Inner tie rod for 2004 Accord sedan
Old 08-21-2014, 03:47 PM
XIV
XIV's Avatar
Icon2 Inner tie rod for 2004 Accord sedan
How to diagnose an inner tire rod.
Old 08-21-2014, 05:32 PM
johnsc2235's Avatar
Jack up the front of the car...grab the tire at the 9 and 3 o clock position...pull/push side to side and you'll be able to feel some play if it's bad... That's the easiest way without proper tools
Old 08-21-2014, 05:51 PM
95accordCE6's Avatar
Default Re: Inner tire rod for 2004 Accord sedan
As john said, just make sure any play you're feeling isn't the outer tie rod end. It's a lot easier with a second person to shake the wheel while you look. In my personal experience I've seen way more outer tie rod ends become worn and loose than inners
Old 08-23-2014, 10:49 AM
XIV
XIV's Avatar
Icon2 Re: Inner tire rod for 2004 Accord sedan
I did the 9 and 3 and found out that my tire rod end is done replace it and have a wheel alignment but after the wheel alignment at a certain highway speed I can feel a vibration.
Old 08-23-2014, 12:37 PM
johnnyb588's Avatar
Vibration at high speeds can be a number of things (including alignment). Since you just had the alignment done, I would suspect that. Bring it back to the shop and ask them to check the specs.
If it's not the alignment (or balance, which they can check as well), I'd check your axles. A bad inner joint can cause shaking at high speeds. Check to see if there is any grease sprayed around near any of the axle boots.
Old 08-23-2014, 03:59 PM
If the alignment is proper I suspect wheel balance as suggested
Old 08-23-2014, 07:42 PM
XIV
XIV's Avatar
When you say " a bad inner joint" , are you referring to inner tire rod?Btw there is no grease spray around the boots.How can I check/diagnose the inner tie rod?
Old 08-23-2014, 08:30 PM
johnsc2235's Avatar
Inner cv axles wear over time, which causes excessive play which then causes vibration. You don't neccessarily have to have grease spitting out for a joint to be bad or cause a shake.. It just has to have some wear which typically is not visible.
Old 08-27-2014, 12:18 PM
VeeSykkz's Avatar
TIE* rod. Not being a Grammer ****, but you really need to know proper tech terms.
Old 08-27-2014, 12:20 PM
Plead da Fif
It Wasn't Me's Avatar
I'd hope not, considering you've misspelled grammar.
Old 08-27-2014, 12:23 PM
VeeSykkz's Avatar
Hahaha stupid auto correct! It even capitalized it.
Old 09-19-2014, 05:01 PM
XIV
XIV's Avatar
I apologize for the typo...
Old 09-19-2014, 05:46 PM
XIV
XIV's Avatar
Default Re: Inner tie rod for 2004 Accord sedan
I am replacing my tire rod dust seal what is the proper tools that I need to tighten the band bellows on my 2004 Accord sedan? Could someone post a photo of the tool or tools?
scubacamper
11-06-2015 03:47 AM
jdmstyleEJ6
04-23-2011 08:10 PM
skcivic4life
08-22-2008 10:09 AM
busyychild
01-03-2008 01:30 PM
diyer
12-06-2005 06:09 PM
Quick Reply: Inner tie rod for 2004 Accord sedan
