66mm street car eg build
Old 08-01-2014, 06:53 AM
  #26
H.Veras's Avatar
Default Re: 66mm street car eg build
What a beautiful, well built car man, great work and lots of attention to details, it is just beautiful.
Old 08-01-2014, 08:13 AM
  #27
civicboy07's Avatar
Thanks man, I appreciate it. Definitely lots of time and hard work.
Old 08-01-2014, 10:39 AM
  #28
H.Veras's Avatar
When are you taking her to the track? And to what track will you go to? I would love to see this car in person.
Old 08-01-2014, 10:43 AM
  #29
civicboy07's Avatar
Once the tune is 100% I'll take it out and see what we can do with the radials. But I'm in northern indiana, so will probably go to a local track or us131 in Michigan
Old 08-01-2014, 10:49 AM
  #30
H.Veras's Avatar
Well, best of lucks man and keep us updated.
Old 08-02-2014, 07:47 PM
  #31
civicboy07's Avatar
Thanks man I will.
Old 08-02-2014, 07:51 PM
  #32
civicboy07's Avatar
Made it to a car show today and I guess the race car is my show car too. Won best engine 👍
Old 08-07-2014, 04:17 AM
  #33
H.Veras's Avatar
Any updates?
Old 08-07-2014, 07:22 AM
  #34
2000CTRSi's Avatar
Love that color. Looks great! Lets see some dyno graphs!
Curious on that a1000 pulling from the intank 255.... Seems to me like that could cause issues later on... for the a1000... No?
Old 08-07-2014, 10:41 AM
  #35
SwappedTURBOegg's Avatar
^ no probbaly not
Old 08-07-2014, 02:06 PM
  #36
civicboy07's Avatar
Started tuning today on the dyno. Made 523whp on 19psi only revving to 8k on conservative timing. But pretty sure one of my injectors is having an issue. Going to send them to fic and then go back later.
Old 08-07-2014, 02:11 PM
  #37
civicboy07's Avatar
Old 08-07-2014, 02:18 PM
  #38
civicboy07's Avatar
Thanks. But I haven't had an issue with it like this yet and old stock sleeve motor was the same way on 32psi. Same concept of what most people use to do with a 255 intake and a 044 inline.
Old 08-07-2014, 08:20 PM
  #39
civicboy07's Avatar
Figured I'd upload some other pics from today. Jason got some videos too so once he goes through them we will get some posted up.
Size:  73.5 KBName:  SZbTnpv.jpg
Size:  66.5 KBName:  TBFHX7s.jpg
Old 08-22-2014, 01:59 PM
  #40
civicboy07's Avatar
Well, made 609whp today on 24psi. Jason was starting to work on timing some and we broke the diff in the trans. Good news is, revving to 9k gets me to 160mph so should be set for a decent trap speed.
Old 08-28-2014, 04:24 PM
  #41
civicboy07's Avatar
Broke 4th gear on the dyno and the diff. Did get a new donor trans for parts and will be installing a quaife lsd
Old 08-28-2014, 10:27 PM
  #42
D-BUILT's Avatar
You guys are overloading the stock gears of that tranny with those big tires on the dyno.
Old 08-28-2014, 10:35 PM
  #43
civicboy07's Avatar
I plan to switch to a smaller tire now, I was running them before since I had thought this was a gsr trans and needed the taller tire to help with trap speeds. Found out it was a ls trans on the dyno since revving to only 9200rpms was taking it up to 165+mph. We plan to also just do more tuning at the track once the trans is back together to see if that helps keep it together.
Old 08-31-2014, 12:45 AM
  #44
king06's Avatar
Any driving videos? I'm going to get the same turbo. Also, what you use for exhaust? the regurlar vband or the marmon v band?
Old 08-31-2014, 12:50 AM
  #45
civicboy07's Avatar
I could post a couple that I have. Videos are only on 19psi and I have a video just crusing. Right now it's a 3" off the turbo then goes to 4" piping and goes out the bumper. Just using a normal v band. Cut off the one on the Borg and welded the new v band flange on.
Old 08-31-2014, 02:02 AM
  #46
civicboy07's Avatar
Here is a idle video
Just cruising in 4th gear
3rd gear and 4th gear videos. still on lower boost and only revving to 8k but the does build boost fairly quick.
Speedo is off a good amount too haha
Old 09-01-2014, 09:55 PM
  #47
civicboy07's Avatar
Got the trans put together today and back in the car. We were able to do a little tuning tonight and it's pulling pretty good on 24psi. We will have to do the rest of the tuning at the track or dyno. Here is a video with how it sits now.
Old 09-05-2014, 08:39 AM
  #48
munster87's Avatar
Awesome build, love your car!
Old 09-05-2014, 10:58 AM
  #49
RTG90's Avatar
mann i want to build a motor like this
Old 09-05-2014, 12:00 PM
  #50
civicboy07's Avatar
Thanks guys. Thing has been a challenge for sure, always seems to be something. Pretty sure I broke 3rd gear last night -_-
Quick Reply: 66mm street car eg build
