66mm street car eg build
Old 07-03-2014, 09:18 AM
civicboy07's Avatar
Default 66mm street car eg build
Well here we go again. last build lasted me 50 miles from one of the sleeves dropping, The company did cover the sleeves and did a new block. So it's all apart and pretty much decided to change a lot again. Ditching the eagle rods, wiseco's, single disk clutch, and the arp head studs. Also decided to go with a gsr block this time.
Here is the build so far,
B18c1 block with LA pro cool sleeves
O ringed
Cp 10:1 compression pistons
Manley turbo tuff rods
Hd wrist pins
Arp main studs
Speedfactory L19 head studs
Itr oil pump
Je pro seal head gasket
Acl race hx bearings
B16 head
Port n polished
Super tech 85lb valve springs, retainers, and valves
Pro1 cams with Golden eagle cam gears
Skunk2 lma's
Ported Victor x intake
76mm blox throttle body
Endyn cam tensioner
Fuel system
Fic2150cc injectors
255 intank with inline a1000 pump
-10 feed line
-6 return line
Edlebrock Fuel rail
A1000 fpr
Tuning and igntion system
Aem ems 1040
Rsk coils
Aem epm
Rywire cop harness
Rywire cop plate
Turbo setup
Carberry built forward facing t4 twin scroll manifold
S366 turbo with divided t4 1.10 housing
Mvr 44mm wastegates
Precision 825hp intercooler
Tial bov
Carberry built 3" charge pipe
Bwr catch can setup
Speedfactory 4 bar map sensor
Drivetrain
Gsr transmission
cnc werks 5th gear cuff
Competition clutch twin disk type c
Drive shaft shop 5.9 axles
Suspension
Skunk2 pro s ll coilovers 10k fronts 18k rears
Function7 rear control arms
Ktuned traction bar
Energy suspension bushings
Brake setup
Wilwood master cylinder with chase bays mounting plate.
Finishing lines sfwd brake line kit
Gsr front brake setup
Goodwridge G-stop ss brake hose
Staging brake on rear brakes
New block. Shop has great turn around time and customer service
I was also able to score a deal on a new set of seats.
Also got a staging brake installed
I'll keep pictures coming as the build comes together. Trying to have it back together soon.
Old 07-03-2014, 05:31 PM
Keo00civic's Avatar
Default Re: 66mm street car eg build
Nice!
Old 07-04-2014, 08:21 AM
$MIKE$'s Avatar
9 seconds ???
Old 07-04-2014, 09:46 AM
civicboy07's Avatar
Originally Posted by $MIKE$
9 seconds ???
Yea that's what my goal is. But also want to see what I can do with the m&h radials before slicks
Old 07-06-2014, 08:50 PM
Mach1n1st's Avatar
**** looks dope pleasure taking care of the block for you. If you need anything you can text me 5405320246.
Old 07-06-2014, 08:53 PM
civicboy07's Avatar
Thanks a lot for doing it and getting it done fast. She should make some power now.
Old 07-06-2014, 11:24 PM
civicboy07's Avatar
Originally Posted by LoveHonda123
Looks nice!
Thanks 👍
Old 07-08-2014, 04:21 PM
CRUZ131313's Avatar
nice how much hp?
Old 07-08-2014, 05:34 PM
civicboy07's Avatar
Originally Posted by CRUZ131313
nice how much hp?
Shooting for around 700-800whp
Old 07-08-2014, 10:21 PM
CRUZ131313's Avatar
ooo dam nice
Old 07-08-2014, 10:50 PM
CRUZ131313's Avatar
what kind of crankshaft did you use?
Old 07-11-2014, 06:09 AM
civicboy07's Avatar
I'm using a b18b1 crank with ls length rods
Old 07-11-2014, 06:22 AM
civicboy07's Avatar
decided to go ahead and do a brake booster delete and tuck the brake lines.
Before
And after
Also got some stuff from speed factory in. Name:  Brn2yHo.jpg
Old 07-11-2014, 02:43 PM
ckrs_civic's Avatar
very nice.
Old 07-13-2014, 03:58 AM
lmalloy's Avatar
Looks good
Old 07-13-2014, 09:43 AM
civicboy07's Avatar
Thanks, motor should be done this week and hopefully in by the weekend. Was able to go pick up a set of dss 5.9 axles yesterday for a killer deal Name:  SaqDIbN.jpg
Old 07-18-2014, 09:11 AM
civicboy07's Avatar
Finally got the block back from being machined and cleaned. Looks brand new now. I'm still waiting on the head to be finished, but should be done by this weekend. Carberry and me got started on getting the bottom end assembled and ready to go
Upgraded cp pins next to the standard cp pins
We were able to get the crank in and double check clearances with plastigauge, but the shop did order wrong rod bearings so waiting on those now to finish up.
Old 07-23-2014, 07:51 PM
civicboy07's Avatar
Got the head back today. Decided to go with ferrea super alloy valves. Looking brand new now though 😎
Now we are just fighting with getting proper rod bearing clearances. Once we can get that figured out, the motor could go together and go in the car.
Old 07-30-2014, 03:49 PM
civicboy07's Avatar
We got a lot done last night and was able to get the motor in and running
Valve cover still needs powder coated
And it's in
Old 07-30-2014, 06:12 PM
SiRCiviC94's Avatar
nice work
Old 07-31-2014, 01:32 PM
Steeve_Civic's Avatar
Very Nice! Which fuel are you running?
Old 07-31-2014, 01:37 PM
civicboy07's Avatar
Originally Posted by SiRCiviC94
nice work
Thanks
civicboy07's Avatar
Thanks, it's on pump e85 still
Old 07-31-2014, 03:59 PM
$MIKE$'s Avatar
In for dyno # 👍
Old 07-31-2014, 09:48 PM
civicboy07's Avatar
Made some progress today. Jason got the car running great and smooth and street tuned on 20psi for now. Should be on the dyno next week 😁
Still have to get some supports made for the wing
Quick Reply: 66mm street car eg build
