random misfires cyl 3 + 4
Old 08-29-2014, 05:37 PM
scarecrow0529's Avatar
Default random misfires cyl 3 + 4
timing belt broke on my 2000 crv, i replaced belt, tensioner and water pump. it started up just fine, i drove it for an hour with no problems. later that day i started it up again and it was running fine but the cel came on. checked the blink codes and came up with the random misfires on 3+4. could it be the valves need adjusting? wires, plugs and distributor all look good.
Old 08-30-2014, 07:30 AM
Default Re: random misfires cyl 3 + 4
i shouldnt say the timing belt broke. about 10 teeth were sheered off of the belt, the belt was still in one piece.
Old 08-30-2014, 11:04 AM
decided to take it for a test drive again today just to see if the cel comes on and it did so i took it to get the codes read. it came up with p1399. it still drives fine and accelerates nicely just when i come to a stop it idles super low, but when i take off its feels fine.
Old 08-31-2014, 06:38 AM
so i plan on doin the valve adjustment today and if that doesnt do it i will adjust the distributor to try and time it, if that doesnt work i will go buy a compression tester and test compression. if the compression is bad i can get a scope to shove in the cylinders to check around. any other ideas? thanks again.
Old 08-31-2014, 02:26 PM
ok did the valve adjustment. all but one of the exhaust valves were pretty tight and all but one of the intake valves were pretty loose. while putting the spark plugs back in i regapped them they were at .049 instead of .044. i took it for a test drive no cel and is running fine.
i am gonna test drive it again tonight and see if the cel comes on.
Old 09-01-2014, 05:24 AM
drove it again last night still no cel.
Old 09-02-2014, 02:42 PM
drove it for a couple hundred miles now. still no cel, runs fine. considering this a success.
Old 09-03-2014, 08:51 AM
dogbiscuit's Avatar
good job
Old 10-29-2014, 06:29 AM
Sooner1's Avatar
Probably valve adjust did the trick....higher compression engines tend to require more frequent adjusting
MyWhiteEJ6
12
11-10-2013 06:38 PM
1993dagsr
07-03-2010 09:37 AM
1993dagsr
07-02-2010 03:15 PM
1993dagsr
07-02-2010 10:28 AM
Teg6
12-11-2006 01:44 PM
Quick Reply: random misfires cyl 3 + 4
