * Celsius/5)
Old 01-23-2003, 11:42 AM
VTHokie's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (Chris N)
Cold (viscus) oil and a cold battery can also cause starting problems.
Old 01-23-2003, 11:47 AM
TypeR 01 886's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (VTHokie)
The more gasoline... the longer it takes to freez. In the tank at least... not sure about the line it self. Just throw a flare in the gas tank to warm things up... it works for me everytime, it worked reallty well on my GSR
Old 01-23-2003, 12:12 PM
Philly_NBP_R's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (TypeR 01 886)
lol
Burn it to the Ground...
Old 01-23-2003, 12:17 PM
GRM Scott's Avatar
so cold you would die.
haha, what are the odds? -40C = -40F
so 72 degrees below freezing on the Farenheit scale
http://people.uncw.edu/dixonrd/tempconv.htm
go internet
Old 01-23-2003, 01:18 PM
Dirt's Avatar
Doh! Civic tank was at 1/8 last night. Fired right up thankfully!
Old 01-23-2003, 02:45 PM
Chris N's Avatar
Moisture in the line freezes.
My S-03's drive like they are flat spotted when my car is left out overnight when VERY cold in chicago (like today!!). Takes a minute or two before that stops. Luckily i don't leave the car out very often at all.
Old 01-23-2003, 03:15 PM
RTW DC2R's Avatar
how does moisture get in there? im pretty sure im putting gas in my car, not H2O
Old 01-23-2003, 04:49 PM
juniordc2's Avatar
it was -41 celcius yesterday morning for me, and I only had a 1/8 tank full with the car plugged in. started up on first crank. this is on my 94 gsr, integra's are good cars.
Old 01-23-2003, 05:04 PM
nfn15037's Avatar
Default Re: OT: Fact or Fiction: Gas lines can freeze? (dc2gsr94)
Plugged in?
mahatma
11-27-2006 08:14 AM
rice a roni
11-18-2005 10:50 AM
null.
06-22-2005 07:03 PM
jspek29
12
03-23-2004 04:28 PM
Quick Reply: OT: Fact or Fiction: Gas lines can freeze?
