Nasty noise in reverse!!!
Old 12-22-2010, 04:48 PM
  #26
#1 Super Guy
94eg!'s Avatar
Default Re: Nasty noise in reverse!!!
My civic has done this pretty much ever since I put integra rear discs on it (over 5 years ago). Only does it in reverse and it's definitely coming from the rear brakes. I've always believed it was just noise from the semi-race pads.
If you search you will find reverse squeals and creeks are common among many performance cars. Especially ones with Brembo multi-piston calipers. My Acura TL Sport (front Brembo 4-pots) will squeal in reverse every so often. I think it's just a common trait of performance pads.
Old 01-04-2012, 09:53 AM
  #27
MindEddy's Avatar
My 1998 Accord EX just started making this weird "moose whine" noise from the rear, but only in reverse. It started immediately after the car sat in the driveway a week while we were gone for Christmas.
I'm going to check the back brakes, rotor this weekend...while trying to apply grease to an exposed front axle and wrap with plastic and duct tape.
I'm quite the mechanic.
Old 01-09-2012, 06:14 PM
  #28
MindEddy's Avatar
It was ALL brakes. I thought I'd done the back brakes, but was confused with my other old Honda. Replaced the pads and NO noise.
Old 01-14-2012, 06:50 PM
  #29
godslayer's Avatar
I just encountered the same noise and after a lot of inspection and verification that everything else was good I found that one of the boots on my passenger side rear caliper slide pin was damaged and dried out. The pin had to be tapped out of the caliper. Replaced the boot, greased & anti-siezed everything appropriately and am hoping I dont get this moose whine tomorrow morning when I take my car out of the garage.
edit: Nope. That wasn't it. Actually it made the groaning sound abuot 10X worse.
edit2: Replaced the caliper and it seems to be good again. The piston seemed to be firing, and retracting, like it should but it must have been on it's way out.
Old 07-31-2013, 02:43 PM
  #30
RedIntegraGSR's Avatar
Check the bolts that hold the caliper, to make sure they are really flush with the metal, not just tight. I had that moaning noise going in reverse and when braking. I checked the brakes, cleaned the pads and rotors, then went to install the bolts, I found I couldn't tighten the bottom bolt completely. I replaced the bolt and the noise is gone.
Old 08-22-2016, 03:28 PM
  #31
ksolo03's Avatar
Default Re: Nasty noise in reverse ?!?? (Cyborg Ninja)
Originally Posted by V-Grip! Teknic73
its your sensor on your brake pads.....change your brakes!
I think your're right , I was just told i need new rear brakes , I will replace and you.
Old 05-19-2017, 11:40 PM
  #32
ed87510's Avatar
Default Re: Nasty noise in reverse ?!?? (hungsteR)
Originally Posted by Super7
Mine has made the noise while braking in reverse AND while just coasting in reverse. And it's an intermittent problem. Makes me think it's something else. Wheel bearing maybe?
Old 07-14-2017, 11:04 PM
  #33
lmrhay's Avatar
Change your transmission fluid and see if the noise goes away.
nonohood69
06-12-2013 07:09 AM
wsuozzie
08-18-2006 10:17 AM
96teggynonVtec
04-13-2006 05:30 PM
Vitt1
09-07-2003 10:39 AM
Quick Reply: Nasty noise in reverse!!!
