F22 engine specs needed asap
Old 01-03-2003, 06:52 PM
BoostedH23a1's Avatar
Default F22 engine specs needed asap
i need the specs for the f22 non vtec and the f22 vtec just like this website has
http://raceseek.com/honda_specs.htm
Old 01-03-2003, 09:07 PM
One2chi's Avatar
Default Re: F22 engine specs needed asap (BoostedH23a1)
hope this helps
http://www.hondahookup.com/honda_eng...ison_chart.php
Old 01-09-2003, 05:04 AM
Default Re: F22 engine specs needed asap (5thgenaccordian)
no thats not what i mean.. i need like rod dia. sizes, crank specs... **** like that. mainly for the F22 vtec. im gonna build my H23 and i hear f22 crank is the same..not sure bout the vtec though.
Old 01-09-2003, 06:49 AM
niedejb's Avatar
Ive got a f22b1 crank out... Tell me what you want and I can measure it.
Old 01-22-2003, 10:33 AM
Default Re: F22 engine specs needed asap (niedejb)
do u have a micrometer.. if so measure the diameter or the rod jorunals and the main journals..
Old 01-22-2003, 10:38 AM
GZERO's Avatar
I'm interested in this as well
Old 01-22-2003, 10:48 AM
FastechAccord's Avatar
H23 and F22B1 rods are interchangeable, right?? I need to know for my buildup. The block leaves for Golden Eagle monday.
Old 01-22-2003, 12:19 PM
Default Re: F22 engine specs needed asap (EvoAccord)
thats what i hear but i just wanna make sure.. hell if u need some rods i have some.. pistons are still on them though
Old 01-22-2003, 01:20 PM
niedejb's Avatar
Unfortunately, now that I see the reply the crank is at the balancer.
But...from the OEM manual f22b1
Journal 1&4 : 49.984-50.008
2: 49.976-50.000
3: 49.972-49.996
5: 49.988-50.012
Taper (.005 max), O/R (.005 max), end play .10-.35, runout .030 max
Rod Journals :47.976-48.000
I'm a metric guy so these arent inches
Post if the H crank is the same
Old 01-22-2003, 03:02 PM
Gennady's Avatar
http://www.tubas.net/~drew/ner/resou...tailedhec2.htm
Old 01-22-2003, 03:21 PM
Default Re: F22 engine specs needed asap (Wont be beat)
beatiful.. thanks
holset b18c
05-23-2008 08:06 AM
non_Vtec4700
04-23-2004 06:26 PM
KS-R
11-19-2002 09:00 AM
Smurfylude
05-22-2002 10:03 PM
Quick Reply: F22 engine specs needed asap
