2001 Honda Accord F18B, interference engine or not?
Old 08-24-2014, 03:42 AM
Hayat Solangi's Avatar
Icon2 2001 Honda Accord F18B, interference engine or not?
I have a 2001 Honda Accord (Japan) with F18B engine. How do I know whether my engine is an interference engine or a non-interference one? Tried searching on the web but didn't find any results.
Old 08-24-2014, 01:40 PM
holmesnmanny's Avatar
Yes
Old 08-24-2014, 06:58 PM
Default Re: 2001 Honda Accord F18B, interference engine or not?
Ok. So I was driving on the motorway at 120kmh when the engine shut off and I pulled off to the side. The car won't start; the timing belt had broke. I'm getting it installed today IA. What are the chances that the engine will start with no damage after installing the new belt? I was just getting worried
Old 08-24-2014, 07:01 PM
My mechanic said there was need to worry if it had been a Diesel engine but he said it is unlikely to cause damage to a petrol one and it will be fine after installing replacement belt. What do you think about this? Help would be appreciated
Old 08-24-2014, 10:57 PM
Sorry but it's almost a sure thing there will be damage. There are instances when there is luckily isn't but you will need to have a compression test done after the timing belt is done to determine what damage, if any, is done.
Old 08-25-2014, 01:57 AM
Ran a compression test, 2 cylinders have ok compression, 1 gave less reading and 1 gave zero.
Old 08-25-2014, 02:33 AM
Unfortunately it's time for a head rebuild.
Old 08-25-2014, 04:16 AM
You mean cylinder head? And how much exactly should it cost. It's a 4cyl vtec engine.
Old 08-25-2014, 06:25 AM
origamy's Avatar
Pull the head, and estimate the damage done. If pistons suffered too, maybe it's time for a swap
Old 08-25-2014, 01:19 PM
Faraz123's Avatar
Idk how much a head rebuild costs but I got a remade head off ebay for like 250 USD shipped, it was for a f22b1. It's still running strong in my 97 CL. If you're lucky you may have only bent some valves with no damage to the pistons and should probably just get those done.
Old 08-25-2014, 08:04 PM
Yeah, just pull the head, at the very least you need to have the head rebuilt. When you pull the head you can see if the pistons are damaged or not.
Old 08-28-2014, 02:37 PM
Lost Again's Avatar
"Holmes" you might want to re-think that post (#2).....too late and a cold one will do that.
Old 09-01-2014, 10:11 PM
Thankyou everyone for the info. Luckily only 6 valves got damaged and nothing else and got them replaced, the mechanics also cleaned the head and replaced the timing and tensioner belt. Car runs better than ever !
Old 09-02-2014, 05:46 AM
Originally Posted by Lost Again
You might want to re-think that last part.
Ya my mistake im thinking my camry v6
Old 09-02-2014, 03:22 PM
Lost Again's Avatar
We're cool
I get them confused all the time
aedude006
09-12-2016 05:20 AM
Sucreem
06-27-2013 03:09 PM
mingbling96
09-12-2005 09:50 PM
e_r_i_c_
04-22-2003 07:02 PM
Quick Reply: 2001 Honda Accord F18B, interference engine or not?
