Civic gas issue -95 Civic EX
#27
Re: Civic gas issue
Have you checked the Fuel Pressure at the check spot on top of the fuel filter? (Rule out line blockage from tank to filter)
Have you checked the Evap system? There is a two way valve and a Purge Solenoid that can affect the fuel system and the Charcoal canister I believe. (Helps control fuel pressure by releasing extra vapor pressure)
#28
Have you checked the Fuel Pressure at the check spot on top of the fuel filter? (Rule out line blockage from tank to filter) Have you checked the Evap system? There is a two way valve and a Purge Solenoid that can affect the fuel system and the Charcoal canister I believe. (Helps control fuel pressure by releasing extra vapor pressure)
Thanks.
#29
Re: Civic gas issue
Make sure it's a fuel injection pressure tester not the old classic fuel pressure tester for carb engines. Those typically never went above 15 PSI while fuel injection typically runs 40-45 PSI standard.
Sounds like you could use the Helm's (FSM) Manual. You can pick one up for cheap at helminc.com It will be your bible for the car.
#30
Make sure it's a fuel injection pressure tester not the old classic fuel pressure tester for carb engines. Those typically never went above 15 PSI while fuel injection typically runs 40-45 PSI standard. Sounds like you could use the Helm's (FSM) Manual. You can pick one up for cheap at helminc.com It will be your bible for the car.
#31
Re: Civic gas issue
On top of the fuel filter is that smaller bolt, that is the bolt you remove and screw your tester into. That's the FSM spot for fuel presser testing. Ever wonder why it was a double bolt right there? Now ya know.
#32
You are the man. After examining the kit, I figured it would be the banjo bolt.
#33
Okay, so I tested it.
Results are,
With hose disconnected, 51
Connected 42
I am not within spec, it says it can be a faulty regulator or pinched or clogged line.
I should add, I swapped out the old regulator with one off a GSR because it was all we had at the moment.
Results are,
Connected 42
#35
Re: Civic gas issue -95 Civic EX
It shouldn't but the GSR regulator is probably why the pressure is high. I don't have the manual off hand but I suspect the B18 requires a higher pressure to run properly.
#36
So at this point I am completely lost. I'm not sure what the heck the problem is. A buddy was telling me yesterday that the car can be sucking up air if the fuel level gets too low? I want to say the car starts to act funny once it reaches a bit lower of a half tank and under. I will have to double check today.
#38
Okay. I will try to get a d series regulator at the junkyard. I'm sure they are the same. Regarding z and y series. I didn't rev it la at night since it was 1am and the car is loud lol. I will try again today.
#39
#40
Changed the regulator for a d16z6 one and another main relay and it still has the issue. I took another video. Here you can see it stop responding and dying on its own.
I really need to figure this out ASAP. It's my daily and I have spent the past two days trying to figure out what's wrong. Thanks for the help thus far.
#41
Update!!!
So my car had a quarter tank left. I have noticed that it seems to act like a ***** when it's below half a tank. I go to the gas station (still driving like ****), I make it. Put $20, gives me a full tank and boom. Car drives perfectly!
Anyone?!
Anyone?!
#42
I've not pulled the fuel pump out but I vaguely recall someone saying something about a crack in the bottom of something in idle conversation about another car.
Basically it gets me to wondering, what is the system used to suck fuel from the bottom of the tank when the fuel gets low. Being it's not baffled and the gas slops all over the place when driving or sitting on inclines, what method is used to grab fuel with a 1/16 or 1/32 tank of fuel. I figure there must be something being the car (mine at least) doesn't have problems starting with reeeeaaally low gas even on hills, facing forward, backward or even sideways.
Could it be an issue with that part of the system?
Another question, when you go to put gas in your car (especially when low) does the tank suck air when you first crack the gas cap?
#43
I've not pulled the fuel pump out but I vaguely recall someone saying something about a crack in the bottom of something in idle conversation about another car. Basically it gets me to wondering, what is the system used to suck fuel from the bottom of the tank when the fuel gets low. Being it's not baffled and the gas slops all over the place when driving or sitting on inclines, what method is used to grab fuel with a 1/16 or 1/32 tank of fuel. I figure there must be something being the car (mine at least) doesn't have problems starting with reeeeaaally low gas even on hills, facing forward, backward or even sideways. Could it be an issue with that part of the system? Another question, when you go to put gas in your car (especially when low) does the tank suck air when you first crack the gas cap?
#44
#45
Thing is, even when it is low on fuel, it starts up no problem. It's just when it drives that she struggles. I'm assuming it's something in the tank. Maybe the device that holds the fuel pump and filter? I had the conversation with the dude yesterday telling me that it may be sucking up something other than fuel, he said oxygen?
Sounds like your fuel level gauge is inaccurate...
#46
I would remove the fuel pump and make sure the sock (little filter before the pump) is properly installed onto the pump inlet. Also inspect the pump itself and all lines leading from the pump to the outlet on top of the fuel tank as well. Sounds like your fuel level gauge is inaccurate...
#47
Check the resistance of the wires between the sending unit and the cluster as well.
#49
Run a wire with alligator clips from one point to the other so you can get the continuity measurement of the wire running through the car.
Does your gas cap suck air when you first open it after driving for a while?
#50
Which point to which point? And you mean that sound it makes when it's typically empty? I'll have to drive it around today and see. How long should this while be?
