my intake manifold cracked at runner #4
I never narc'd on nobody!
Re: my intake manifold cracked at runner #4
Other than the rear brace, they're all cross-compatible from 92-00 with the only differences being the IACV and FITV. Just get any complete intake manifold off any 92-00 D series, and you'll be able to make it work.
http://tampa.craigslist.org/hil/for/4565209193.html
I'm gonna try jb weld, I have some and its the only thing IV got right now that might fix it. If it doesn't I'll go get a manifold from a y7 at my local junkyard since thats the only kind there
If you are gonna JB Weld it, I would get a grinder and create a valley for the JB weld to stick to not to mention the gouges.
How do you own anything that works? It sounds like you beat the crap out of everything. Racing your girlfriend's Accord 10 times straight and frying the transmission...
Is there an anger management issue lurking?
That was our civic. My accord has its own problems.
I pulled the intake back off, and staring at it I immediately noticed the problem. Felpro put the wrong gasket in the box! There's a copper crush washer above the coolant line that runs next to runner #4, there's no holes there to necessitate a crush washer.
the gasket fit onto the studs just fine, but looking at it closely the holes for the ports are too big, and there's that piece of **** washer there that broke my intake.
how much do you guys wanna bet Federal Mogul's felpro brand will accept no responsibility for supplying me the wrong gasket in my head kit, and breaking my intake manifold? This is easily a several hundred dollar job for a shop, they need to reimburse me for their mistake. I bet they're gonna say its my fault for not checking that they gave me the wrong ******* part
I'm gonna complain to rock auto too since they retailed me the head set which included the wrong intake manifold gasket.
It is true you should always compare the parts you are replacing with the new parts.
But, I would try to go after them if it was part of a kit that they sold you for a not swapped car or the swapped information was provided to the representative that facilitated your purchase.
I torqued it to what the manual says. I slid the thing onto the studs and without over thinking it assumed that a multi-million dollar company which up until today had my brand loyalty was capable of putting the correct parts in their boxes.
I didnt see the problem until I took it apart again and inspected it.
rock auto told me they can give me another gasket, but it'l still have the crush washer there that doesn't belong there. I'm gonna ask Honda what they think about it tomorrow. In the mean time I'm gonna try and make sure I do infact have a d15b7 intake manifold and not something else. I know its a b7 head since I already confirmed that. There's no hole in the head for the crush washer either so I dunno.
Are you talking the hole to the far right? Looking over a number of parts catalogs, that's completely normal. It's there to help seal that coolant channel. If you broke your intake manifold because of that, it's not the gasket's fault. You say you "torqued it to spec", but when was the last time your torque wrench was calibrated? What kind of torque wrench is it? There's a reason professional shops have those things calibrated once every 3-6 months.
I used a Snap on digital torque wrench and it was calibraded recently I think it was either June or July I dont remember though.
that does look like the gasket, except the coolant flows thru the square hole not the circular one. That circular hole doesn't co-exist with anything in the cylinder head or intake manifold. And mine had a copper crush washer wrapped around it, and it didn't crush at all.
its a 95 DX civic coupe
Fish Twig
Since you're always saying your tight on a budget cut the copper part of as long as it doesn't effect the gaskets purpose. You did say it didn't lead to anything.
That could be the opening for the egr found the d15z7/d16y5/d15z1
I have never seen an intake manifold crack before under normal circumstances.
You have created so many problem threads...probably more than everyone who has viewed this thread combined together. That should tell you something.
Density of Metals
http://www.coolmagnetman.com/magconda.htm
Fish Twig
It doesn't excuse the fact that knowingly used with force and hoped it wouldn't become an issue.
Either way since not everyone knows the extent of the damage the next solution would be to jb weld and to let it cure properly before using. And to cut out the copper ring without damaging the gasket.
Density isn't the only measure of a metal's hardness, and is actually a poor scale for hardness. The Rockwell scale, as well as ductility, are much better gauges for that. Copper only ranks a 10 on the Rockwell scale, and 1 for ductility. Cast iron ranks an 84 on the Rockwell scale, and a 5 for ductility.
You have his quote in all of your posts so I doubt you will take his side.
I want to see if anyone sells the gasket without the dumb *** metal bit. I'll take the manifold with me tomorrow to the parts store and see what they have and how well it fits, versus what came in the felpro head set.
Tony might be right, if it comes down it I'll carefully cut the crush washer off. I was told I'm the first person to inquire about this problem by Rockauto, so I guess its possible my intake had a casting flaw? I'm dunno exactly, but the gasket wasn't even fully torqued when it cracked and apparent the washer has never been a problem before. My wrench didnt beep at me, all I heard was "crack!" and my intake had a fracture in it.
if I cant fix it ill either pull a different manifold, or order the b7 manifold. I found some on eBay, and according to car-parts.com there's actually some junkyards that aren't too far that have dx civics.
I'll show the thread what happened tomorrow, right now I'm more sick of Honda civics than I can handle, and I dont wanna look at it
