2008 Civic Si radio issue
Old 07-08-2014, 10:54 AM
TXcivic96's Avatar
Default 2008 Civic Si radio issue
I've done a search and was unable to come up with anything so heres the problem.
It's a non-nav model
When the radio is on and the car is running everything works as it should, how ever when the car is turned off and the key is removed, door is opened and locked, the radio does not shut off, it will stay on untill the battery dies, (it hasnt done this yet i've let it go for about 1/2 hour). Whenever you lock the door through the key fob the radio will quickly dim and then go back to regular brightness but will not shut off.
However if you push the button to power off the radio the anti-theft light will come on and you can not re-start the radio.
The door switches seem to work as once the door is opened the dome lights come on, however i've also notice that whenever you shut off the car the passenger door does not unlock (i dont know if this is normall or not you have to manually unlock the door or push the switch for it unlock)
any help is appreciated
John A. Parker
04-10-2017 10:00 AM
lrhtech
07-13-2015 05:30 PM
Tonyl507
03-09-2007 06:23 AM
malix
01-10-2006 02:22 PM
Quick Reply: 2008 Civic Si radio issue
