Trans won't go in gear
Old 07-30-2014, 06:08 AM
Chavy340's Avatar
Icon2 Trans won't go in gear
2006 RSX type-s wont go in gear. When the car is running and trying to put in any gear it won't go in and also grinds if trying to go in reverse. When the car is off it will go in gear but it's also kind of hard to put in gear. When driving it wouldn't come out of gear and if it does it wont go in the next gears. SOMEBODY HELP PLZ. ASAP
Old 07-30-2014, 06:33 AM
SickSi99's Avatar
Default Re: Trans won't go in gear
Did you check your transmission fluid?
Old 07-30-2014, 06:36 AM
mustclime's Avatar
blown clutch master or slave cyclinder...I usally replace both at the same time as they seem to go around the same time....do not get box store parts....oem acura or you will be doing this again sooner than you want to.
Old 07-30-2014, 07:07 AM
Chavy340's Avatar
Thanks. I will check that.
Old 07-30-2014, 07:11 AM
Chavy340's Avatar
Wouldn't those cause the pedal to sink to the floor? and also when in gear and foot on the clutch it makes like rattling type kind of noise.
Old 07-30-2014, 12:36 PM
AutohausAZ-Mike's Avatar
Hi,
First I would check the fluid in your clutch reservoir, If its low you might
have a leak somewhere. Also check your clutch master cylinder and slave
cylinder. If you need those two parts we have them available. Here is the
link for both of them.
AutohausAZ - Clutch master cylinder
AutohausAZ - Clutch slave cylinder
Disclaimer: Make sure to check the year and model of the vehicle before
placing an order.
Old 07-30-2014, 03:21 PM
Need 4 Speed's Avatar
Clutch master cylinder, check the fluid and for leaks. Might be time to replace it.
Old 07-31-2014, 07:38 AM
mustclime's Avatar
depends on whats blown and how badly...blown does mean that something is leaking, it just means that you are not pushing enought fluid to more the clutch engagment arm enought to lift the pressure plate...most times the clutch peddle will stay on the floor but not always....
Old 08-03-2014, 08:22 PM
DC5nub's Avatar
i had this issue recently. I replaced both slave and master cylinders, and eventually one day the car would not go into gear while on. However, it would go into gear when the car was off. If you are having this issue, and have confirmed your CMC and CSC are working, then I would suggest looking at your actual clutch and pressure plate. Turned out that one of my springs on the clutch broke out and was not allowing the car to disengage. Good luck!
Jamesflo
01-17-2012 06:18 AM
JPerkMr954
15
04-28-2011 02:07 PM
boostedeghatch
Transmission & Drivetrain
14
01-14-2009 11:11 AM
boostedeghatch
29
01-03-2009 12:20 PM
Quick Reply: Trans won't go in gear
