RSX header on EP3?
Old 08-07-2014, 02:14 PM
DvrkLord's Avatar
Default RSX header on EP3?
Im looking to get a K tuned exhaust for my ep3 and it only bolts up to an RSX header, if I used an aftermarket header for an RSX will it work on my EP? I have heard people saying the problem is the rex header won't bolt up to the ep3 exhaust but if Im changing that will there be any issues?
Thanks. Im an EP3 newbie.
Old 08-08-2014, 10:14 AM
mustclime's Avatar
Default Re: RSX header on EP3?
been covered about 1,000,000 times....the k20a2/z1 has higher compression...so the gasses comming out the heads are hotter....so the cat was moved farther down stream.....so the cat is longer and the mid pipe is shorter.....so there is not way you can just bolt up a type-s header to an ep mid pipe...
fyi....no kpro...your ecu will flip out when your secondary o2 sensor burns up(because there is no cat) and dump fuel...you will run very rich and your milage will be carp.
Old 08-08-2014, 01:35 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
yeah you have to modify exhaust to make it work. Or use full RSX-S exhaust system, I believe I read that all bolts up the same.
VtecKiDD
Performance
198
05-24-2011 07:23 AM
Porterhouse
04-20-2007 02:47 PM
The-Kid
10-12-2006 03:43 PM
mr devious illusions
04-28-2006 06:52 AM
kpxshorty
04-26-2005 10:15 AM
Quick Reply: RSX header on EP3?
