D16y7 - transmission main bearing replacement
Old 05-27-2014, 03:33 AM
Jazlynsciviclx's Avatar
Default D16y7 - transmission main bearing replacement
Tranny started making noise that went away when clutch was pressed so i replaced clutch and throw out bearing thinking it was the problem. Replaced the transmission and still same problem so i opened tranny yesterday and a bearing is broken. Can anybody tell me bearing name and How hard of a job am I looking at? Thanks
Old 05-27-2014, 03:36 AM
Default Re: D16y7
Its the top bearing on left thats broken
Old 05-27-2014, 09:41 AM
talks to himself
CX-Adam's Avatar
Default Re: D16y7
That's your mainshaft.
I just did this work and, in my opinion, getting the transmission out was the hard part.
There are a ton of write-ups for how to replace the bearings.
You can order the bearings individually here: http://www.hondaautomotiveparts.com/...5=MT+MAINSHAFT
Or, you can go into the hondamarketplace and find a sponsor that sells a kit for way less money.
Old 05-27-2014, 06:03 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: D16y7
Call Synchrotech, and order the complete rebuild kit. Like CX-Adam said, getting it out and open is the hard part. While you have it out and open, you should absolutely replace all of the bearings, seals, and synchros.
Old 05-28-2014, 02:23 PM
Default Re: D16y7
Thanks for all the help so far another question? How can I remove old bearing from case without messing up case?
Old 05-28-2014, 02:26 PM
Default Re: D16y7
Another pic this time I cleaned it
Old 05-28-2014, 03:07 PM
Default Re: D16y7
Pic
Old 05-28-2014, 03:10 PM
NotARaCist's Avatar
Default Re: D16y7
You should be able to get a bearing puller on the inside of the outer race. Alternatively, a dremel with a diamond cutting wheel, cut it at the fluid passage, and break it out.
Old 05-28-2014, 04:10 PM
Default Re: D16y7
Is this the bearing I need? http://www.partsgeek.com/gbproducts/WC/6007-01081372.html?utm_content=YN&utm_term=1995-2004+Honda+Civic+Mainshaft+Bearing+SKF+W0133-1628475+95-04+Honda+Mainshaft+Bearing+2000+1999&fp=pp&gbm=a&u tm_source=google&utm_medium=ff&utm_campaign=PartsG eek+Google+Base&gclid=CNSWnqrrz74CFQEdOgodVAkApA
Old 05-28-2014, 04:19 PM
Default Re: D16y7
http://www.hondaautomotiveparts.com/auto/jsp/mws/srchrslts.jsp?search=sku&catcgry1=&inputstate=&src hwords=91004-PL3-A03&vinnosrch=Enter+VIN+Number+---
Old 05-28-2014, 05:05 PM
Former User's Avatar
Default Re: D16y7 - transmission main bearing replacement
In the future, please create thread titles that are more informative - edited.
Old 05-30-2014, 07:43 PM
Okay thanks for all the help part is on its way from dealer same prices as online and quickier
TravisBiggie
Honda Civic (2001 - 2005)
11-25-2012 02:00 PM
Eklsv-t
08-28-2008 10:52 AM
jamaican
07-27-2007 05:34 PM
candy eg
01-12-2006 08:48 PM
Quick Reply: D16y7 - transmission main bearing replacement
