crx tire size
Old 11-12-2002, 08:52 AM
boonacka's Avatar
Default crx tire size
hey i'm a proud new owner of a 90 crx si. i need new tires and i was just wondering what is the widest tire i can go with on the factory rims? thnx
Old 11-12-2002, 09:00 AM
JoshDM's Avatar
Default Re: crx tire size (boonacka)
190 or 195
Old 11-12-2002, 09:02 AM
boonacka's Avatar
Default Re: crx tire size (JoshDM)
what aspect ratio with the 190 or 195?
SuperCivic's Avatar
i run 195 60 14s on stock size wheels.
Old 11-12-2002, 09:10 AM
Afausto_A's Avatar
Default Maybe not for street use but...
For auto-x, I've shoehorned 225/50R14 Toyo Proxes RA-1's on my '91. My car has the stock coils and
the tires are mounted on '86-'87 alloy ("four-hole", 40mm offset, 5x14") wheels with no problems with
clearance. Hope this helps!
--Afausto
white 1991 CRX Si
SCCA G-Stock
SoPac div, CSCC region
Old 11-12-2002, 09:15 AM
broncoman74's Avatar
Location: Northwest Hills of, CT., United States of America
I just priced out wheels and tires for my 1990 Civic Si Hb and the most they recommend is 205-40 17's. You can do 18 inch wheels but the ride will be horrible if you live anywhere with bumpy roads and potholes. Best thing to do is call up a nationwide type of tire and wheel dealer and have them look it up in their computer. If it were me I would not do any bigger width then the stock tire width unless you upgrade to the larger wheels. Honda is real good about testing and re-testing to find the best handling tire for their design. All you may accomplish by putting a wider tire on is more body roll and a better chance for the tire to come off the bead at higher speed cornering. I do not recommend changing it. Hope this helps!
[Modified by broncoman74, 6:22 PM 11/12/2002]
Old 11-12-2002, 09:30 AM
boonacka's Avatar
Default Re: crx tire size (broncoman74)
the factories came with 185/60 14's ... your telling me 195/60 14's would fit just right while maintaining the same overall diameter?
Old 11-12-2002, 09:35 AM
SuperCivic's Avatar
they'll be a little wider. i believe stock is 185/65/14, so they'll be the right height.
Old 11-12-2002, 12:17 PM
JoshDM's Avatar
diameter has got nothing to do with the width
learn your geometry
Old 11-12-2002, 12:43 PM
boonacka's Avatar
uhhh.. it has nothing to do with geometry mr einstein.. what i was asking about was the aspect ratio... i thought a factor crx tire was 185/60 and he said to use a 195/60 .. but i was misinformed about the factory aspect ratio.. read the whole thread first buddy before you decide to have a and make stupid statements .. cheers
[Modified by boonacka, 9:44 PM 11/12/2002]
Old 11-12-2002, 01:16 PM
Vinceg99's Avatar
I worked at Firestone for quite a few years....say you have the stock 185 60 r14's and you went with 195 60 r14's they will be a little taller, here's how the numbers go is like this 185 or 195 whatever the first number is is the width of the tire (duh everyone knows that!!) ok then the 60 or well whatever number 60, 65, 50....ect....is the height of the rubber but heres how it works the number is the percentage of the width so on a 185 60 r14 185 is the width 60 is 60% of the width (185) of the tire and well r stands for radial..lol...and well 14 is the rim size which is another thing everyone knew. Oh and stock for the Si is 185 60r14
[Modified by Vinceg99, 4:16 PM 11/12/2002]
Old 11-12-2002, 08:15 PM
boonacka's Avatar
Default Re: crx tire size (Vinceg99)
see thats what i thought.. 185/60 IS the factory spec.. that swhy i was questioning the 195/60 that they were telloing me to use.. maybe a 195/ 50 would work? or 195/55 .. i need a tire calculator...
Old 11-12-2002, 09:34 PM
Vinceg99's Avatar
There wont be much of a difference between the 185 and the 195 nothing that you would probably even notice but if you did want to be safe I would say that like you were saying the 55 series would probably work....but while your at it why dont you just step up to like 15's and then go with 50 series? Or do you just want to stick with the stock rims? Oh and the difference between 185 and 195 60series would be like 7 or so millimeters so not much...
[Modified by Vinceg99, 12:35 AM 11/13/2002]
Old 11-13-2002, 07:41 AM
1990hondaHF's Avatar
Here you go my friend: http://www.miata.net/garage/tirecalc.html
Old 11-13-2002, 07:46 AM
elmalouno's Avatar
-LOL hahahahaha
Old 11-13-2002, 08:59 PM
Default Re: crx tire size (elmalouno)
I'm not sure what exactly is funny, Could you fill me in please?
Old 11-14-2002, 08:40 AM
audioroach's Avatar
Its the 17" *bling..bling* factor thats all....at first we all wanted big rims (most of us) then we woke up....a smaller tire has less wieght and rotational mass therefore faster.....look into a15" or 16" wheel combo and have fun.
BarcodeCRXSI
04-12-2010 12:05 PM
Ish
19
12-25-2007 12:15 PM
SFlCrx
11-01-2007 02:50 PM
Noir
11
09-27-2006 10:02 AM
HondaHeddie
11-17-2005 10:35 PM
Quick Reply: crx tire size
