overheating , 93 integra
Old 07-29-2014, 09:15 AM
danteisme's Avatar
Default overheating , 93 integra
i'm working on my brother's 93 RS. it has about 170K on it, radiator and tstat were replaced last year i believe. the waterpump and timing belt were replaced at 105K miles. my buddy is about to buy it off my brother, but all of the sudden it is overheating so we're trying to fix it before he buys it.
the coolant level is right where it needs to be so its not a leak. we started the car and watched the gauge. id say within about 6-8 min it was a notch below the red on the gauge so we killed the car. i noticed that the fan did not kick on and when i squeezed the upper rad hose, it was not stiff. like, the tstat did not open and allow coolant into the motor.
here is my though. replace the tstat in case it is stuck shut, and replace the coolant temp sensor(controls the fan, right?) the other reason i want to replace that part is the gauge was acting a little goofy when the motor wasnt running. after we killed the car to let it cool off, i put the key in the on position to check on the temperature. the needle kind of bounced around on the gauge.
anything else i should be looking at or am i on the right path?
Old 07-29-2014, 01:14 PM
TheRealTegger's Avatar
Default Re: overheating , 93 integra
Chances are excellent that the cooling system is just fine and that your problem is in the electrical system instead.
Chances are also excellent that somebody has chopped up the factory wiring to install/alter this or that, and has made a hash of the job.
Old 07-29-2014, 01:46 PM
danteisme's Avatar
If its electrical its not from cuttin the harness i dont think. The car is all bone stock with the exception of an intake
Old 07-29-2014, 03:30 PM
Pimptegr4's Avatar
Have you checked the oil at all? Milky oil would sure suck but pinpoint it, the not "stiff" upper hose make it sound to me like in aint full of water also.
Old 07-29-2014, 03:57 PM
danteisme's Avatar
Oil is full, coolant is full, no discolorations or anything. It was fine 2 weeks ago when we started it up and let it run for about 10 or 15 minutes. We're foing to replace the sensor and tstat this weekend and go from there. It just seems like its not opening up and circulating the coolant through the motor.
Johnrb
04-19-2012 07:09 AM
marebear1984
09-17-2011 11:12 PM
Paulie10
06-02-2009 12:58 PM
wtfda88
02-23-2006 04:55 PM
egme93
11
10-10-2005 01:31 PM
Quick Reply: overheating , 93 integra
