symptoms of bad tps sensor?
Old 11-17-2002, 04:57 PM
SIK IN DA HED's Avatar
Default symptoms of bad tps sensor?
just curious...
Old 11-17-2002, 05:04 PM
Honda4CX-T's Avatar
Default Re: symptoms of bad tps sensor? (dlplayboy)
.... Inconsistent Idle fluctuations when engine is COLD is a good sign for that TPS sensor to act up. Checking the voltage on that sensor would give more of a definate answer though.
Old 11-17-2002, 05:09 PM
tony1's Avatar
a check engine light...
Old 11-17-2002, 05:22 PM
TheIntegraGuy's Avatar
Default Re: symptoms of bad tps sensor? (tony1)
Man you have a lot of threads..Uhm..Bad TPS...
-Idling is off...(revs too high, or too low, or keeps jumping from high to low)
-bogging/lagging/sputtering
-car dying
There are a couple more that I can't think of, but it seems to me your problem has to do with fuel..As if the motor wasn't getting enough.
Old 11-17-2002, 10:18 PM
Default Re: symptoms of bad tps sensor? (Esone3)
define "a lot of threads". ive probably posted around 5 threads tryin to get some feedback. i dont see anything wrong with postin threads... im here to learn, too... ya know.
as for my problem... right now, i think its my distributor.. but it could be somethin else.
Old 11-17-2002, 10:23 PM
Hehe.. you shoud see me..I have about 798743 threads that all lead to the same problem.
As for you distributor, Hmm..Possibly...If everything is leading to it, just change the cap and rotor and see what happens. Did you try your wires?
Old 11-17-2002, 10:24 PM
ninesecrx's Avatar
Hunting idle....
Old 11-18-2002, 12:50 AM
Lei Siew Long's Avatar
-car dying
these were the symptoms i had when i had a bad TPS
Old 11-19-2002, 09:24 PM
boostin GSR's Avatar
Default Re: symptoms of bad tps sensor? (boostedeg6)
where would you go to fix the tps sensor?
-i mis shifted and bounced off the rpm scale, then my check engine light came on, and my car sputters and idles funny.. could this be the tps sensor or something else?
[Modified by BoostinGSR, 6:25 AM 11/20/2002]
Old 11-19-2002, 09:33 PM
AbaZ's Avatar
Default Re: symptoms of bad tps sensor? (BoostinGSR)
You will need to get a Multimeter/Fluke whatever, and probe The signal wire..
The tps works off a 5 volt system, you have 3 wires going to it, 1 ground, 1 positve 5 volt reference wire and your signal wire to your ecu.
I usually set my TPS's .45v Closed throttle, and its around 4.7 @ WOT.
Normally you really dont need to **** with them, unless you just installed it, Honda TPS's have tamperproof breakaway screws on them, so you will have to cut them off and install normal screws. If you want to make any adjustments.
Jeff Frank
But I'm thinking thats not your problem, whats your CEL code..?
[Modified by AbaZ, 6:33 AM 11/20/2002]
Old 11-19-2002, 10:49 PM
IntegD's Avatar
Sounds like you bent a few valves bro. I am the ******* king of misshifting...on the highway I misshifted and bent all 8 exhaust valves. Loping idle is a symptom I had...good luck.
Old 11-20-2002, 12:40 AM
Default Re: symptoms of bad tps sensor? (IntegD)
loping idle? exactly what do you mean by that? how did your car run when you drove it? ****... ive been thinkin it might be the valves.
Old 11-20-2002, 10:48 AM
IntegD's Avatar
I was talking to boostedgsr....but unless you had a big overrev...I doubt the valves would bend.
Old 11-21-2002, 10:45 AM
AbaZ's Avatar
Valve train float could easily happen, depending on how high is rev limiter was...?
I would do a compression check, and also a cylinder leak down test to isolate which cylinders.
Jeff Frank
Old 11-21-2002, 03:21 PM
Default Re: symptoms of bad tps sensor? (AbaZ)
well... i did not overrev my engine when the problem happened...
ive been too busy to do the compression and leak down tests. i will soon, though.
hurleypooper
04-29-2008 08:12 PM
xfrankix2
12
09-12-2007 08:10 PM
1990si
12-10-2006 11:31 AM
homeskillet
20
01-10-2005 02:28 PM
Quick Reply: symptoms of bad tps sensor?
